Regarding the IceGiant Prosiphon Elite!!
142 (0.14/day)
Ballkans
I have been wondering for a while about the Ice Giant's fans, I mean they resemble Arctic P12s so much.
Maybe they have a deal with Arctic, who knows but what I want to know is the part number and how I can get them because they are rated at 2300 rpm while the normal Arctic P12s are rated at 1800rpm!!
Any help is greatly appreciated!
1,665 (0.31/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
The version I tested had the standard 1800RPM P-fans. You could email them and ask them. They are very nice and personable.
2,729 (0.68/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
I have the numbers from the label on back of my fans for it.
The labels says:
P12PWMCO-2300
Icegiant
DC 12V 0.12A
It's probrably just as easy, if not easier to simply figure out it's size and CFM, then base what you can get on that info.
AsRock
TPU addict
19,105 (2.99/day)
UK\USA
The labels says:
P12PWMCO-2300
Icegiant
DC 12V 0.12A
And what you know there is a P12 PWN CO, just that they don't go 2300PRM.
2,729 (0.68/day)
Alabama
Memory C.R.S.
The info I provided is right from the label of the fans that came with mine.
My Icegiant works fine with just two fans, keeps the chip cool like you'd want it to.
In truth there really isn't a need to go with higher CFM fans for a regular build with it, just use the fans it comes with and it should be able to handle about anything you'd want it to.
The only reason I'm using just two is well.... I'm too lazy to install the other two fans. :D
BTW I've modified the mounting plate on this one so it works with AM3/AM3+ as well meaning it can be used for anything that's AMD from AM2 to AM4, including TR of course since it supports TR as well.
Right now I'm using it with my 1100T and it's loving it.
AsRock
TPU addict
19,105 (2.99/day)
UK\USA
Yeah you said...
Umm ok, i just thought he would like to know that there is a actual PWM CO version too.
Just for the sake of getting info, do you use the original backplate of the mobo?.
2,729 (0.68/day)
Alabama
Memory C.R.S.
Yeah you said...
Yes, I use some screws to mount it with the silver mounting collar and spacers the cooler comes with and it works fine.
In fact the design of it seems like it's intended to be used with the backplate or something similar. If you don't have the screws I refer to, a trip to the hardware store for some takes care of it. The screws have to be the correct length to reach and thread pitch for the backplate - Aside from that it's a snap to install and get working.
BTW I can take a pic of the fans I have, front and back if you want me to post them.
