Retro 775 build
Durvelle27
6,813 (1.48/day)
Memphis, TN
System Name Black Prometheus
Processor |
Cooling Thermalright PA120 SE |
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Had some old parts laying around that I found that I decided to put to use for a light media center.
Build consists of
Antec Three Hundred Case
Gammaxx 200T Cooler
Core 2 Duo E4300 (Until I can source a core 2 Quad)
ASUS Mobo
Samsung 8GB(4x2GB) DDR2 800MHz
EVGA GTX 260
Sound Blaster Audiogy 2 ZS
Enermax 650W
Will keep you guys updated
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
EVGA GTX 260 Superclocked
561 (0.24/day)
Canada
System Name HP Pavilion a6552f
Processor Intel Core 2 Quad Q9400
Motherboard Asus IPIBL-LB / HP Benicia-GL8E
Cooling DeepCool Gammaxx 200
Memory 8gigs Kingston 4x2gigs DDR2-800
Video Card(s) Zotac GT630 "Fermi" 2gb DDR3 128bits Synergy Edition
Storage Western Digital Green 7200rpm 1tb
Display(s) LG Flatron EW234 Super LED
Case HP Pavilion
Power Supply Thermaltake TR2 430w
Mouse Razer Abyssus Mirror Special Edition Blue LED
Keyboard Thermaltake Tt eSPORTS Commander Red LED Backlighting Mechanical Keycaps Membrane Gaming Keyboard
Software Windows 7 Home Premium 64bits
Build consists of
Gammaxx 200T Cooler
ASUS Mobo
EVGA GTX 260
Enermax 650W
A dualcore E8400 is quite capable and it could be 5 or 10$.
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
I rather have a Quad Core as this machine will have to stretch its legs
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
Ran into an issue
PC boots fine but when the GTX 260 is installed the PC just constantly restarts
I’m not sure if it’s the PSU or GPU
911 (0.37/day)
Al Balqa', Jordan
Processor AMD Ryzen 5 2600 (Covered with Cooler Master MasterGel Pro)
Motherboard ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta]
Cooling Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust)
Memory Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8)
Video Card(s) Palit GeForce GTX 1660 Ti Dual OC
Storage Kingston NV2 1 TB
Display(s) MSI PRO M251 (HDMI), Running @104 Hz
Case Cooler Master MasterBox MB520
Audio Device(s) HP H360G USB
Power Supply Cooler Master MWE 550 80+ White
Mouse HP G200 Black
Keyboard Redragon MITRA K551-1 RGB
Software Windows 11 Home
Ran into an issue
It's probably the PSU , this GPU EATS WATTS !!!! , and gives heat.
1,025 (0.33/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
C2D E4300 seems rather weak. I suggest E8400, E7600 or Xeon X5260 since they can be found for under 10 $.
561 (0.24/day)
Canada
Case HP Pavilion
He just replied me that he doesnt want a dualcore.
561 (0.24/day)
Canada
Case HP Pavilion
After a quick search the GTX 260 require a psu over 500watts but also a minimum of 36amps on the 12volts supply line for the gpu itself. Lot of people tend to forget about the amps.
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
After a quick search the GTX 260 require a psu over 500watts but also a minimum of 36amps on the 12volts supply line for th3 gpu itself. Lot of people tend to forget about the amps.
This PSU has 2 12V rails rated 25 amps a piece so that could be the reason
I never even looked at the GTX 260 power draw :shadedshu:
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
So after further testing the PSU is the culprit
Seems it can handle the strain of the GTX 260
42 (0.02/day)
that "free physX" logo brought back that taste in my mouth ....
really cool of you to resurrect this. ITS ALIVE!
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
So I dug up some old 771 Xeons Quads. I might just use one of those instead of a Core 2 Quad
561 (0.24/day)
Canada
Case HP Pavilion
Could be better and the adapter is qiite inexpensive and don't forget to break the tabs. :)
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
You don’t break the tabs you just shave them down
561 (0.24/day)
Canada
Case HP Pavilion
I break them with a pair of cutting plyers for thin metal. Each his technique. :)
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
I will use a exaco knife the trim them off
Deleted member 67555
I have had that problem with a GTX 275...(bought brand new in 2016 for $18)
It needs a lot of amperage to operate.. Literally did the same thing.. Thought a 2 rail PSU would work with 20a per rail but nope...
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
CPU I plan to slap in it
It’s a Xeon E5310
10,885 (1.55/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
I slapped a X5470 quad into a P5Q and it worked great. The sticky pin adapter on the CPU was the hardest part, need a jewelers loupe to get it spot on. Results:
  • P5Q Deluxe (slightly modded CPU slot to accept the X5470, will still accept a 775 Core CPU)
  • X5470 Solid at 4Ghz
Solid second gaming rig till I got the 4970k z97 I have now. Both were fitted with 290x graphics
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
Not bad at all what did you do with the rig ?
And how hard is it really to adhere the adapter; this would be my first
10,885 (1.55/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
A member here took it off my hands
It was my first too :p I would buy at least two (they're cheap) in case you bungle the first try. Make sure you have a good pair of tweezers, a very good magnifying glass and take a few Zanax first, lol.
Here's a video... I like the technique of getting one end placed right and rotating the other before tacking it down. It's a lot smaller than appears in the video, and not a lot of room for error.
Google socket 775 to 771 adapter and there's a ton more info and videos.
Ruru
S.T.A.R.S.
13,288 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Audigy2 ZS, my favourite soundcard ever. :toast:
1,226 (0.24/day)
Omaha, NE
System Name Graphics Card Free...
Processor Ryzen 5 5600G
Motherboard MSI B450 Gaming Plus MAX Wifi
Cooling Cryorig M9a w/ BeQuiet! PureWings 2 ~ 92mm
Memory Corsair Dominator Platinum DDR4 3200 ~ 16GB(2x8GB)
Storage Samsung EVO 870 SSD - 1TB
Display(s) AOC 24G2
Case Cardboard...
Power Supply eVGA SuperNova 550w G3
Mouse Logitech t400 Zone Touch Mouse
Keyboard IBM Model "M" Keyboard
Software Manjaro ~ KDE Plasma
Benchmark Scores She's a Runner!
If you're going to do cpu mods, perhaps the under $10 q6600 with the tape mod(BSEL) would work? 1.6GHz on that xeon seems a little low.
Your pictures are dark, but that ASUS motherboard looks like an IPIBL-LA or LB, those were actually some pretty strong runners. Although, back when I was playing with them...one of the varieties wasn't compatible with the newer quads so I had to use a QX6800 instead of a Q9550.
It was a very solid board...never gave me trouble.
Back when that GTX 260 came out...I bought the XFX version...I loved that card. I'm subbing to your thread to see what happens next!
Liquid Cool
