Geschnallt
- May 30, 2020
- 2 (0.00/day)
Hi Community,
I was kind of late to switch to Windows 10, however after switching to W10 from W7 I noticed the Acoustic Echo Cancellation is not working that great anymore.
It was pretty much perfect on Windows 7. I am using a Microphone + Speakers.
My Mainboard is a ASROCK Extreme 4 Z370.
I think I kind of found out why, at least there is a easy to spot difference when between the driver on Win10 and W7.
I'm sorry for the German Screenshots but I'll explain. "Nachhallunterdrückung" is the Acoustic Echo Cancellation. Starting from W10 it's also missing the DC-Offset (No Idea what's that for).
And the Acoustic Echo Cancellation is now (v2), this v2 is working way worse for me. Occasionally others hear themselves on Calls. This did not happen on Windows 7.
Interestingly yesterday I took a look at a friends PC, which is way older, it's a GA-X58A-UD5 rev2 with Realtek ALC889. And it's working there on Windows 10 like on 7 for me. No (v2) and the DC Offset is present.
So maybe this "upgrade" is only for newer Realtek Chips?
Using the same Driver Version on Windows 10 as on Windows 7 does also not work, also I can't try a even older driver since those do not Support the ALC1220.
In this forum I found some posts about the Realtek HDA driver test utility. Maybe with this it is possible to set the Older Version of Acoustic Echo Cancellation, or just to switch to some Legacy mode.
Unfortunately I don't really know how to use it or where to start.
So please I need help with this. Thank you very much.
