Razer Intros Ripsaw X, a Low-latency Camera Capture Dongle
47,293 (7.53/day)
Razer over the weekend introduced the Ripsaw X, a device the company describes as a low-latency USB capture device for cameras. Intended for those who use DSLRs, GoPros, or professional video cameras that stream live video over HDMI. The device acts like a convenient USB dongle, if you don't want to use internal PCIe capture cards. It supports resolutions of up to 4K UHD at 60 frames per second, or Full HD (1080p) at up to 120 frames per second. It requires a USB 3.x port (5 Gbps), with a single connection handling both power and connectivity. The device is compatible with most popular camera brands, including Canon, Nikon, Sony, GoPro, Panasonic, and FujiFilm. It is largely plug-and-play, with the device fetching its own drivers and software over the Internet once plugged in. It supports most popular software, including OBS. Available now, the Razer Ripsaw X is priced at USD $140.
17,417 (4.69/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
Does Twitch allow 120 FPS 1080p? I don't know what a capture card would be doing allowing 120 fps 1080p, I thought most sites if not all limit you to 60 fps?
1,190 (0.22/day)
Republic of Texas
System Name [H]arbringer
Processor 4x 61XX ES @3.5Ghz (48cores)
Motherboard SM GL
Cooling 3x xspc rx360, rx240, 4x DT G34 snipers, D5 pump.
Memory 16x gskill DDR3 1600 cas6 2gb
Video Card(s) blah bigadv folder no gfx needed
Storage 32GB Sammy SSD
Display(s) headless
Case Xigmatek Elysium (whats left of it)
Audio Device(s) yawn
Power Supply Antec 1200w HCP
Software Ubuntu 10.10
Benchmark Scores http://valid.canardpc.com/show_oc.php?id=1780855 http://www.hwbot.org/submission/2158678 http://ww
They limit bitrate not fps, the setting will show 1080p/60 but if you look at the details it will show true framerate.
I find 900p/90hz looks better than 1080p/60hz
Most people watch with chat open, so you don't need to stream at full res.
34 (0.02/day)
Bucharest
I'm not sure most people can watch 120fps@1080p due to their internet connectivity.
5,569 (0.96/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
see it more like filming with a RED camera, you get crap quality on the other end because it requires post work but gives you the full information to work with.
even if youcannot stream 120fps, there might be value in having it recorded at that rate or even scaled down from to 60 for streaming.
other then that, I wonder who is the OEM for this.
17,417 (4.69/day)
that makes sense yeah.
1,190 (0.22/day)
Republic of Texas
Motherboard SM GL
Display(s) headless
More likely screen than internet. Bitrate for game streaming for non partners is 6mbps.
silentbogo
5,552 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Yes and no. The answer is complicated. 120FPS can be streamed, but it's not "technicall" supported(lack of integration) and will look like crap given a 6Mbps bitrate cap.
But quite soon they'll implement full AV1 support, which will allow 1440p 120FPS to be streamed with a tiny bandwidth increase (~8Mbps).
Right now only h.264 is supported AFAIK.
1080p@120FPS has identical bandwidth requirements to 4K@30FPS, which has been a thing for awhile now. 30Mbps is attainable for most of the semi-developed world, otherwise 4K TVs would still be a novelty.
7,591 (1.48/day)
RÄ«ga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
The problem is that that it probably is nv12. It is capable capturing RGB only at 1080p30. The core of the device is probably same as on ali capture cards/USB boxes, they support HDR passthrough as a added bonus for console streaming.
1,771 (0.60/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
Not in America, rural areas of America are seriously undeserved, but given how telecoms are basically allowed to have local monopolies, I'm not surprised. My cousin, for example, nlive in a small, rural town in New Hampshire and the only option is DSL at.... 1.5Mbps, that's right, 1500 Kbps, the only other option is Hughesnet satellite, but they have very low data caps. I live maybe an hour away in a more developed area and get 1.2Gbps (1200Mbps) for $50/month...i was getting 800Mbps for $30/month, but would always test out at 950Mbps, so that was a good deal, but since I have a 10GBase-T home network, I figured I might has well go with the 1200Mbps.
50 (0.01/day)
Bad Nenndorf, Germany
Processor AMD Ryzen 7 5800X3D, watercooled
Cooling Custom Watercooling-Loop with 2x 240mm and 1x 120mm Radiators
Memory 4x 8Gb G.Skill Trident Z 3600 MHz
Video Card(s) AMD Radeon RX 7900 XTX MBA
Storage 2x Crucial P1 1TB, 1x Mushkin Reactor 1TB
Display(s) Cooler Master Tempest GP27Q
Case Corsair Obsidian 500D
Power Supply Superflower Leadex Platinum 750W
This true for uncompressed video, with compression things are a little bit more complicated.
