Realtek 2.82 official driver with MB2 without haxx.
342 (0.21/day)
19H1 or later:
Otherwise:
Download r2.82
Add your Sound Device Hardware ID to HDXTHXD.inf
AND INSTALL THRU THAT .INF VIA DEVICE MANAGER!
Download & install MB2
Done!
12 (0.00/day)
Not working here, i install and mb2 says not hardware found, even i updated HDXTHXD.inf with my hwid.
12 (0.00/day)
The driver from 19H1 or later link in your first post
8865_FF00_PG474_Win10_19H1_WHQL.zip
Edited \win64\HDXTHXD.inf
Added under
[AzaliaManufacturerID.NTamd64.6.0]
Next line:
"Realtek Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_10199CE9
disabled driver signing and updated driver in device manager choosing \win64\HDXTHXD.inf
then installed mb-2
The driver didnt work.
All this under windows 10 version 1809 compilation 17763.914
Maybe Should i choose r2.82 or update to 1909 windows version?
12 (0.00/day)
thanks but will that file work with windows 10 ?
Inside the .rar i can find a lot of folders with names like
8703_FF00_PG472_Win10_RS3_RS4_RS5_19H1_Win7_WHQL
8703_FF0C_PG472_Win10_RS3_RS4_RS5_19H1_Win7_WHQL
8703_FF01_PG472_Win10_RS3_RS4_RS5_19H1_Win7_WHQL
8703_FF03_PG472_Win10_RS3_RS4_RS5_19H1_Win7_WHQL
8703_FF04_PG472_Win10_RS3_RS4_RS5_19H1_Win7_WHQL
8703_FF06_PG472_Win10_RS3_RS4_RS5_19H1_Win7_WHQL
8703_FF10_PG472_Win10_RS3_RS4_RS5_19H1_Win7_WHQL
Wich one should i choose?
I would like to have x-fi mb 2 in my mobo, but i don't know if it's possible to make it work with windows 10. I tried to make my own edit some time ago and the software started but using it didn't make any change.
Thanks
342 (0.21/day)
Thanks
Dont know. Try F00?
12 (0.00/day)
Thanks with your help i made it work (almost everything) !
I used ff10 driver, added my id and installed. After that i installed x-fi mb 2 from puresoftapps web because the one from this link didn't work fine. I didn't hace access to crystalyzer or other extra features.
After that i put the license keys and it worked.
But i still have a problem with cmss-3d, everytime i try to change the slide bar the creative audio console app crashes.
Is there any other way to change the cmss-3d bar ? in audio control panel that bar is not visible, and i think the surround option in thx trustudio pro app is not the same.
cmss-3d is the main reason why i wanted x-fi mb2.
Thanks!
184 (0.10/day)
I mean what do u expect, MB2 is ancient..made for Windows XP, of course something will crash in modern OS..just use MB3 or MB5, much better @myfreelog
818 (0.38/day)
System Name Dell Inspiron 7375
Processor AMD Ryzen™ 7 2700U Mobile Processor with Radeon™ RX Vega 10 Graphics
Memory 16GB (total) 2400MHz DDR4 SODIMM
Video Card(s) Radeon™ RX Vega 10 Graphics
Storage SanDisk X600 SATA SSD 512GB
Display(s) BOE NV13FHM
Audio Device(s) Realtek ALC3253 (Dell Labelling) ALC255 (Real name)
@myfreelog MB3,MB5 also has CMSS-3D.
You can also try Dolby Surround Upmixer, the one used by Atmos receivers to upscale stereo to Atmos.
12 (0.00/day)
Are you sure mb3 and mb5 hace cmss-3d ? I thought it had sbx-pro instead.
btw wich could be the best solution to add stereo upmix to all 5.1 channels with analog outputs? . I liked a lot how my x-fi xtreme gamer handled this but with the onboard card when i enable speaker fill option i have a lot of echos that ruins all the sound. I only want to replicate front audio to rear audio with independent control of central and subwoofer.
