Question HDD2.5" + enclosure case usb3.0
nandobadam
20 (2.86/day)
I ejected safely remove hardware in Windows 10 after When pulling the USB3.0 cable from the case + HDD2.5" to remove it from the PC my hand hit the HDD case and it moved on the table. Did this hit the read/write heads scratch the magnetic disks? my disks are 2013 WD10JPVX-08JC3T5 and HGST HTS541010A99E662 and Seagate ST500LM030
161 (0.15/day)
You managed to hit three hard disks simultaneously?
If you're absolutely determined to find out if the platters are scratched, first copy all the data on to new drives (2013 drives are 11 years old and way outside any warranty period). Next, remove the cover from the hard disk. Disassemble the platters so you can view both sides of each platter. Check with high power microsocope for scratches. Regardless of condition, smash the platters with a large hammer and dispose of carefully.:)
A less destructive test would be to download a trial copy of Hard Disk Sentinel and run a surface read scan. This can take ages on a big drive, e.g. 2 to 8 hours. If the result looks like this, you've got serious problems. You won't know for certain if the platters are scratched, but at least you might learn if the drives are going bad.
https://www.hdsentinel.com/help/en/61_surfacetest.html
42,222 (6.64/day)
Did you hear anything from the drives like a noise you normally don hear? If not just run them and take caution when removing cables
nandobadam
20 (2.86/day)
the hit shock was on a USB 3.0 enclosure case + 2.5" hdd I pulled the USB3.0 cable from the PC on it came out quickly and my hand hit the side of the case moving it under the table but it didn't fall to the floor
before pulling the cable I had ejected hdd2.5 + usb3.0 case in Windows 10
cases Orico 25Pw1 black and Kesu 2530
Ruru
S.T.A.R.S.
12,790 (2.93/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-A
Cooling Arctic Freezer 50 / Thermaltake Contac 21
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Creative Omni BT speaker
VR HMD Oculus Rift CV1
Most likely the drive is fine. Funnily enough, I've used that "remove safely" feature the last time about 20 years ago. USB is hot-pluggable anyway.
