Remove .repl extension !!!
aadarsh_2000
8 (0.00/day)
Hey All,
This is the first time i am posting any query and i hope i get the solution to my problem.
Can anyone tell me how can i remove .repl extension(Ransomeware Virus)? I can't even open any file , photos, documents, music etc....
Please help !!!
947 (0.17/day)
System Name Desktop
Processor AMD Ryzen 7 5800X3D
Motherboard MAG X570S Torpedo Max
Cooling Corsair H100x
Memory 64GB Corsair CMT64GX4M2C3600C18 @ 3600MHz / 18-19-19-39-1T
Video Card(s) EVGA RTX 3080 Ti FTW3 Ultra
Storage Kingston KC3000 1TB + Kingston KC3000 2TB + Samsung 860 EVO 1TB
Display(s) 32" Dell G3223Q (2160p @ 144Hz)
Case Fractal Meshify 2 Compact
Audio Device(s) ifi Audio ZEN DAC V2 + Focal Radiance / HyperX Solocast
Power Supply Super Flower Leadex V Platinum Pro 1000W
Mouse Razer Viper Ultimate
Keyboard Razer Huntsman V2 Optical (Linear Red)
Software Windows 11 Pro x64
If you're using Windows 10, open Settings, search Default apps, scroll down to Reset to the Microsoft recommended defaults option and hit Reset. Hopefully that helps.
752 (0.44/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
You could try to see if the ransomware is just stupid enough to change the extension or if it's actually encrypted/converted. If you open file explorer, take it to full screen, go to the tab "View", and enable "filetypes" then you'll see extensions and be able to manually change them. Take a file, rename it, change the .repl extension back to whatever filetype it was, or remove it if it's just added on top (example: you had a shortcut that was named "program.lnk", but now it's "program.lnk.repl", just remove the .repl and hit enter and try to open it). If you're able to use the file normally after that, you're lucky. The virus wasn't programmed very well and didn't actually convert the file. If it still doesn't work.. tough luck, really. Your files are gone unless you had a backup or have restores enabled in Windows 10.
18,584 (2.67/day)
System Name AlderLake
DECRYPTION TOOLS
aadarsh_2000
8 (0.00/day)
I did as you said, still i cannot access my files.
I tried doing that as well but no luck.... :(
752 (0.44/day)
System Name Main PC
Case Corsair 1000D
Then they've been converted. Unless you have a backup, I'm afraid they're gone. You should check in Windows 10 if there's a restore available to before the virus.
aadarsh_2000
8 (0.00/day)
There is no restore and i have tried so many things but no sucess so i guess i have lost it then. :(
19,375 (3.52/day)
Reinstall windows from scratch (format drive, reinstall)... but you lose all your files. :(
18,584 (2.67/day)
Did you check the link I posted?
14,202 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I guess Microsoft's Onedrive has it's uses after all.
If you want to keep anything of importance, back it up.
21,640 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
OneDrive is transparent to the filesysem, meaning yeah, it's probably going to get hit if you get ransomware as well.
The best defense against this kind of crap is completely offsite solutions, not convenient filesystem accessible cloud drives.
Frick
Fishfaced Nincompoop
19,778 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
It has a restoration scheme though.
21,640 (3.40/day)
Olympia, WA
System Name Pioneer
