- Oct 9, 2007
- 47,074 (7.59/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Announcing the Raijintek Aeneas case, loaded with an array of features. The case is developed with superb airflow in mind, combined with a great intake and outtake giving all of the components great ventilation. The Raijintek Aeneas is a sturdy case presented with a clean, elegant design displaying an eye-catching blue LED bar running along the front and the top of the case; which can be switched on/off.
A huge range of possibilities with cooling in this case is an enthusiast's dream, supporting a maximum of eight fans including a 200mm optional fan space at the front of the case. The case is pre-installed with two 120mm fans on the front of the case, however there are further options of four 120mm fans can be fitted, also a 200mm fan, or a 240mm radiator. At the rear of the case two 140mm fans are pre-installed. With the top cooling options allowing you to fit a further two 240mm fans or a 280mm radiator.
The case has superior features, such as a removable motherboard tray for easy installation, the max CPU height is up to 180mm, and the case can support full length graphic cards up to 310mm.
The case allows for a high class watercooled system to be assembled inside, with options of having a side-window to show off your hardware. The Aeneas is also available in two colours, black and white.
Aeneas Features:
Aeneas Features:
- Elegant LED light bar design (on/off switch)
- User Friendly design - removable M/B frame and tool-free screws
- Classic design with efficient and mass airflow
- Complete black coated interior
- Dust-control filters for all mesh area
- Sturdy and reliable chassis body Chassis body: 0.8mm SGCC
- Accommodate an internal 240mm radiator at front ; an 280mm radiator at top
- Powerful fan systems pre-installed: two 140mm at rear; two 120mm at front
- Supports to up to eight fan installation; 200mm fan option at front
- Supports to install four 3.5"HDD (or four 2.5" HDD) and five 2.5" HDD (optional cage)
- Fully supports Tool-free for ODDs & HDDs
- Two high speed USB3.0 and two USB2.0
- Supports VGA card up to 310mm
- Support CPU cooler height up to 180mm
