- Dec 16, 2010
- 1,682 (0.32/day)
- State College, PA, US
System Name | My Surround PC |
Processor | AMD Ryzen 9 7950X3D |
Motherboard | ASUS STRIX X670E-F |
Cooling | Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans |
Memory | 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30 |
Video Card(s) | MSI NVIDIA GeForce RTX 4090 Suprim X 24GB |
Storage | WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces |
Display(s) | 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD |
Case | NZXT Source 530 |
Audio Device(s) | Sony MDR-7506 / Logitech Z-5500 5.1 |
Power Supply | Corsair RM1000x 1 kW |
Mouse | Patriot Viper V560 |
Keyboard | Corsair K100 |
VR HMD | HP Reverb G2 |
Software | Windows 11 Pro x64 |
Benchmark Scores | Mellanox ConnectX-3 10 Gb/s Fiber Network Card |
I made a dumb mistake tonight. Have an MSI X299 SLI Plus motherboard. I needed to cut the end of a PCIe x1 so I could put a PCIe x4 card in it. I was using a file, and I slipped and damaged some traces on the PCB. They connect to lanes 1 and 2 of the lowermost x16 slot. If I didn't need the slot, I would just leave it as-is since there is nothing else damaged, but I do need to use that slot and need to repair it.
What would be the best way to repair those traces? I tried making a solder connection but those traces are way smaller than even the tiniest tip I have and the solder just balls up instead of bridging the traces. I was thinking that painting conductive paint on the board might be the best solution since I can scrape off the paint where I don't need it. Is there another method I'm not thinking about?
