- Oct 9, 2007
- 47,023 (7.60/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Here is the first GPU-Z screenshot of a Radeon HD 7950 graphics card. Although put into a screenshot with ASUS GPU Tweak tool and Republic of Gamers-themed GPU-Z, the card doesn't appear to be an ASUS-made one, and is more likely HIS or PowerColor. The device ID checks out with the one HD 7950 has been associated with. Most other features match expectations. The HD 7950 is carved out of the 28 nm "Tahiti" GPU, with 28 GCN compute units (CUs) active, totaling 1,792 stream processors and 112 TMUs. The ROP count is untouched at 32, so is the memory, that's 3 GB GDDR5 across a 384-bit wide memory interface. With a memory clock of 5.00 GHz effective, it's churning out 240 GB/s of memory bandwidth. It's just the core clock speed where we weren't on target (from the previously-expected 800 MHz), either 880 MHz is the reference core clock speed of HD 7950, or this particular card is a factory-OC variant (PowerColor HD 7950 PCS?).
