- Oct 9, 2007
- 47,128 (7.58/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Reeven today introduced the Naia 240 all-in-one liquid CPU cooler. The cooler is characterized by a clear acrylic pump+block with a small reservoir, which the company refers to as "water above pipe" design. The cooler has two reservoir segments, one at the radiator, and another at the pump-block. The one at the pump-block has a coolant injector port, letting you add coolant colors. The block features white LEDs, which lets the coolant glow through the acrylic top.
The pump-block is plumbed to a 240 mm x 120 mm radiator, which is ventilated by a pair of Reeven ColdWing 12 (120 mm) fans, which spin between 300 to 1,600 RPM, pushing up to 90.28 CFM of air, with a noise output ranging between 6.5 to 30.9 dBA. The block features a dense micro-fin array with 0.11 mm-thick fins. Out of the box, the cooler supports Intel LGA2066/2011(v3), LGA115x, AM4, AM3(+), and FM2(+), but socket TR4 support can be added with an optional retention module purchased separately. The company didn't reveal pricing.