Thanks.
818 (0.38/day)
Thanks.
Sbx pro is (most probably) a relabeling.
818 (0.38/day)
184 (0.10/day)
I made an X-Fi MB3 driver with Realtek UAD > RTK_UAD_MB3 , get the MB3 app from pureappsoft, XMB3-OEM1D-4-11.rar I think...ohh, u also need the GenKga for MB3 license file..u need to activate test sign mode or disable driver sig enforcement before install the driver, follow this sequence of installation RTK MB3 driver > restart > install MB3 app > Genkga license > restart @myfreelog @emanresu
342 (0.21/day)
Is MB5 not preferable @ador250 ?
I wanna get surround from my z5500, and I saw a post yesterday on haxxxing Dolby Atmos and Realtek, but I can't find it no more.
184 (0.10/day)
MB3 and MB5 is same thing, just Ui change..u can literally install the MB5 app on top of that driver and it will work just fine @emanresu
29 (0.02/day)
i added my HWID like myfreelog did and installed the driver via Device Manager. than i downloaded and installed the soundblaster stuff and nothing works. i have now the Sound Blaster Panel in my taskabar, there i can choose between avaible sounddevices (Nvidia/Sonic/Realtek) i choosen Realtek. When i wanna open the THX Studio/ Sound Blaster Console or Musik Server its say all the time ''Device not found''
i installed the 2.82 after editing the HDTXHD.inf with my HWID
can i add my HDMI HWID (Nvidia) also?
438 (0.13/day)
Processor AMD Phenom II X4 925
Motherboard Gigabyte GA-78LMT-USB3 R2
Memory 4 GB DDR3 1333Mhz
Audio Device(s) onboard Realtek ALC892
Power Supply Seasonic S12II 620w (SS-620GB)
Software Windows 10 Education x64 21H2
X-FI MB3 & MB5 are nearly the same thing except MB3 uses different kga license files than MB5.
for MB3 (retail w/ MB3 driver) it's CTLTD2H3X2.kga by itself; for MB3 (OEM w/ host soundcore support) it's CTLT02H0X2.kga by itself.
for MB5 you need only CTLXS2Q3X2.kga. other kga files installed in the Softwarelock folder may interfere with the detection process & may fail to recognize your audio hardware, so don't put too many kga license files in that folder
no sorry, Mircosfot. Nvidia HDMI uses a different audio driver (Nvidia HD audio) which the Creative integration files can't be integrated onto and only integrate with Realtek audio devices. you also did not mention or did not check if you have certain KGA license files installed for the THX TruStudio app (need CTLT99HB0X.kga file specifically for THX Trustudio to work & recognize the onboard Realtek audio hardware)
@ador250: X-FI MB2 requires minimum Windows Vista SP2 or Windows 7 as noted on this PDF file on the Creative OEM web site. MB2 not compatible with XP
438 (0.13/day)
actually XFI MB3 when 1st released in summer 2013 was not fully Win10 compatible until it was updated in mid-2015 to make it Win10 compatible.
MB5 is certified Win10 compliant from RTM to newest Win10 release
BobaBrett
27 (0.01/day)
If you are still looking for somthing in this range, I have been using HeSuVi which has a lot of those DTS HPX, Cmss, Atmos, ect I have UWP Atmos for games that support it. But do you guys prefer the actual HRTF over a program like HeSuVi. So far I prefer hesuvi do to it being easier to stay up to date with driver updates and dont need to do keygens. I have tried almost every program you can find and I always come back to it =x On top of the app having over 20-30 HRTF sound sigs you can also find tuned eq for your headphones in the eq settings even for headsets like HyperX Cloud II - more expensive headphones. Just thought Id share my findings good luck.
184 (0.10/day)
For me it's X-Fi MB5, no matter how many hesuvi/peace config or others apo's I use, always come back to X-Fi MB5..it gives me the best tuning overall.
