Retail VS Shucked drives, MHDD platter scan results
30 (0.03/day)
Poland, Bydgoszcz
As someone who does a bit of data hoarding, I decided to share my small results of checking shucked drives against a retail drive
Drives are:
8TB - WD80EDAZ-11TA3A0 - Shucked WD MyBook - white label WD HC320
12TB - WD120EDGZ-11B1PA1 - Shucked WD Elements - white label WD purple WD121PURP
16TB - WD161KRYZ - Retail WD Gold 16TB purchased directly from WD website
The pattern I see is that the shucked drives are something like Quality-Control rejects.
More sectors showing instability which may evolve into bad sectors.
A sample of three is not much, but I would love to see results from others.
MHDD is an old piece of software (~2006), running on DOS, easiest way to boot is to use Yumi tool.
Older uefi or bios preffered for this software to work.
Scanning all the platters takes time, but I would say it's worth it, as one can weed out troublesome drives before they get into a working setup.
Mussels
Freshwater Moderator
58,413 (8.01/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
The heck is a shucked drive?
1,755 (1.27/day)
A shucked drive is, I believe, an external HDD removed from its enclosure. I once removed a 750GiB Seagate HDD from an external enclosure and it developed bad sectors after a year of use as an internal HDD.
1,197 (0.19/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
Deleted member 202104
A drive pulled out of an external enclosure.
It’s North American slang.
I had to lol at the example.
“The process of removing, peeling or discarding the outer covering on food items such as nuts, corn and shellfish. The husk is peeled from an ear of corn, the shell is removed from a nut, and the outer shell of a shellfish such as an oyster or a clam is also similarly removed or "shucked."”
213 (0.23/day)
Processor Ryzen 5 5600X
Motherboard Asus B550-F Gaming WiFi
Cooling Be Quiet! Dark Rock Pro 4
Memory 64GB G.Skill Ripjaws V 3600 CL18
Video Card(s) Gigabyte RX 6600 Eagle (de-shrouded)
Storage Samsung 970 Evo 1TB M.2
Display(s) 2 x Asus 1080p 60Hz IPS
Case Antec P101 Silent
Audio Device(s) Ifi Zen DAC V2
Power Supply Be Quiet! Straight Power 11 650W Platinum
Mouse JSCO JNL-101k
Keyboard Akko 3108 V2 (Akko Pink linears)
Well that would definitely help explain why shucked drives are cheaper than retail....
I only found out what "shucked" drives are a few months ago. Never knew what it meant.
1,197 (0.19/day)
Hampton Roads
Cooling Fans
Storage small ssd
Case Lian Li
Power Supply X750
Cool story: the first drive I bought to shuck was a Hitachi DeskStar 1TB. Bought for the cool sum of $170 US. I also got a short tour of Thomas Jefferson National Laboratory, as that is where the dude that sold it worked!
21,245 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
It's what happens to shellfish who ask too many questions...
You wanna go for a drive, mussels? You don't.
2,280 (0.48/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
I found that if you get these symptoms, then it's most likely an HDD with a bad board or bad cache on the HDD board: (possibly oxidation or corrosion on the HDD PCB!)
MHDD finds nothing wrong during the scan, but Windows installation keeps failing, often in random spots and/or Chkdsk terminates with a false insufficient-disk-space error.
Or the system keeps reporting corruption, even when MHDD didn't find anything wrong.
OneMoar
There is Always Moar
8,789 (1.66/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
not sure I trust MHDD its a hella old and dos-based
edit and the comparison is what?
you are testing 3 Different drives here?
Pattern? What Pattern?
2,280 (0.48/day)
System Name KHR-1
Case Corsair 275R
Oh, in my case with what looked like a PCB fault on a Western Digital WD5000AAJS HDD, IIRC, it had the symptoms I mentioned, but not even so much as unusual lag with the MHDD platter scan.
There also were no other errors reported by MHDD.
Mussels
58,413 (8.01/day)
Oystralia
This explains why i'm bipedal these days
Heaps of my drives are from externals, i've never had any issues
Edit:
Now to be clear i get a lot of second hand utterly f*cked 2.5" external drives, but that's because the owners treat them like poopoo and beat the crap out of them. SSD's have saved us from that stupidity continuing - i've even had to stop family from whacking the enclosure to 'stop the noises'
21,245 (3.40/day)
System Name Pioneer
I'm from Pacific Northwest Oyster area, so I know shucking as a term.
Fun unrelated fact (as if this is on topic at all): It's a very fact paced industry to make a livable wage (per unit pay), and people who do it longterm tend to lose fingers.
OneMoar
8,789 (1.66/day)
Rochester area
is that why your profile is a tree frog
missing a few digits are you?
30 (0.03/day)
Poland, Bydgoszcz
If I could compare more drives, I would.
That is unfortunately not possible with the income I have available.
Normally I would have purchased another external 12TB for redundancy but I decided to spend more on a retail 16TB drive, for the 5 year warranty and the ability to check whenever there are noticeable differences in the quality of the drive.
If other users could fire up the scan on their new shucked/external and retail drives, there would be more data to get some conclusions.
MHDD does scans the same way other programs do, it's that most programs just flag good/bad while MHDD provides actual access time for all the sectors. There are some more modern programs but they are Windows based, which means there's an element of uncertainty like the OS trying to access the drive, running a dedicated program under DOS removes that uncertainty.
8,179 (2.20/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
awww shucks!
Get shucked!
and the ever popular: Go Shuck Yourself!
I used to see people bring me borked old Passbooks (WD). Dropping them almost guaranteed something inside would break. I would offer to mount the HDD inside their case if it was still good.
41,427 (6.58/day)
Shucking peas, corn
Use Hitachi DFT
21,245 (3.40/day)
System Name Pioneer
FreedomEclipse
~Technological Technocrat~
23,880 (3.75/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Cooling AM5 Contact Frame + Thermalright PS120SE
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Off topic (and im very sorry but it will be my only one)
I read this in Joe Pesci's voice
Home Alone Smile GIF by filmeditor
qubit
Overclocked quantum bit
17,865 (2.91/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
21,245 (3.40/day)
System Name Pioneer
You wish that was all that was off about him....
785 (0.23/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
Thus far based on the amount of HDD used in the data hoarding reddit from shucked hdd, they general perform as similarly as retail version and reliably enough albeit slower. I got tons of externals due to their price I am curious of their reliability themselves. External hdd are derated retail version running at lower rpm which makes them rather excellent for quiet builds. My 7200 retail WD ultrastars are loud in comparison.
30 (0.03/day)
Poland, Bydgoszcz
As far as I know, they are not derated.
Even if the drive reports 5400rpm, it is often in fact 7200rpm.
WD introduced 5400rpm "performance class". If you take measurements based on seek time, vibration frequencies or just use an MHDD command "rpm" you will get 7200rpm. Three ways to confirm the real rpm.
WD80EDAZ reports 5400rpm, but it's 7200rpm without any doubt.
