Question regarding voltage drops on PCIe Slot
4 (0.00/day)
Hi everyone!
I am a bit concerned about the readings of PCIe Slot voltages during full load of my GPU. Can someone please take a look at my readings from HWiNFO and GPU-Z? The first screenshot shows GPU readings from HWiNFO and GPU-Z - and second one shows Motherboard side of things. I am confused whether the 11.6 V reading from GPU or 11.736 V from motherboard is more accurate. I'll only add that so far I don't seem to have any problems. My questions are: Are these drops acceptable - and if they are, can they damage something in the long run?
PS. Ignore my native language on HWiNFO:)
My specs are:
Motherboard: Gigabyte B85+HD3 Rev 2.0
PSU: Corsair TX650M
RAM: 16 GB
CPU: Intel i7 4790
GPU: Gigabyte RTX 3060 Windforce OC 12 GB
OS: Windows 10 Pro 64bit
5,847 (0.80/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
Under 12V would concern me a little, except for the fact that the PCIe slot doesn't contribute much to the GPU. And your 8-pin power to the GPU looks good at 12.1V, so I wouldn't worry about it.
ir_cow
4,612 (0.77/day)
USA
11.6 is low. It will probably crash if you a full load like furmark.
Edit: nvm. That's PCIe slot voltage. If the 8pin dropped that low I would be concerned.
4 (0.00/day)
Thanks for the replies! I feel somewhat relieved now, knowing that PCIe slot voltage isn't as important as 8pin one.
583 (0.29/day)
Hungary
System Name Detox sleeper
Processor Intel i9-7980XE@4,5Ghz
Motherboard Asrock x299 Taichi XE (custom bios with ecc reg support, old microcode)
Cooling Custom water: Alphacool XT45 1080 + 9xArctic P12, EK-D5 pump combo, EK Velocity D-RGB block
Memory 8x16Gb Hynix DJR ECC REG 3200@4000
Video Card(s) Sapphire RX7900XT - NITRO+ Vapor-X 20GB
Storage Samsung PM9A1 1Tb + 2x PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb
Display(s) HP ZR30W (30" 2560x1600 10 bit)
Case Chieftec 1E0-500A-CT04 + AMD Sempron sticker
Mouse Logitech G400
Keyboard IBM Model M122 (boltmod, micro pro usbc)
Software Windows 11 Pro x64
