Quick look at CPU bottlenecking on 4090 and future prediction with 5090
3,441 (1.16/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
I gathered some data from TPU reviews to have a quick look at CPU bottlenecking, old data is from 7900XTX launch review (13900K test system) and new data from Intel B580 (9800X3D test system)
Left is old data, right is new data
1080p
1440p
4K
The game testing suite have changed between the old and new reviews, but it's interesting to see that the 4090 is able to increase its lead over the 4080 (and also 7900XTX) with the 9800X3D, even at 4K. Yes at 4K the increase is only 2.2%; but with the upcoming RTX5000, i have no doubt that the 5090 will run into serious CPU bottleneck @ 4K.
Recently one Youtuber have noticed that the latest games are more CPU demanding than before
So yeah, CPU and Memory subsystem are getting more important these days
wolf
Better Than Native
8,228 (1.28/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte X650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
From my perspective CPU's can be more lacking than GPU's right now, and can give tremendous leaps even to existing cards at high output resolutions. I went from a 5800X3D to a 9800X3D with a 3080 and the difference is large in basically every title I own.
I remember when the scaling reviews started coming out here on TPU, the ~50 game CPU head to heads with a 4090, I had the distinct feeling a 4090 would continue to stretch it's legs with yet unannounced CPU's, and I still believe that's the case today, even with a 9800X3D.
A 5090 will probably be CPU bottlenecked even at 1440p and 4k at launch compared to what it will be able to do in the years that come with newer gen CPU's.
3,441 (1.16/day)
Processor 9800X3D
Software win11
I remember when the scaling reviews started coming out here on TPU, the ~50 game CPU head to heads with a 4090, I had the distinct feeling a 4090 would continue to stretch it's legs with yet announced CPU's, and I still believe that's the case today, even with a 9800X3D.
Yep, all we got is a measly 10% improvement with CPUs for the past 2 year (7800X3D to 9800X3D), it's kinda sad that Intel fell into new low every year.
Another case in point is using Ray Tracing will further increase the CPU bottlenecking, there is no escaping from upgrading your CPU if you want to play latest games these days (unless we rely on frames interpolation techniques)
159 (0.19/day)
too close to Russian borders
System Name Phat Cat
Processor Ryzen 7 5700x3d
Motherboard MSI B550 Pro
Cooling ID Cooling SE-224XT with 120mm Noctua, 2x200mm Noctua front, 2x140 Noctua back and inside
Memory 32GB Kingston Fury 3200mhz CL16
Video Card(s) Asus RTX 3070 TUF OC
Storage Kingston NV2 256GB boot + Kingston NV2 2 TB storage
Display(s) Dell G3223D
Case Thermaltake Commander C32
Audio Device(s) Audigy 5/RX for optical SPDIF out to Audigy 2 Bay + Sennheiser HD569
Power Supply Thermaltake Toughpower GF1-750W
Software Windoze 11
I have noticed the same FPS increase for any CPU launch since the 4090 day one review. With each newer CPU the 4090 just keep on giving.
2,233 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
i wonder where the real problem is...
- badly optimized game?
- dlss/xess/fsr to boost fps?
- games not utilizing cpu cores?
- game engine simply too demanding (UE5)
- limited performance cores 8 Cores...
996 (0.59/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
Then use something the enable mGPU like Chernobylite
It has RT & can run two RTX 4090's in mGPU with the newest update to the game & Nvidia 566 drivers.
4K ultra settings with no need for D.L.S.S./F.S.R/X.e.S.S
You'll definitely be CPU bottlenecked then, on that game.
10,821 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
The last two gens of GPUs we've had 40-60% increases in performance in games, where as the last two gens of CPUs you basically can barely tell them apart.
back of napkin math:
1.0x 1.8x -> 1.2x -> 1.4 -> 1.6 -> Total: 4.83x faster
980ti-> 1080ti -> 2080ti ->3090 -> 4090 ->
1.0x -> 1.2x -> 1.25 -> 1.3 -> 1.25 -> total 2.43x faster if amd 1.95x if intel, due to arrow lake regression.
skylake -> coffee lake-> alder lake/Z3 x3d -> z4 x3d -> zen5 x3d
if the 5090 comes out 50-60% faster than the 4090 again, the 9800x3d will likely be a substantial bottleneck unless you go nuts on the pathtracing.
