Researchers Build a CPU Without Silicon Using Carbon Nanotubes
AleksandarK
2,352 (0.93/day)
It is no secret that silicon manufacturing is an expensive and difficult process which requires big investment and a lot of effort to get right. Take Intel's 10 nm for example. It was originally planned to launch in 2015, but because of technical difficulties, it got delayed for 2019. That shows how silicon scaling is getting more difficult than ever, while costs are rising exponentially. Development of newer nodes is expected to cost billions of Dollars more, just for the research alone and that is not even including the costs for the setting up a manufacturing facility. In order to prepare for the moment when the development of ever-decreasing size nodes becomes financially and physically unfeasible, researchers are exploring new technologies that could replace and possibly possess even better electrical properties than silicon. One such material (actually a structure made from it) is Carbon Nanotube or CNT in short.
Researchers from MIT, in collaboration with scientists from Analog Devices, have successfully built a CPU based on RISC-V architecture entirely using CNTs. Called RV16X Nano, this CPU is currently only capable of executing a classic "Hello World" program. CNT is a natural semiconductor, however, when manufactured, it is being made as a metallic nanotube. That is due to the fact that metallic nanotubes are easier to integrate into the manufacturing ecosystem. Its has numerous challenges in production because CNTs tend to position themselves randomly in XYZ axes. Researchers from MIT and Analog Devices solved this problem by making large enough surfaces so that enough random tubes are positioned well.
The CPU is based on the RISC-V architecture, particularly it is designed to handle 32-bit wide instructions in a 16-bit wide memory address design. Being that all stages of the CPU pipeline (Instruction Fetch, Decode, Register Read, Execute and Write Back) are 16-bit in width, the CPU is officially declared as 16-bit. It uses 14,000 logic gates, like AND or NOT gates, to become a fully functional design. Given the careful manipulation of nanotubes, researchers managed to pull off 100% yield, meaning that all of the 14,000 gates worked correctly. Here is the waveform of execution of the Hello World program (while it isn't exactly Crysis, given the position of this technology, it is quite an impressive achievement):
The technology isn't perfect, yet. The chip ran at a very low clock speed of only 10 kHz, which means that your average CPU is an order of magnitude faster than this. With all of the flaws, this demonstration is an important achievement for the technology - a proof of concept. It shows that you are able to manufacture a working example of CPU based on something that doesn't require silicon and possibly is even better than it. We just haven't perfected all of the bits and pieces required to get CNTs at the same level of performance we already have.
1,771 (0.44/day)
About time. We've been hearing about CARBON NANOTUBES for what seems like a decade without so much as a working prototype.
I highly suggest you check out Coreteks's latest video where he speculates on the next 30 years of chip manfufacturing including CARBON NANOTUBES:
64K
6,402 (1.69/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Video Card(s) MSI RTX 2070 Super
Display(s) Dell 27 inch 1440p 144 Hz
Keyboard Logitech G105
I read an article a few years ago on Ars Technica about using carbon nanotubes to replace silicon. It's pretty interesting. The scientists speculated that using carbon nanotubes for transistors could be up to 5 times faster than silicon while using 1/5th the power. That would be an incredible advancement for so many devices if they can work the bugs out.
If carbon nanotubes doesn't work out then some other material will. Silicon is definitely not the future. It's getting more and more expensive as the process node shrinks. One day it may be possible to continue to shrink but not economically feasible to do so.
computer chip
"A new kind of computer chip (array of chips on the wafer pictured above) contains thousands of transistors made with carbon nanotubes, rather than silicon. Although the current prototypes can’t compete with silicon chips for size or speed yet, carbon nanotube-based computing promises to usher in a new era of even faster, more energy-efficient electronics."
