Reallocated Sector Count 05
sectorskills
2 (0.00/day)
I have been having this error since 2014. But only today i decided to check if there were bad sectors. So i used HDD regenerator to check bad sectors .Funny thing before the scan it was 112. After the full scan with no bad sectors it is now 120. The scan did not show any bad sectors. This is a laptop Seagate HDD 5400rpm 500GB. I know that the disk will die soon but when. I was expecting this in 2014. Almost 3 years have gone by. I keep it on almost 12-18 hours a day. Usually for downloads. What caused the deterioration. Normal wear and tear or just manufacturing defect?
Thanks
43,467 (6.76/day)
Get Hitachi/IBM disk fitness Test, check it, to me it maybe dying.
Solaris17
Super Dainty Moderator
27,218 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Impossible to know. All SMART data does is tell you the current health of the drive. It cant tell you if you dropped it out of a plane or pissed on it.
21,707 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
The drive is dying. It's merely remapping sectors in a desperate attempt to save itself. The more strenuous the activity the drive performs, the more likely it's demise will be hastened (as illustrated by your surface scan).
There is no way to "regenerate" remapped sectors safely, they are gone.
6,881 (1.45/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
HDD regenerator is a lie. Trust me I used it.
Bad sectors are typical of seagate drives.
Get a new drive whenever.
Frick
Fishfaced Nincompoop
19,813 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
This. Replace ASAP.
Reallocated sectors are only "fine" (if the drive is backed up very regurarly - which every drive should be anyway - and if it's not very essential) if there are very few of them and they do not increase in numbers no matter what you do, but this is not the case here.
sectorskills
2 (0.00/day)
Thank you all for the reply. That's what I wanted to hear. Basically all my important files are on my external hard drives. If the HDD dies. Oh well. I have an SSD I got recently. Its temperature is 39degree on idle. That is irrelevant I know. I think being 5400rpm has slowed its deterioration rate. My 7200rpm HDD which recently died had the same problem.
34 (0.01/day)
Realocated sectors dont make problems, they are not used anymore.
Curent sector pending shows the ones instable.
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
eidairaman1 pointed out that the manufactures fitness test would be the next move. HD Tune warnings are not always fatal. But likely in this case
Aquinus
Resident Wat-man
13,174 (2.77/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
No but, it does say how many blocks have been marked as bad. I would call 120 a fairly high number. A drive where this value is climbing (not staying stable,) is a sign of failure but, you can only reallocate so many sectors before there are more bad blocks than spare ones. It also means that data could be corrupted if those blocks were actively being used when they got reallocated. Either way, the OP needs to back up the stuff on that disk as a precaution, even if there is an intent to use it until it actually fails.
34 (0.01/day)
its a high number but they dont die from realocated sectors. my old drive its still works for movies , but because of curent pending sectors i had to disable a partition.
12,333 (2.24/day)
Oregon
Lol, that's sketchy. How many hours on that drive?
Kursah
Super Moderator
14,734 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
For unimportant storage that is probably fine to do. Once a drive is reporting reallocated and bad sectors, it's blown through the buffer of them that it had shipped with anyways. Which is a sign of potential danger ahead.
Every hard drive out there has bad sectors, period. It cannot be avoided with these kinds of drives, so they include a buffer to allow reallocated and bad sectors to occur even before the OS becomes aware via SMART reporting. What the board logic reports versus how many there are is actually two very different figures. And odds are you'll never know how many actual bad sectors a drive has, but only what sectors it is telling you about. There's an inherent risk where you might use a drive reporing reallocated or bad sector issues and be fine, others where it had minimal warning and failed in minutes or hours. I've seen plenty of both and everything in between.
Having to "disable a partition" isn't a good answer for a drive that has any kind of data that might have any kind of reliance or importance. But it is definitely a method to continue using the flagged "good" parts of the drive until it gives up the ghost. :)
43,467 (6.76/day)
DFT has been around since IBM Deathstar, pretty good test, can detect and run on most hds too
