Rate My Build (Plan)
419 (0.21/day)
Processor R5 5600X
Memory 32 GB 3600 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Phanteks P300A
Software Manjaro Linux, W10 if I have to
Hello,
I made a plan for an upcoming build. Please offer any suggestions or critiques you have.
Mobo: MSI MPG B550I GAMING EDGE WIFI; they're offering a rebate currently -> 145 €
CPU: Ryzen 5900X or 5700X, depending on the reviews & pricing 300-500 €
RAM: 32 GB 3600 MT/s; Corsair Vengeance looks like good value 160 €
GPU: Probably the cheapest 6000 series with 12 GB RAM, depending on reviews 400 €?
NVMe: 2x 1 TB in RAID-0 125 € (already have one drive) (note mobo must have 2x NVMe slot)
[Storage: 6 TB HDD 150 € (probably will buy this later)]
Case: NZXT H210 99 €; just the right size IMO; I don't need the smart device from the i model
Watercooling:
Eisblock XPX CPU block
Probably Alphacool for the GPU as well
Alphacool Laing DDC 310 pump
Eisbecher 150 mm reservoir
NexXxoS XT45 Full Copper 240 mm "front" rad
NexXxoS ST30 Full Copper 120 mm "bottom" rad
Alphacool or Noctua fans
500 € for cooling
Budget target:
1500 €, max. 2000 €, in Finland
Use case: Work and gaming. Matlab, FEM modelling, VMs & newest games at 1440p 144 Hz
Already have: 1x 1 TB NVMe, 850 W PSU (requires 210 mm space)
Other boundary conditions: Case must be sub 30 litres. Case must support at least 3x 120 mm radiators in any configuration, e.g. the H210 supports 240 mm front + 120 mm rear. One other case I found was Jonsbo C3 Plus, however it looks very airflow constrained in the front. I'm a bit worried it would starve the rad for air. On the plus side, it would support a µATX board while being sub 30 l.
Thanks!
1,001 (0.59/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
I don't like the two Nvme setup on that board one is from the chipset the other is from the cpu it self.
you might be better off with an add in Nvme card for raid being directly connected to cpu.
you would end up running the video card 8x on pcie 4.0 should be fine.
INSTG8R
Vanguard Beta Tester
8,081 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
I agree with the RAID setup as well.
812 (0.41/day)
Processor Intel i9 13900KS Allcore @ 5.8
Motherboard z790 Apex
Cooling LT720 360mm + Phanteks T30
Memory 32GB @8000MT/s CL36
Video Card(s) RTX 4090
Storage 990 PRO 4TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Prime Ultra Titanium 1000w
Mouse G502 X Plus
Keyboard K95 Platinum
Pretty sure every am4 mobo has only 1 nvme CPU slot.
The problem is b550 doesnt do chipset 4.0 so you're limiting your self to 3.0 which is very much on its way out with most manufacturers having 4.0 solutions out right now or about to.
I would switch to an x570 tomahawk @ 200euros instead.
Corsair kits tend to not play well with a lot of zen2 am4 boards also, at the very least if youre expecting to just toggle XMP and forget. I would go for Patriot with budget in mind or Gskill if you're willing to spend a bit little more.
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
Why does it matter if one slot is on the chipset and another on the CPU?
I'm not worried about PCIE speeds for the NVMe or GPU, it will not bottleneck the system.
What is the advantage of the X570 Tomahawk? Actually that seems to be full ATX and won't fit in the case.
Thanks for the memory suggestion, I will look at Patriot. I think the Vengeance kit was on the MSI QVL though.
812 (0.41/day)
Storage 990 PRO 4TB
Mouse G502 X Plus
Oh didn't notice you were talking about SFF, still i would stick to x570 tho im not sure what the options are as i never even entrtained the thought so im not familiar with what's out there.
The difference is b550 only does 4.0 via CPU lanes (1st nvme, and x16 gpu slot only) and x570 does 4.0 on every slot on the board.
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
I think it's been proven that PCIE3.0 x16 and even x8 does not bottleneck current systems. Therefore I'm not keen on paying extra for PCIE 4.0.
bug
13,844 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
I think RAID0 for SSD is pointless, just like 16GB VRAM.
You may also want to look at AsRock mobos (no idea how they are priced where you buy).
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
Why pointless? 2x 1 TB is cheaper than 1x 2 TB, especially when I already own one 1 TB drive.
bug
13,844 (3.95/day)
Because it improves performance in a limited number of scenarios, while ensuring if a drive craps out, you lose the data on both of them.
And if you really need the slightly faster sequential speeds, you can get those by letting one drive run at PCIe 4 speeds.
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
I'm not doing it for speed, but for capacity. If I get any speed benefits that's a bonus.
Looking at the RAM options, we have e.g.
