Raijintek Refreshes the Pallas CPU Cooler with RGB LED Lighting and More
46,892 (7.62/day)
Raijintek today introduced the Pallas 120 RGB, a refresh of the original Pallas from 2014. Raijintek has made four key changes to its design. To begin with, the mirror finish nickel-plated copper base from the original has been replaced with a direct-touch base, where the cooler's six 6 mm-thick copper heat pipes make direct contact with the CPU. The second big change is the black coated aluminium fin-stack and heat-pipes, which offer a matte appearance. Thirdly, the change reflecting the namesake - the fan featuring RGB LED illumination using 10 diodes (4-pin standard RGB header); and lastly, support for newer sockets AM4 and LGA2066, in addition to LGA115x and AM3+.
The C-type heatsink offers a height of just 68 mm, making it perfect for low-profile builds, provided you can find room around the CPU socket for the cooler's vast width and depth. Measuring 130 mm x 146.8 mm x 68 mm (WxDxH), it weighs 550 g, including the fan. The fan specs are mostly unchanged from the original. Drawing power from a 4-pin PWM header, and featuring a hydraulic bearing, it spins between 200 to 1,400 RPM, pushing up to 41.71 CFM of air, with a maximum noise output of 28.43 dBA. The company didn't reveal pricing.
3,881 (0.86/day)
Aside from the fan being poor. I like the look of it in all black.
21,726 (6.00/day)
Mouse XTRFY M42
I've always been a sucker for this one, for some reason. Fixes your fan issue too :D The height does kinda defeat the purpose for most cases though..
627 (0.15/day)
Nice but that Raijintek sticker on the fan is way too loud, in your face branding, It'd be the first thing to go if I got one of these.
5,918 (1.50/day)
Over here, right where you can't see me !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
y.
A.
w.
N......
6,701 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Big Typhoon reminds me of.
703 (0.28/day)
France
Processor RYZEN 7 5800X3D
Motherboard Aorus B-550I Pro AX
Cooling HEATKILLER IV PRO , EKWB Vector FTW3 3080/3090 , Barrow res + Xylem DDC 4.2, SE 240 + Dabel 20b 240
Memory Viper Steel 4000 PVS416G400C6K
Video Card(s) EVGA 3080Ti FTW3
Storage XPG SX8200 Pro 512 GB NVMe + Samsung 980 1TB
Display(s) Dell S2721DGF
Case NR 200
Power Supply CORSAIR SF750
Mouse Logitech G PRO
Keyboard Meletrix Zoom 75 GT Silver
Software Windows 11 22H2
Would be nice to see how it compares to L12S .
590 (0.25/day)
I been liking these style coolers and having the fan blow down and across the m-board to keep a breeze on it . heck I use a cheap coolermaster vortex + with good results . [amd and intel use]
I just wish they would show the cooler mounted on a board to see any clearance issues like memory slot overhang or what ever to be noticed ...
like the guy above said I do like that blackened look as well...
