- May 19, 2015
- 78 (0.02/day)
- Ukraine
Processor | Ryzen 7 7700X |
Motherboard | Asus ROG Strix X670E-F Gaming WiFi |
Memory | F5-6000J3038F16GX2-FX5 |
Hey, thank you for your work, the utility is really cool!
Please help me to fix this issue. I usually install drivers via Revo Uninstaller so that when I need to uninstall them - there will be no (hopefully) traces left. And usually I used NVCleanstall with the following options:
- picked graphics driver (required) and usb-c (for an unknown reason there's a device for it in the list of devices, although my 1660ti has no visible usb-c ports);
- checked disable telemetry and clean installation
And then, when I tried to install it via Revo Uninstaller, it would install just fine.
Today I updated NVCleanstall from 1.6 to 1.7 and downloaded the latest driver which is 451.67, I did everything like usual but added 2 expert tweaks - disable driver telemetry and enable MSI, and it failed to install via Revo Uninstaller, it said "Error: NVCleanstall settings file not found". When I then tried to run setup.exe directly (not via Revo) - it seemed like everything got installed like usual.
So my question is - how to fix that so that I install it through Revo Uninstaller?