4,839 (1.59/day)
Processor Ryzen 9 5900X
Motherboard MSI B450 Tomahawk ATX
Cooling Cooler Master Hyper 212 Black Edition
Memory VENGEANCE LPX 2 x 16GB DDR4-3600 C18 OCed 3800
Storage 970 EVO NVMe M.2 500 GB, 870 QVO 1 TB
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Mouse SteelSeries Rival 310
Software Windows 10 Professional 64-bit v22H2
Unfortunately silicon was still involved in the process.
Arstechnica said:
the researchers made a silicon surface with metallic features that were large enough to guarantee several nanotubes would typically bridge the gaps between the metal.
1,600 (0.81/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
Carbon Nanotube process is also an expensive and difficult process which requires big investment and a lot of effort to get right.
160 (0.08/day)
System Name Lovely Milky Milky
Processor 7800X at 4GHz
Motherboard EVGA X299 FTW K
Cooling Custom milky loop
Memory 32GB Crucial Ballistix Sport LT 3200MHz quad channel
Video Card(s) MSI GTX1080Ti SeaHawk EK X
Storage A-DATA 512GB M.2, 750GB Samsung SSD, 2x 1TB Seagate Pipeline HDD's
Display(s) AOC CQ32G1 32" Curved 144Hz 1440p
Case Aerocool Quartz Pro
Power Supply Seagate Snow Silent 750W
Mouse Fnatic Flick 2
Keyboard Drevo Blademaster TE
Raging at my PC and calling it a CNT will be valid finally
277 (0.06/day)
Intel's 10nm 4 year delay is not much of an example since the rest of the industry is going in to 5nm and already working on 3nm.
With 10nm they put all eggs in one basket and failed, greed and hubris got in their way by selecting the cheaper way to do 10nm by default.
You could say karma is a b1tch, this one decision gave AMD the future lead in the cpu business and i am so happy Intel screwed over them self's.
A greedy company like Intel should never ever have any kind of monopoly because they will self destruct by prioritising profit over technical advancements.
I am sure someone will develop a new way of doing cpu's without silicon long before Intel.
2,779 (1.15/day)
Buenos Aires, Argentina
System Name System V
Processor AMD Ryzen 5 3600
Motherboard Asus Prime X570-P
Cooling Cooler Master Hyper 212 // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Storage SHFS37A240G / DT01ACA200 / WD20EZRX / ST10000VN0008 / SA400S37960G / SNV21000G / NM620 2TB
Case NZXT Source 210
Power Supply Corsair CX650M
Mouse Microsoft Trackball Optical 1.0
Keyboard HP Vectra VE keyboard (Part # D4950-63004)
Software Whatever build of Windows 11 is being served in Dev channel at the time.
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
Carbon nanotubes can not replace current silicon-based technologies because there is no way to mass-produce them yet. With current technology, you could make at best a few dozens of thousands of carbon nanotube transistors in a relatively short time. A processor would need at least hundreds of millions (for example, the Core i7 980 had 1170 million transistors and 8-core Ryzen processors almost reach the 5 billion mark). And then you would have to make millions of processors.
Besides, and before that, you need to have people in R&D that know all the ins and outs of carbon nanotubes, and we still haven't discovered everything about them. So, I'd say it would take ten years more at least before we see them in everyday technologies.
I said this sometime ago, and while I haven't changed my opinion, hopefully it will take a little less time to see it in actual products.
The next few years sure look quite interesting, though.
121 (0.06/day)
Gotta love how it only took 6 comments for someone to bash Intel on an article having nothing to do with them.
4,384 (1.47/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
Carbon nanotubes. Yeah been hearing about this a lot lately. It doesn't mean necessarily that the advancement will have to take 30 years to catch-up. This depends on the research and how many companies or probably researchers will be involved. This is a rough estimate and believe it or not, it will be way faster. Starting is basically the worst part after that you take a leap forward. Especially if you have a proof of concept and we have that already.
132 (0.07/day)
So it roughly is as fast as ENIAC from 1945, though surely more energy efficient...
