- Mar 26, 2022
- 143 (0.14/day)
- Ballkans
I know that bare copper GPU/CPU blocks have been a thing for a long time, then they started nickel plating them!
Is there an advantage to nickel plating!?
To my knowledge if a loop has no other metals but copper there should be no need for nickel plating!
The reason I'm asking this is because I have just started to get into water cooling and would like further expand my knowledge about certain things.
Also a big problem about nickel plated copper blocks with transparent acrylic on top is they start to look awful once the plating erodes away which is an undeniable fact that will happen, it's just a matter of when.
Hopefully this wasn't long
Cheers!
![Smile :) :)](https://tpucdn.com/forums/data/assets/smilies/smile-v1.gif)
Cheers!
