Reeven Arcziel 12 CPU Cooler Pictured
46,892 (7.62/day)
Reeven unveiled the Arcziel 12 CPU cooler. Classified in the large category, the Arcziel 12 is a top-flow air-cooler that uses an aluminum fin stack arranged along the plane of the motherboard, to which heat is conveyed by six 6 mm-thick copper heat pipes that make indirect contact with the CPU over a nickel-plated copper base that's polished to a mirror-finish. The six heat pipes pass through the aluminum fin stack at two points, to even heat distribution. The heatsink is then ventilated by a 120 mm PWM fan that spins at 500 to 1900 RPM, with noise-output of up to 35 dBA. Measuring 140.5 x 131 x 126 mm, the cooler weighs about 557 g. It supports all modern CPU socket types, including LGA2011, LGA115x, AM3+, and FM2. It is slated for November 21.
274 (0.05/day)
Unknown
System Name ASAS
Processor Intel Core i5 2500K @ 4.2 GHz
Motherboard Gigabyte GA-Z68A-D3-B3
Cooling Scythe Ashura
Memory Patriot 2x4GB DDR3 1600MHz 9-9-9-24 T1 @ 1.5V
Video Card(s) MSI GeForce GTX 770 2GB Gaming
Storage Samsung 830 256GB + Samsung Spinpoint T133 HD400LJ 400GB
Display(s) Samsung SyncMaster EX1920
Case Bitfenix Ghost
Audio Device(s) Realtek ALC889
Power Supply Seasonic S12II-620 Bronze 620W
Software Windows 7 Ultimate 64-bit SP1
Those are some weird shaped heatpipes.
6,700 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Looks solidly built. No complaints.
307 (0.06/day)
Processor Ryzen 2700X
Motherboard Asrock X470 Master sli/ac
Cooling Raijintek Themis Evo
Memory Team Dark Pro 3200 cl14
Video Card(s) GTX 1080
Power Supply Seasonic Focus Gold Plus 850W
Top flow and tower cooler combined? Curious about the cooling efficiency.
FreedomEclipse
~Technological Technocrat~
23,722 (3.75/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
I'd stick another 80 or 60mm fan below the cooler (between heatpipes) in a push-pull config.
hard to fit one on unless you use plastic cable ties
2,669 (0.49/day)
System Name Old Gateway / Steam Deck OLED LE
Processor i5 4440 3.1ghz / Jupiter 4c 8t
Motherboard Gateway / Valve
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3 / 16gb DDR5 6400
Video Card(s) RX 560D 4GB / Navi II 8CU
Storage 240gb 2.5 SSD / 1TB nvme
Display(s) Dell @ 1280*1024 75hz / 800p OLED
Case Gateway / Valve LE
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago), Valve
Power Supply 380w oem / 65w valve USB-C
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100 / virtual
VR HMD Lmao
Software Windows 10 / Steam OS
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC. SD LE 45fps
+1 I was thinking the same thing.
Would look good in this... well if it can fit in it anyway.
My friend has one... its a decent case. A similar sized tower type cooler of the same size has some clearance issues with the case and its side fan... we just took off the big fan and used some tin snips on the large side grill in a couple spots... just the tips of the heatpipes were in the way so only a little slot was needed. anyways... I think this cooler would fit without having to do that, maybe still having to take off the side fan.
mediasorcerer
978 (0.21/day)
coast ,melbourne
System Name THE MEDIAMACHINE
Processor i5-3570k
Motherboard Asus gene v z-77 matx.
Cooling Antec h20 620
Memory 2x4gb g.skill ripjaws z 2400
Video Card(s) h.i.s radeon 7950 reference 3 gb- hooray!!!
Storage samsung 128gb~830 ssd. samsung 500gb hdrive.
Display(s) 22 inch tele.
Case circa 1996 grey rat box with no sides front.until my own is finished
Audio Device(s) inbuilt creative.supreme effects 3
Power Supply thermaltake tt-500w
Software win 7 x64-
Benchmark Scores Coming soon
The advantage i can see from this sort of config is the possibility of the fan drawing heat from the components surrounding the cpu as well?
As a previous poster mentioned, pity it doesn't have a fan underneath too.
41,030 (6.56/day)
holy chunky coolers batman!
3,528 (0.69/day)
Netherlands
System Name desktop | Odroid N2+ |
Processor AMD Ryzen 5 3600 | Amlogic S922X |
Motherboard Gigabyte B550M DS3H |Odroid N2+ |
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 case fans | stock heatsink + fan |
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 |
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 |
Storage SK Hynix SSD 240GB, Samsung 840 EVO 250 GB, Toshiba DT01ACA100 1T | Samsung 850 Evo 500GB |
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) |
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack |
Mouse Logitech G500 |Steelseries Rival 300
Keyboard Qpad MK-50 (Cherry MX brown)| Blaze Keyboard
Software Windows 10, Various Linux distros | Gentoo Linux
As it seems it does, like my Triton 75 is doing. It is pushing though, so that means that the exhaust case fan(s) must output a bit more air to avaoid turbulence in the areas you mentioned (like above the CPU power related stuff on the mobo).
1,259 (0.26/day)
Top-flows CPU coolers are very efficient if you have a bottom mount PSU (far from the CPU), and wanna go for a nearly silent setup, because they are gently blowing fresh air to the rest of the motherboard and onto the RAMs as well, and that's a must on hot summer days.
I still have a Big-Typhoon in one of my systems, and I just replaced its fan with a silent 800RPM hydro-dynamic bearing fan, which I run on 0(5)-9V depending on the load. Combined with a silent PSU, a similar almost-passive setup on the GPU, and a Quiet-Drive from Scythe means you simply can't hear a thing from the case, or perhaps only a very little if everything is on full load and you put your ear next to it.
1,843 (0.33/day)
Latvia
Processor 7700X \\ i7-8565U
Cooling Noctua DH-15
Power Supply Corsair AX860i
Keyboard Corsair K55 RGB PRO
+20$ for the yellow cooler.
41,030 (6.56/day)
The Cooler needs to be Taller as of the Pipes, Ram slots are blocked