5,452 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
I'm picking Quantum CPUs will be out for the consumer before this ever makes it to market
8,326 (3.19/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Haha probably not you have to hit -1,000,000 Kelvin to get Quantum CPUs to even do what they are supposed to do. We will need an Alexa sized cooler to be able to do that at home and that is many years away.
121 (0.06/day)
Not only that, but quantum computers don't lend themselves well to doing everyday tasks. For certain problems, yes they eventually can be faster than classical computing, but for the consumer, no.
8,326 (3.19/day)
Cooling In Win SR36
Exactly they are building them to do calculations for complex problems at the molecular level, or solving quantum mechanics equations mostly but the thought of a CPU processor having 4 different states for instructions is crazy.
121 (0.06/day)
Yeah. I can grasp how classical computing works, but start reading about quantum computing and my head hurts.
8,326 (3.19/day)
Cooling In Win SR36
I know super position, entanglement were so easy for me to understand at a high level but the details are indeed headache inducing.
5,449 (0.97/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
Who knows, maybe for example games are calculated eventually on an ingame molecular level for realism :p
3,595 (1.22/day)
So?
Different computers for different tasks.
CNT is just another candidate for future CPUs like we have today: deterministic, binary. We know silicon's potential is ending. We already have better semiconductors that work (like GaN), but they're more expensive, so won't be used until there's no other way.
Quantum computers will be used for different problems. You won't run Windows on them. Ever.
Seriously...
454 (0.16/day)
System Name Sillicon Nightmares
Processor Intel i7 9700KF 5ghz (5.1ghz 4 core load, no avx offset), 4.7ghz ring, 1.412vcore 1.3vcio 1.264vcsa
Motherboard Asus Z390 Strix F
Cooling DEEPCOOL Gamer Storm CAPTAIN 360
Memory 2x8GB G.Skill Trident Z RGB (B-Die) 3600 14-14-14-28 1t, tRFC 220 tREFI 65535, tFAW 16, 1.545vddq
Video Card(s) ASUS GTX 1060 Strix 6GB XOC, Core: 2202-2240, Vcore: 1.075v, Mem: 9818mhz (Sillicon Lottery Jackpot)
Storage Samsung 840 EVO 1TB SSD, WD Blue 1TB, Seagate 3TB, Samsung 970 Evo Plus 512GB
Display(s) BenQ XL2430 1080p 144HZ + (2) Samsung SyncMaster 913v 1280x1024 75HZ + A Shitty TV For Movies
Case Deepcool Genome ROG Edition
Audio Device(s) Bunta Sniff Speakers From The Tip Edition With Extra Kenwoods
Power Supply Corsair AX860i/Cable Mod Cables
Mouse Logitech G602 Spilled Beer Edition
Keyboard Dell KB4021
Benchmark Scores 13543 Firestrike (3dmark.com/fs/22336777) 601 points CPU-Z ST 37.4ns AIDA Memory
8,155 (2.23/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
The question is whats the smallest size is achieveable that is still practical, will CNT be better or will silicone in the long run? That is assuming smaller is still better. I'm betting that CNT will be more reliable when the process reaches picometers (unless they use angstroms as the unit of measure).
3,595 (1.22/day)
IIRC, CNTs are better conductors of heat, too! IMO, this is a step in the right direction.
Not really.
A single CNT can be a fantastic thermal conductor... along it rotational axis ("through" the tube) and basically an insulator in perpendicular direction.
A randomly aligned CNT material is a worse thermal conductor than copper.
Making big chunks of aligned CNTs is at this moment under research. It may never be easy and cheap enough to be used in consumer CPUs or cooling solutions.
Also, keep in mind the best thermal conductivity is true for CNTs that are electric conductors - hence not usable as silicon replacement.
CNTs that end up in CPUs (if it ever happens) will have different physical properties and lower thermal conductivity.
418 (0.23/day)
Processor R5 5600X
Memory 32 GB 3600 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Phanteks P300A
Software Manjaro Linux, W10 if I have to
An order of magnitude? My CPU is multiple orders faster.
