RAM not working on it's max potential
240 (0.64/day)
Bulgaria
System Name Mid-Range
Motherboard ASUS TUF Gaming B550 Plus WiFi II
Cooling AiO LS 520 White edition(MX-6 thermal paste applied)
Memory 2x16GB DDR4 3600Mhz CL18 Corsair Vengeance RGB PRO SL
Video Card(s) RX 7700 XT ASRock Steel Legend 12GB
Storage Kingston FURY Renegade 2TB /TeamGroup Cardea A440 1TB
Display(s) MSI G272QPF 27 inch 2560x1440p 170hz + Technika 1080p 24'' 60hz
Case NZXT H6 Flow ARGB + 2x140mm Lian Li Uni infinity mirror
Audio Device(s) RGB Kogaion Speakers/Naraka bladepoint MR720 headset
Power Supply EVGA Supernova G2 650Watts 80 plus Gold
Mouse A4 Tech Bloody Naraka W95 MAX
Keyboard A4 Tech Bloody Naraka S98 Mechanical
VR HMD no
Software Windows 10 Home SL
2x16 GB Corsair Vengeance RGB PRO SL CL18-22-22-22-43
When I overclock it with D.C.O.P profile - PC crash
When I overclock it manually with 3600mhz +1.3500v - it works but on CL26-big number-big number-big number-
When I set it to 1.29500v with 3533mhz it works on CL-18
Same for 3400mhz with 1.29500v - it works.
Whenever I OC it to more than 1.2950v with the designed CL speeds no matter the Mhz it crash.
Am I doing something wrong ? The ram is rated for 3600mhz CL-18 at 1.35v , at least thats what it says on the sticker. It's couple of months since purchase and never bothered with overclocking it, but days ago I noticed that it is working on CL26. and started getting interested why is that
I need to take the most out of it juice because I heard that 5800X3D loves higher mhz
1,812 (0.33/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
This phenomena is called "The Vengeance"
But seriously, download Zen Timings and give a screenshot of that so everyone can see what all you have borked up thus far.
240 (0.64/day)
Bulgaria
VR HMD no
I really don't understand what these numbers and letters mean , but here it is :
2,900 (6.40/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
That… is literally the opposite of the truth though? Zen likes (and always did) lower timings. And even then, the X3D chips are less sensitive to memory than their regular counterparts due to their massive cache.
240 (0.64/day)
Bulgaria
VR HMD no
I am getting more and more confused now :D What should I aim for? Doesn't my ram needs to be running at it's described speed without any problem ?
ir_cow
4,776 (0.79/day)
USA
This is odd, you have a 3600CL18 kit and its running at 3534 CL20? Something is seriously wrong. Idk how you even get that number.... Reset BIOS and try again.
2,900 (6.40/day)
@hermesa
3600 with CL18 can be a crapshoot on Zen 3 and entirely depends on having a good sample. Some can do even CL14. Some are absolute golden samples and can go even further. Some will shit the bed. 3200 with decent primary timings is usually recommended as a “sweet spot”.
But yeah, as @ir_cow says, what your ZT screenshot shows is abnormal. Unless that’s your manual settings?
1,812 (0.33/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Display(s) MAG401QR
Case QUBE 500
Software 11 Pro
I'm guessing this is some low grade Micron E-die. First CLEAR CMOS. Then you'll need to set these parameters manually in the BIOS. Set DRAM Voltage to 1.35v, RAM Frequency to 1600MHz (3200MT/s). Primary timings to 16-20-20-20. F10, and enjoy your computer.
240 (0.64/day)
Bulgaria
VR HMD no
@hermesa
I tried settings them manual now , previous screenshot was also manual but forgot to set manual timings.I am not really into this and I am scared to touch them :D
2,900 (6.40/day)
@hermesa
You aren’t going to brick anything. Just follow the instructions @damric provided above and you should be good.
240 (0.64/day)
Bulgaria
VR HMD no
So I set FCLK to 1600mhz and RAM to 3200mhz, + 1.35v and timings to 16-20-20-20 , but what about the tRC ?
1,812 (0.33/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Display(s) MAG401QR
Case QUBE 500
Software 11 Pro
auto for now. You want it to work without crash.
11,025 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
This 100%. Those ICs and that AMD IMCs are not friends. My kid would work and randomly restart every 3 days on the R5 3600.
bug
14,116 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
RAM would. The trick is the CPU and motherboard which support non-JEDEC speeds in overclocking mode (i.e. it will or will not work, at random).
240 (0.64/day)
Bulgaria
VR HMD no
These settings didn't worked too... I couldn't even boot. Now it's on AUTO voltage with 3200mhz and 1600 FCLK and 18-22-22-22-42 timings. I thing I will set it to 3466mhz 1.29500v as it was the last couple of days.It never did any problem but I also don't want to use it on CL26
1,812 (0.33/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Display(s) MAG401QR
Case QUBE 500
Software 11 Pro
Those timings are fine if it works. The X3D CPUs are much less sensitive to RAM anyway.
I've had some very bad Micron E, but also some very good Micron E. Same with Samsung B die and Hynix. However I'm yet to see a Vengeance kit work correctly out of the box on AM4.