G.Skill 32GB (2 x 16GB) Ripjaws V 151 €
G.Skill 32GB (2 x 16GB) Sniper X 158 €
G.Skill 32GB (2 x 16GB) Trident Z Neo 180 €
No Patriot at my favourite store.
bug
13,844 (3.95/day)
What's the problem with running independent drives? Your sig says you're mostly running Linux, you can mount independent drives however you like. I always mount at least /home separately so I can reinstall without losing data.
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
Well yeah but mounting root on a 1 TB drive is a waste lol
22,722 (6.05/day)
Bit of a fantasy build, half the parts ain't even out yet.
And this matters because it won't be the first Ryzen gen coming up that warrants the use of specific boards for optimal performance, or specific RAM.
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
Great point but as an engineer I do like to make plans ;)
1,001 (0.59/day)
Display(s) HP X24i
There is only one Mirco ATX The Asrock X570M pro 4 mirco-atx board. Seems pretty nice if he's willing to compromise a little bit.
I would buy a separate NVMe add in card, which will add to the cost. Might be able to still close to that case size maybe in a cube like one.
bug
13,844 (3.95/day)
Why? You don't have to mount the whole TB, you can split that up over two or more partitions.
1,092 (0.20/day)
Essex, England
Processor Ryzen 5900X OC 5150Mhz
Motherboard Asus ROG Crosshair VIII Formula
Cooling Custom EKWB for CPU, VRM's & GPU with 2x 480mm Rads
Memory Gskill TridentZ 3600 Mhz C17
Video Card(s) Powercolor RX 6900XT Liquid Devil Ultimate
Storage Samsung 970 Evo Plus 2TB x 2 Raid0
Display(s) MSI Optix MAG272CQR 27 1440p x2
Case Corsair 1000D
Audio Device(s) onboard 7.1 HD Audio
Power Supply Seasonic PRIME Ultra 1300w PSU
Mouse Logitech G300s
Keyboard Logitech G19s
Software Windows 10 64Bit
Benchmark Scores R20 : 9329 Timespy: 21455
TBH I raid0 both of my NVME drives for the same reason.
I created a 4TB Raid, partitioned off 250GB for OS only, then the other 3750GB for program installs as one lump of storage. makes life so much easier and fun,
However, I run a X570 board so the 4x PCI lanes between the chipset and CPU provide enough bandwidth to cover the NVME on the chipset and other devices.
@FinneousPJ you may (and could) in certain circumstances bottleneck with PCIe 3.0
The Chipset to the CPU has 4x PCIe lanes at 3.0 this is 3940MB of bandwidth. That's enough for one NVME drive but you also have everything else running through it, your NIC, USB, SATA. SO yes... with all the devices, under some situations could cause a bottleneck. ie moving from NIC to NVME or from NVME to SATA drives. any situation causing both drives to spin up could cause it to slow down.
Whereas if you had PCI 4.0 the link speed between the chipset and the CPU would be double the 3940MB of speed, giving you overhead for other chipset based devices.
bug
13,844 (3.95/day)
Only if you don't know how to manage drives. Linux is very flexible about this and even Windows has learned junction points for some time already.
I mean, sure, i understand it's nice to lump the drives together. But only until one of them craps out you you lose the data on both. You can mitigate that with backups, but not everybody does that and backups mean additional costs/drives anyway.
1,092 (0.20/day)
Essex, England
Case Corsair 1000D
Well for me, it was the fact 4TB of NVME/SSD storage were not easily available. I know perfectly well how to manage drives and have used JP's in the past but honestly, Raid is a perfectly legitimate way for setting up storage, Hell we're still using it often enough in our corporate environments lol.
Raid provides a nice clean and easy to manage storage. Also, no offence, if people aren't backing up data from RAID (like you mentioned) what makes you think they'd know how to use NTFS Junction Points
If people don't have backups of data... well that's their problem. I use Raid0 because I don't need redundancy on the drives. I have no sympathy for someone who uses RAID and then moans if it fails or needs rebuilding.
bug
13,844 (3.95/day)
Well, the thing is many people use RAID0 simply because they on the internet that read it's faster. And they don't know anything else.
Like you said, RAID0 is only a convenience when it comes to SSDs. So I'd never go for that setup. I'm just trying to make sure those who, understand the risks and that there's no speed to be gained.
1,092 (0.20/day)
Essex, England
Case Corsair 1000D
Aye NVME there are next to none real world performance increases of RAID. Sure benchmarks give bigger numbers but nothing uses those speeds, except maybe moving files.
bug
13,844 (3.95/day)
Even then, you'd have to be moving them from/to something equally fast.
MxPhenom 216
ASIC Engineer
13,013 (2.49/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
Why a B550 board? Why not X570 or whatever X tier chipset comes with the new CPUs? Since you are already looking at things that arent available yet.
bug
13,844 (3.95/day)
I don't think there are new chipsets incoming. What would you add to X570 anyway? I think he picked B550 because he wants miniITX.
