ram wont post with manual timings & what type of chips is it?
120 (0.06/day)
Sacrum Imperium Romanum Nationis Germaniae
Processor AMD Ryzen 7 5700X VMR-B2
Motherboard Gigabyte X570 UD rev 1.0 F37
Cooling LC-CC-120
Memory 32GB Dual-Rank DDR4 @ 3600MHz (16-19-19-42-46-630) (IRP3600D4V64L18/16G)
Video Card(s) ZOTAC GeForce RTX 2080 Ti AMP/Triple Fan
Storage 2TB Intenso SSD, CT500MX500SSD1, ST2000DM008-2FR102, ST2000DM001-1CH164, WDC WDS100T2B0C-00PXH0
Display(s) HP 32 (HPN351A) & S24D300
Case CHIEFTEC CS-601 / OPT. DRIVE HL-DT-ST BD-RE BH16NS55
Power Supply BE QUIET STRAIGHT POWER 10 800W CM (EC10-CM-800W)
Mouse SHARKOON SHARK FORCE 2
Keyboard CHERRY KC 1000
Software Windows 10 Pro 64-bit Version 10.0.19045 Build 19045
Benchmark Scores https://www.3dmark.com/3dm/97100035?
recently i acquired these modules (goodram IRDM PRO CRIMSON WHITE DIMM Kit 32GB, DDR4-3600, CL18-22-22, retail (IRP-C3600D4V64L18/32GDC)) as an upgrade from 2x8gb 16gb single rank to 2x16gb 32gb dual rank.
now i wanted to tune the memory manually with ryzen dram calc in the bios as i used to with many other sticks before but this time i would be unable to get the ram to boot whatever i tried and i dont know why.
ive heard before dual rank are worse to tune than single rank but these wont work at all.
as far as i understand these modules have hynix chips but which ones (mfr, afr, cjr, djr) i cant clearly tell.
first i went into thaiphoon burner and extracted the complete html record with timings in nanoseconds and loaded it into ryzen dram calc which is also attached in the thread (complete html reports with clock cycles, nanoseconds and zen timings debug report).
calculated a manual safe profile with hynix cjr @ 3600 and entered it into the bios but the the pc wouldnt post and reset the bios.
ive tried several different profiles with several different speeds and modules for fast and safe but nothing would work, what i didnt try was tcke 0 or higher trfc values.
usually i could run all the sticks i got previously with either 3200 cl14 or 3600 cl16 but these wont work at all.
it almost feels like the manufacturer is prohibiting manual timings completely yet the ram boots in default of course even without an xmp profile.
what ive also noticed is that the xmp profile in this module but also others contains "false information" - that is theres information in the xmp profile that does not get actually applied but instead seemingly other random values are entered.
for example, in this xmp profile trfc1, trfc2 and trfc4 show 350, 260 and 160ns, but in reality the actual readout with zen timings / ryzen master shows values of 630, 468 and 288.
second the trc value deviates too, xmp profile says 64 but actual value is 84.
further i noticed that with this ram tcke has value of 0 yet ryzen dram calc always gives me a 1.
so some values are taken from the xmp profile while other values seem to be taken randomly or from somewhere else.
does anyone have an idea how i can get this to work with tuned timings? any suggestions on manual timings / settings?
  • tpu.rar
783 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
Try manually setting the vdimm to 1.4v as you play with the settings. Manually set the primary timings to their XMP values and increase the memory clock to 1833/3667 and the fabric clock to 1833.
Leave everything else on auto.
I have Hynix DDR4-3600 CL16 running at 3733 with otherwise similar settings.
966 (0.43/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
This review by Kitguru maybe be useful.
I recommend you search the net with your model number and find similar articles that do overclocking.
783 (0.11/day)
GA, USA
System Name Gamer
3,368 (1.70/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Yikes 1.45vdimm! I mean, okay 1.45vdimm is actually fine. :)
LOL my MSI motherboard manual says "Based on processor specification, the Memory DIMM voltage below 1.35V is suggested to protect the processor."
120 (0.06/day)
Cooling LC-CC-120
thank you guys very much for your replies. got it to working with the timings from kitguru @ 1,4v.
