- Oct 23, 2021
- 162 (0.14/day)
System Name | Mypc |
Processor | AMD Ryzen 5 5600x |
Motherboard | MSI MAG B550M BAZOOKA |
Cooling | Coolermaster Hyper 212 Rgb |
Memory | Corsair 3600 mhz Cl16 ddr4 8x2 |
Video Card(s) | Asus RX 6750 XT Rog Strix OC Edition |
Storage | Samsung 990 PRO 1TB + Samsung 980 Evo 50gb |
Case | Coolermaster TD500 Mesh White |
Power Supply | Corsair CX-650F RGB |
Software | Windows 11 |
Hello everyone, last week i have changed the thermal paste on core die of my rx 580 8gb sapphire pulse, and the temps dropped about 10-15 degrees. But while removing the heatsink unfortunately i ripped off a thermal pad of off a single memory chip. I have used the card for a week without problems both core and memory chip temperatures doesnt exceed 70 degrees celsius under heavy load.
I have three questions regarding this;
1. I already ordered the correct size thermal pads for the gpu and i will be replacing it once arrived. When I take off the heatsink to replace thermal pad do i also need to replace the thermal paste again ?
2. Another worry of mine is, any chance i could have damaged the card by using it without a thermal pad on the memory chip ?
3.This one could be off topic but since i got the card the core and the memory temperature is always linked, is this normal behaviour ?
