Recommended Ryezn 7 5700X (non 3D) CPU coolers?
SamSegal
18 (0.20/day)
I'm looking to buy an adequate cooler for the Ryzen 7 5700X.
I don't really have a budget, but I prefer getting a good bang for buck than the lowest possible temps.
In the summer we often get 35 degrees, however I do have AC so that wouldn't be room temp.
The room itself has a window but isn't great on air circulation, so perhaps it's worth getting something on the beefier side (dual fan?).
I'm focused only on air coolers, as my old (2016-ish) Sharkoon case does not support top / bottom radiator (AFAIK).
I don't think I'll be overclocking the CPU, but I might enable Precision Boost Overdrive.
Any recommendations out there? I buy from local retailers or from Amazon.
I've set my eyes on a 2nd hand Thermalright Phantom Spirit 120 Evo, but I'm not sure the buyer is serious.
Update: seems like my case won't fit it (CPU cooler max height: 15.5 cm - vs 15.7 ;_;).
Other specs:
Motherboard: Asus B450
GPU: Asrock Arc A750
RAM: G.Skill Ripjaws V 2x8GB 3200Mhz DDR4 (height for clearance: 42 mm / 1.65 inch).
CASE: Sharkoon Vaya: https://en.sharkoon.com/product/11728
Any tips regarding benchmarks available online will also be appreciated. 1st time heavier CPU cooler fan I'm buying.
Thanks in advance!
2,072 (0.33/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
Maybe it is useful to provide the exact case name since max cooler height depends on that.
28 (1.33/day)
Processor AMD Ryzen 5700X
Motherboard MSI X470
Cooling Assassin King 120
Memory 16GB DDR4
Video Card(s) 6700XT
Storage SK Hynix Platinum
Thermalright assassin/phantom spirit 120 are great air coolers
SamSegal
18 (0.20/day)
6,340 (2.86/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
This is new:
15.5 cm so max your case can technically support
Should cost around €50 and fans alone cost about €30 at retail. Comes with quality fans that can reach 2000 rpm easily but stay silent up to around 50% speed.
You could look for something smaller but:
- it's air cooling, in the end you will still be limited by the room temperature but since you have AC it shouldn't be an issue
- your CPU TDP is 65W so you should be fine anyway,
- you can always apply Curve Optimizer to lower the temps.
When I had 5800X I used Dark Rock 4 (non-pro) and it managed just fine so anything solid with one tower should also serve you well.
