Radeon R9 Nano BIOS flashing tools not working
3x0
988 (1.13/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
Hi, I have a R9 Nano that has a problematic primary BIOS- when it's selected the card is very unstable even on desktop. When I switch to the secondary BIOS the card is working properly.
The primary BIOS version is the UEFI compliant version 015.049.000.012.006449 (read by GPUz) https://www.techpowerup.com/vgabios/183161/amd-r9nano-4096-160212
The secondary, working BIOS is 015.049.000.008.006197 (non-UEFI)
I'd like to flash the primary BIOS with a working one, but every version of AtiFlash/AtiWinFlash/AMDVBFlash either don't run or don't recognize the card. I can't even read any of the two BIOSes. I'm running Windows 10 64bit with 22.6.1 drivers.
Does anyone know which BIOS flasher version to use?
INSTG8R
Vanguard Beta Tester
8,129 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
I had a Fury that I flashed to a full Fury X but I did that by modifying the original BIOS. If I recall correctly they won’t flash to another BIOS they had some sort of write protection/hash key. Now this was obviously years ago now so I will tag the only man I trust that would know bette. I’m retired @eidairaman1 hopefully I’m wrong here and you m know how to help.
  • Like
Reactions: 3x0
3x0
988 (1.13/day)
I've tried some more versions and amdvbflash_win_3.31 works without issues. Unfortunately the BIOS chip itself seems faulty:
-reflashed the UEFI compliant version 015.049.000.008.006197, the problems persisted but it would crash less often
-flashed an older version, crashes still there but at least I could run 3D load for a few seconds
-flashed the BIOS that I've saved from the second slot- the card was stable completely, at least for 5 minutes under load
-flashed the UEFI compliant version 015.049.000.008.006197 again, the card seems to be working, currently testing
So it seems the chip itself it "rotten", and needed a few program/erase cycles to work again. Now I don't know whether I should trust it or just flip to the secondary BIOS permanently.
43,833 (6.79/day)
Boot up on working bios, flip switch to non working bios,
Install the driver from latest version of amdvbflash which should disable write protection, attempt to use 2.93 or 2.93+
Otherwise might need to do the 1+8 or 1+5 pin shorting method. Or get a spi flasher.
Continue to test, if it stops flip to other side, who knows might need to secure another firmware chip
@3x0 here is additional guidance
