(Resolved) Request HIS RX 580 Bios (113 H5885STD1 M80) Please Help!!!!!
Status
Not open for further replies.
Emanon
9 (0.01/day)
(Resolved) Finally!! I fixed it by this bios --> VGA Bios Collection: his rx580 8 GB | TechPowerUp Thx everyone :D
Anyone have this bios version? I forgot to backup before flash. try to find this version but i can't find it.
Reason is i try to fix afterflash problem i try to reflash by use bios from this website (My GPU is HIS RX580 8GB OC) but after reflash i still can't use my card and got this messege
and this...
and finally is this in GPU-Z (i used pic from google because this is not my pc it's my bro pc) it's emtry in all this "red box" i marked
Anyone have solution for this problem?
The things i'd tried :
- Reinstall Window
- Change GPU to another PC
- Install new bios by using AMD ref bios and HIS Bios
- Install old driver and new driver
- Change bios (it's dual bios on GPU)
pls help me :(
Emanon
9 (0.01/day)
PC Spec:
i5 9400f
Gigabyte H310M H 2.0
Ram 16 GB
PSU 600w
SSD 500 GB
HIS RX 580 8GB
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
do you have a picture of the card?
otherwise try using AMD/ATI Pixel Clock Patcher . patch the driver and see if it works. ill look around and see if i can find the right bios tho.
1,891 (1.41/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello
For example in my case, i own RX580 from MSI with this error 43.
On GPU-Z appear that i have Micron memory chips but in reality when i checked on video card (i opened it) i noticed i have Samsung.
So in your case i managed to find out a BIOS for your card, but with Samsung chips.
Try it
And be so kind and after you test it inform us how it work
Emanon
9 (0.01/day)
Hello
Try it
I can't find HIS RX 580 with Micron Ram Bios :(
1,891 (1.41/day)
Romania
Because it is possible to have Samsung. Either you try with BIOS i put link above, either you open the video card to make a picture of memory chips.
It is possible to have Samsung memory chips (like in my case) and GPU-Z to read it wrong.
So you must choose what you prefer.
Good luck
Emanon
9 (0.01/day)
Good luck
it's not matter what gpu brand bios i will use right? but must use correct to the ram brand?
Emanon
9 (0.01/day)
Another pic from GPU-Z
Hello
Try it
I tried to install AMD/ATI Pixel Clock Patcher but it doesn't work and tried to reflash bios that's say "Micron" RAM but it can't because SubID anyway to tried?
Emanon
9 (0.01/day)
It's say pass but it's not show GPU-Z info like the pic i post
1,891 (1.41/day)
Romania
Hello again
As i said i have same situation like you, but i have MSI.
In my case GPU-z also reported that i have Micron memory but after i opened the card i noticed that in reality i have Samsung.
So you have 2 options :
1 - test the BIOS i put link
2 - open the video card to see what kind of memory you have in reality.
Keep us informed
Emanon
9 (0.01/day)
Hello again
Keep us informed
1 - I already tried that bios you sent but can't install it said my SSID mismatch
2 - I already open video card too it's Micron RAM
any solution bro? ;(
Status
