AquaAngel
- Feb 24, 2024
- 12 (0.04/day)
- Vancouver island, Canada
Good day there, hope you guys are well?
I just got a Radeon VII from Ebay knowing that it was defecting. Sadly enough, the seller also bought it used before selling it. so i have no history about the card, but i would love to revive it if it is possible.
I took the card apart last night and there was some corrosion on the support bracket and the heat shield.
I have checked the coils and the power and i get about .8 volt on all coils except 2 that gives me a reading of 1.1 volt "the 2 at the bottom right, on the Plug side of it, not the bracket", but i doubt that would trigger a 0 Clock freq on GPU/memory/boost
i was able to reflash the Vbios as before, i had no UEFI enabled, temp was at 550deg C, no fan rpm. After flashing it? i was able to get the UEFI, rpm is now working and so as the Core temperature. all 3 fans are working.
Even after all of this? i still have no frequencies to the GPU, Vram and Boost.
I have tried different video cables and different port and of course, no signal output
Is there by any chance a way to bring that card back to life?
here is some pics.
Thank you all for your help
here is some pics.
