repasting my vega 56 ( need thermal pad advice )
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
so i just repasted my vega 56 with Thermal grizly kryonaut extreame after watching a nice website with thermal conductivty numbers..
now im wondering wat thermal pads i should get? hey i need to replace that with something beter to... but i cant find proper reviews with proper thermal conductivty numbers... so im wondering what do you guys recomend??
some pics of my repast job. hell the vega 56 asking for allot
41,962 (6.61/day)
For pad thickness needed, get a feeler gauge and a vernier
753 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
Fujipoly Ultra Extreme thermal pads are supposed to be very good and might be less expensive than Thermal Grizly. You might need more than 1 thickness of pad too. Measure all of them, as some might be 1.0mm & others might be 1.5mm.
5,062 (3.80/day)
Colorado, U.S.A.
Software Windows 11 Home
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
If you have gone with Thermal grizly kryonaut extreme, why not go with pads:
https://www.thermal-grizzly.com/en/products/516-minus-pad-extreme-en
didt had pads at hands. first i wanted to repaste the gpu package cus of thermal throteling.. after i done that. now im noticingthat the VRM's are 98c... some arent even touching the vrm's...
I think you would have been fine using less paste
trust me i needed this allot any les it wouldt boot or overheat straight away... even after googling several forums all in the end allot of thermal paste.. or straight with liqeud metal...
tough it kinda looks messy :p
5,062 (3.80/day)
Colorado, U.S.A.
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
Something is wrong, in my opinion.
yea probaly has something to do with hbm being differend hight than the gpu or my waterblock is off
11,878 (2.22/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Or thermal pad in the wrong place is getting in the way of adequate clamping, literally only the parts EK or whoever, says should have pads and no where else should pad be fitted , EK use 0.5 and 1mm thick pads and obviously if applied the wrong way around with 1mm on a 0.5 spot you can have partial contact with other areas of the cooler, for reference my GPU loaded Never gets above 46°C and the vrms never above 70, sounds like you're pads are dead or put on wrong causing poor clamping pressure on the GPU die hence requiring too much Tim.
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
pads that are now on it ones that came with it
27,518 (6.63/day)
This. Thermal paste is meant to be used sparingly.
@Morgoth You used too much. However, that's not going to hurt anything. When you secured the heatsink to the card, all the excess got squished out the sides of the GPU die. It'll be messy with you want to change it out next(if?), but otherwise no harm done. The TIM you used in the photos is excellent! Carry on.
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
acording to this wat i readed https://www.igorslab.de/en/amd-rade...and-the-right-application-of-waermeleitpaste/ i had to use enough
11,878 (2.22/day)
Manchester uk
VR HMD Oculus rift
Is it a EK or other Water lock, how long was it in system and working fine, did you fit the right pad width to the right part.
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
waterblock is *A-XF56-NANO-X* not sure what brand it is but i got it from aliexpres.. there werent any others avaible
pads that came with it is some unknow brand that i dont know of just generic stuff comes with it
hell even half the screws that came with it didt fit so i bought my own screws and reused screws from the air cooler...
i got it almost a year now. it just recently that it started to act up. had a HOTSPOT temp issue was hard to fight with now my Voltage regulators are high up..
i even readed some where that the hotspot temp is not even a real sensor
32 (0.04/day)
ACCESS DENIED
System Name Who tf is playing megalovania over the mic?
Processor Ryzen 7 5700x
Motherboard ASUS ROG STRIX X570-E GAMING
Cooling Noctua NH-U12S REDUX
Memory 32Gb Corsair vengeance LPX 3200MHz CL16
Video Card(s) MSI RTX 2070S GAMING X
Storage Samsung 980 PRO 2TB
Display(s) ASUS TUF Gaming VG27AQ
Case NZXT H710
Audio Device(s) Logitech G PRO
Power Supply Seasonic PRIME Ultra 650 platinum
Mouse Logitech G604 / G pro wireless (modded)
Keyboard Corsair K70 RGB MK.2 (cherry MX silent) (tape/foam mod)
Benchmark Scores The hell is a benchmark?
Well, If you don't already have thermal grizzly pads, you could try Thermalright one enjoy thermal pads (saw a lot of miners using this one).
I guess, it shouldn't be a problem, try some K5-PRO.
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
so after some more searching i found "Kritical extreame thermalpads" it got 20 w/m-k i think i go with that got the highest rating of all the thermal pads that i found that ist grapphite or carbon based
tough kinda sad that grapphite bads dont com in 2mm only in 0.2
2,207 (0.80/day)
Whatever pads you go for make sure it's not conductive when replacing pads across the MOSFETS, you don't want to short that out. I use Fujipoly on my Vega Nano 17W m/k.
Never heard of the ones you posted until today. Need to read PDF Docs on this (if any).
EDIT: Where is main company website? ....EDIT Found it, sorry I don't trust what they are saying.
171 (0.03/day)
The pads the manufactures use on graphics cards tend to be high quality, I wouldn't bother changing them unless they have become damaged.
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
here https://kriticalpads.com/ is your vega water cooled? and how mutch tim did you use? and what type??
41,962 (6.61/day)
Igorlabs is a good source for useful info. However, they're not always right on everything. That much TIM is just not needed.
He has the unlevel gpu die.
Too much tim just makes a mess, as long as it's not a liquid metal, conductonaut or arctic silver, he will be fine. A firm motion down with little twists helps
Morgoth
Fueled by Sapphire
4,237 (0.67/day)
Netherlands
41,962 (6.61/day)
27,518 (6.63/day)
you know if i use less it wil shut it self down on start up??
Not really. 40um is very small and it takes very little TIM to fill that kind of space. I have repasted many Vega GPU's and have never used as much TIM as you applied. However, the excess will not hurt anything. You just used more than you really needed to, that's all. No worries mate.
