Quick comparison, 1Gbps, 2.5Gbps, 5Gbps, 10Gbps Ethernet
17,573 (2.40/day)
Note that this test is limited by the fact that the target is a mechanical hard drive, even if it's a NAS drive. The NAS also has an Aquantia 10Gbps card in it.
This is obviously not a thorough test, but I wanted to see how the Realtek 2.5Gbps chip performed.
Take this for what it is, a quick test and nothing more/less.
I'm actually surprised at how decent Realtek's 2.5Gbps chip is. I guess they've stepped up their game quite a bit.
Intel 1Gbps
128914
Realtek 2.5Gbps
128915
Aquantia @ 2.5Gbps (limited to 2.5Gbps in the driver settings)
128913
Aquantia @ 5Gbps (limited to 5Gbps in the driver settings)
128912
Aquantia @ 10Gbps
128910
42,051 (6.62/day)
I just know a dedicated lan card helps if you need more speed than 100/1000 solutions lol. Also it's theorhetic speeds...
17,573 (2.40/day)
Why is it theoretic? Yes, there's some slight overheads due to how the protocols on top of Ethernet works, but on Gigabit you should be able to hit 980Mbps or more on a modern PC.
And why would a dedicated card help vs. integrated on the motherboard? It might've made a difference back in the day, but no so any more.
This is just a quick and dirty benchmark that gives people an idea what they can expect in terms of performance from a hard drive based NAS.
This is obviously not the maximum performance you can get.
42,051 (6.62/day)
Resistance
Andru123
8 (0.01/day)
Intel 1Gbps
Realtek 2.5Gbps
Any chance you also measured CPU/power consumption? Realtek problem was that it used too much CPU during network traffic handling.
17,573 (2.40/day)
This thread is almost four years old....
3,820 (0.58/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
3,276 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Intel 1Gbps
Realtek 2.5Gbps
Aquantia @ 10Gbps
Do you recall which intel chip you were testing?
17,573 (2.40/day)
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
Helios LanTest = 17 Sep 2014 project.
Too old for my taste.
3,575 (1.69/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Did you monitor CPU usage during these tests?
After using my 13700k system daily I started noticing very high cpu usage linked the network throughput.
I then did some research which found multiple sources of information realtek nic's need higher cpu to process same through vs intel.
Comparing to my 9900k system though isnt apples to apples, however luckily I have a pcie intel gigabit card available.
Here is some data, in both cases the equivalent features are enabled on the network devices.
Realtek 2.5gbe vs Intel gigabit both running in 1000mbps full duplex mode.
2 RSS threads
Checksum offload fully enabled.
Interrupt moderation disabled.
Equal transmit and receive buffers.
Large send offload disabled.
VLAN disabled.
Power saving features disabled.
Jumbo frames disabled.
Flow control enabled.
% means percentage per logical core so this cpu e.g. can handle 2400% max. But load is only spread over core's equal to RSS threads, so in this case max 200% available. I did best to extract data used by the network itself, not the userland processes.
Realtek
100mbit 6% cpu usage
250mbit 23% cpu usage
500mbit 49% cpu usage
968mbit 112% cpu usage (requires 2 RSS threads to max out on a powerful 13700k)
Intel
100mbit 1% cpu usage
250mbit 3% cpu usage
500mbit 9% cpu usage
974mbit 21% cpu usage
The realtek can go up to max 4 RSS threads, vs only 2 on Intel, I now know why. Realtek network hardware seems very cpu heavy, even though it now has similar feature set at consumer level. Something must be done pretty badly in drivers or not optimised in hardware design?
Luckily my board has spare x1 slot for card, although its annoying as I prefer to use onboard. Wouldnt care if the difference was maybe only an extra 20% or so, but these numbers are astounding.
Andru123
8 (0.01/day)
I have extensively tested different Realtek and intel chips, and have very different results. (It is dutch forum, but you can use translate button if screenshot is not clear)
I think there is your problem:
I have all 3 enabled, especially interrupt moderation is the most important.
You did not specify what chips exactly you use, there are many different ones. Latest Realtek chips do not use CPU excessively.
Older intel chips (i210) have special setting “DMA coalescing” that needs to be enabled. It has amazing effect on CPU and power consumption.
@chrcoluk
3,575 (1.69/day)
UK, Midlands
System Name Main PC
Processor 13700k
@chrcoluk
I did state the same settings on the intel nic, that also had those disabled.
For reference enabling interrupt moderation doesnt bring it down to the intel numbers, not even close.
Chip wasnt specified because I dont know the exact chip.
Checked hwinfo for you, it is a RTL8125 Gaming chip.