Usually the efficiency of the codec will rise with higher resolutions (meaning it can store more information with the same bandwidth). That is because many pixels in the higher resolution image will be identical or similar compared to the lower resolution image, so the codec is possible to encode that additional information with a relatively low bandwidth increase.
The same is true for increasing the framerate. Since video codecs only store the differences between each frame, the bandwidth increase when going from 60 to 120 Hz will be very low in most cases, since the new intermediate images will have almost no new content. Lets say you have images 1 and 2 on 60 Hz. Between image 1 and 2 there is just a little change in content. Now you add an intermediate image 1.5 because you increased the framerate to 120 Hz. This intermediate image will have even less content change and can probably be stored just by referencing to content that is already stored in image 1 and 2, so it requires almost no additional bandwidth.
What I want to say with this: The required bandwidth/bitrate is highly content and codec specific. For an example encoding 4Kp60 content using H.265 will usually need 2x to 3x the bandwidth compared to 1080p60 content to achieve a similar quality per pixel, while the amount of information being stored is actually 4 times higher.
silentbogo
5,552 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
I know the situation. I spent some time stateside, and ISP/cell services are awful, overpriced and have lots of shady aspects to each. But that's the problem of citizens not pressing the issue. Heck, in my super-unstable and underdeveloped motherland govt is already talking about municipal internet and making it a
As I said earlier, twitch only does H264, which is getting very old. Not sure why they've skipped H265, but AV1 support is on the way.
No one in their sane mind will stream uncompressed or even lossless video.
1,302 (1.07/day)
Thailand
System Name Shoebox
Processor 3600x
Motherboard Msi b550m Mortar +WiFi
Cooling Cryorig m9
Memory Crucial Ballistix c16 B-die 2x8gb
Video Card(s) Powercolor rx570 4gb
Storage WD black sn750 256gb (OS), crucial mx500 1tb(storage),Hitatchi ?? 7200rpm 500gb(Temp files)
Display(s) Samsung 65" TU7100
Case Zzaw b3
Audio Device(s) Yamaha rx-v363
Power Supply Corsair sf750
Mouse Logitech g300s
Keyboard Custom Skyloong sk64s
Software Windows 11Pro
I looked at this thought it was a good idea to connect my camera up as a webcam then saw the price..... Turns out I can try something similar for $6
silentbogo
5,552 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Those are generic USB2.0 capture dongles. The most you could get out of it is 1080p30 with bad compression artifacts (assuming it works at all). There is no way around it - even cheap chinese capture cards that can do 1080p60 in shitty quality will cost you no less than $50 due to complexity and component price alone. A more or less functional no-name device - min $100.
For $6 you get what you pay for.
1,302 (1.07/day)
Thailand
System Name Shoebox
Processor 3600x
Cooling Cryorig m9
Case Zzaw b3
Actually the generic capture dongles are $1 this is far superior :roll:
2,567 (2.01/day)
Regardless of how a bit overpriced the razer capture card is, it's still amazing how cheaply you can get a capture card nowadays
5,569 (0.96/day)
Mouse Elecom EX-G
Keyboard Rapoo V700
yet I am of the opinion that it ever was an still is so expensive....all you are doing is recording....its hte other devices that actually produce the content, all this does is record it...actually not evne that, it just converts output so it can be recorded...and we have to pay 130 bucks for that?
2,567 (2.01/day)
That sounds very simple but capturing 6Gbit/s and making sense of each bit is anything but simple, there was a time not that long ago (like 5 years ago) where the best you could get was around 200$ and there were barelly any players in the market (magewell and blackmagic are the cheapest I can remember, other players like Matrox among others also existed but prices start to go up very fast when looking at pro equipment like that)
silentbogo
5,552 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
1) It's not just "converting" the signal. It's decoding the signal and then re-encoding it again. All in near real-time. That's why your typical 1080p capture card has so many ICs in it (decoder, bunch of buffers/tranceivers, USB bridge, dedicated MCU for low-speed stuff like EDID spoofing and comms, plus the usual RAM/ROM/power etc). Just the BOM alone can make up over 50% of the price of such device.
It's not just as simple as take a byte from here and put it there. Lots of processing is involved
2) USB 3.0 isn't cheap(still), especially when it comes to UVC (we'll leave mass storage for another day, another topic). You may see some no-name cards that claim USB3.0 and miraculous specs, but it's just a "fancy" connector with good-ole 2.0 wiring.