Andru123
8 (0.01/day)
@chrcoluk Even with Intel chip, the cpu should not go higher than 6% at full load. Interrupt moderation is a feature that is specifically designed to reduce CPU usage and improve throughput at the same time. It is weird to not enable it.
The same goes for hardware offload - network chips can do all the processing much more efficient than CPU, so it does not make sense to not let them.
As I mentioned, i tested with a Realtek 2,5G chip, and did not observe such high numbers, they were slightly higher than Intels, but not much. It could be driver or settings or many other factors.
Solaris17
Super Dainty Moderator
26,910 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
This. With hardware offload off you are shooting youself in the foot. You are literally telling the OS not to offload work to the NIC. That’s said as Andru eluded too some chips differ greatly in not only hardware accel but drivers. I’m not sure why anyone would think anything “gaming” would be highly performant in anything network related.
3,575 (1.69/day)
UK, Midlands
System Name Main PC
Processor 13700k
I think I will give up here.
The point has been bypassed whether deliberate or by mistake.
So I will try to repeat the point once more.
Like for like settings the realtek is a cpu gobbler, the same offloading options are disabled on the intel.
I of course did try them enabled (with all the downsides that come with it, batch processing of packets, latency etc.) and the cpu load is still ridiculous.
Whilst realtek cards seem to be much more stable these days, its not hard to find people reporting high cpu usage, and even server vendors, as well as enterprise software vendors like truenas warning people away from them, so realtek are still not where are intel are. But they probably dont need to be, as being cheaper sells units, and many people will be ignorant of the differences, as fundamentally they do still work, just less efficiently.
I am on the latest driver available for download as well, however if I do find a resolution, I dont mind updating the community. Likewise if anyone has a suggestion I havent tried yet I will of course try it, but as i said I did try all the offloading enabled.
Solaris17
26,910 (3.83/day)
Alabama
VR HMD Quest 3
Yes this is known. Intel nics are much better for network sensitive tasks this even reaches into the server space.
The one thing I will give Realtek and maybe it’s because of there lack of features is that the drivers are generally detected without issue on windows systems
3,575 (1.69/day)
UK, Midlands
System Name Main PC
Processor 13700k
Yep in terms of stability it has been fine, and although the default driver was old, it beats not having no network out of the box. I may end up just living with it anyway, isnt the end of the world.
Andru123
8 (0.01/day)
It was true in the past with older Realtek chipsets/drivers. However their recent chip revisions have significantly improved - that is just an observation I am trying to convey. I was also surprised, tbh, how well Realtek chip performed compared to Intel.
Intel i210, i211 and i219 were extremely efficient and rock solid. With i225, i226, unfortunately, it changed - they are known to lose connection and consume more power.
If you really want to use onboard nic, why don't you try the best settings/drivers for it, because it can be efficient.
3,327 (1.18/day)
North East Ohio, USA
System Name My Ryzen 7 7700X Super Computer
Processor AMD Ryzen 7 7700X
Cooling DeepCool AK620 with Arctic Silver 5
Memory 2x16GB G.Skill Trident Z5 NEO DDR5 EXPO (CL30)
Video Card(s) XFX AMD Radeon RX 7900 GRE
Storage Samsung 980 EVO 1 TB NVMe SSD (System Drive), Samsung 970 EVO 500 GB NVMe SSD (Game Drive)
Display(s) Acer Nitro XV272U (DisplayPort) and Acer Nitro XV270U (DisplayPort)
Case Lian Li LANCOOL II MESH C
Audio Device(s) On-Board Sound / Sony WH-XB910N Bluetooth Headphones
Power Supply MSI A850GF
Mouse Logitech M705
Keyboard Steelseries
Benchmark Scores https://valid.x86.fr/liwjs3
That is, if the stupid thing can maintain a link. The Intel i225 and i226v Ethernet chipsets have been plagued by issues in which they drop connections for no good reason.
Solaris17
26,910 (3.83/day)
Alabama
VR HMD Quest 3
Yeah iv seen your posts and thread about being in that hate train. This is off topic here though. I’d still take one over Realtek and those intel chipsets aren’t used in servers so….
3,276 (1.69/day)
Mouse Logitech M575
21,443 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
I don't know about taking a defective one over realtek but I have one of the revised ones on my file server as well as a dual port X540-T2. Both do fine.
3,327 (1.18/day)
Mouse Logitech M705
Which Intel NICs are used in servers?
Which now begs the question... If Intel can make a good server-grade Ethernet controller, why can't they make a good consumer-grade Ethernet controller?
21,443 (3.40/day)
System Name Pioneer
