Rivatuner 2.23 Released
malware
5,422 (0.75/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
The very powerful videocard tweaking utility Rivatuner has been updated towards version 2.23. The full list of this release' updates and fixes follows below. To download it, please click here.
What's new:
  • Added ForceWare 182.xx drivers family support.
  • Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 181.20, 181.22 and 182.05.
  • Added Catalyst 9.1 drivers family detection.
  • Updated PCI DeviceID database for NVIDIA display adapters.
  • Added reference fan duty cycle monitoring and low-level fan control tab for G92 based display adapters using integrated on-die fan controller (e.g. GeForce 9800GTX series). Please take a note that low-level fan control tab for display adapters using integrated fan controller is provided only as a workaround allowing you to control the fan if the drivers are completely unable to do it. It is strongly not recommended to use low-level fan control for integrated fan controllers if driver-level fan control functions properly.
  • Added heuristic driver version detection for unattached display devices (for example the secondary GPUs in SLI/Crossfire mode invisible to OS) under Windows Vista.
  • Improved driver-level overclocking and fan control for NVIDIA multi-GPU systems.
  • Improved hardware monitoring module, New sticky graphs mode was designed special for multi-GPU systems
  • Updated bundled RivaTunerStatisticsServer v3.1.0 utility:
    - Minor skin appearance changes, "Normal" application detection level has been renamed to "Low" for better understanding.
    - Improved hooking system injects code into OS kernel's LoadLibrary functions by precached offsets and improves compatibility with some protective systems, faking the real LoadLibrary function offsets (e.g. latest revisions of SecuRom coming with new games like Dead Space, Need for speed : Undercover etc). Now such games no longer crash on startup when the server is running and LoadLibrary hooking is enabled by selecting "High" application detection level.
    - Added pre-created profiles for 3D applications, which require non-standard On-Screen Display coordinate space settings (e.g. Codename Panzers : Phase Two and Alpha Prime).
    - Added pre-created profiles for new pseudo-3D applications.
  • Updated bundled D3DOverrider v2.0.0 utility
  • Added experimental display configuration tracking mode. Power users may enable this mode using DisplayConfigurationTracking registry entry to force RivaTuner to track changes in your display adapters configuration (e.g. toggling SLI mode on/off or disabling secondary display adapter in the device manager). RivaTuner will reinitialize logical devices list and restart hardware monitoring module on display configuration change.
  • Minor GUI changes and improvements.
  • Many more (check revision changes)
InnocentCriminal
Resident Grammar Amender
6,477 (0.91/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
I'll be trying this out tonight.
:D
1,145 (0.19/day)
England
System Name Wasleys PC
Processor Intel i5 2400 3.10GHz
Motherboard Asus P8z68-V
Cooling AC Freezer Pro
Memory Kingston 4GB (2x2GB) DDR3 Hyperx Memory
Video Card(s) HIS ATi 6850 1GB DDR3
Storage Seagate ST3500320AS 500GB Hard Drive SATA II 7200rpm *32MB Cache*
Case Antec 900 with mods
Audio Device(s) On Board
Power Supply OCZ Stealth Xtream 500W
Software Windows 7
Downloaded it - Never understood what to do with it. Suppose it helps If I read the website :)
InnocentCriminal
6,477 (0.91/day)
System Name BeeR 6
If you want dude, I can make a simple guide tonight on how to OC, set fan speeds and the alike. At work right now so can't.
jydie
209 (0.03/day)
Processor Athlon 64 X2 4200+ (socket 939)
Motherboard ASUS A8R-MVP Express200
Cooling Standard AMD CPU Heatsink/Fan
Memory 1GB Geil PC3200
Video Card(s) Sapphire Radeon X1900GT
Storage 2 Maxtor 7200 HDD (80GB)
Display(s) Samsung 19" LCD
Case Yellow Chieftech Dragon
Audio Device(s) integrated
Power Supply Thermaltake TT-420AD
Software Windows XP Home
If you take the time to figure out how to use this utility, you will be amazed. It allows you to keep an eye on your video cards' vitals and sooo much more. I will admit that it does take some time to figure out though... not as easy as ATI Tool, but ATI Tool is really outdated and no longer works with my newer video cards. I really wish they would update ATI Tools... that program was the PERFECT video card tool.
InnocentCriminal
6,477 (0.91/day)
System Name BeeR 6
It was ATi Tool that brought me to this site, I used it for years, reading and browsing this forum before actually signing up. I presume it'd be too much work for Wizard to get ATiTool back into swing.
KBD
2,477 (0.39/day)
The Rotten Big Apple
Processor Intel e8600 @ 4.9 Ghz
Motherboard DFI Lanparty DK X48-T2RSB Plus
Cooling Water
Memory 2GB (2 x 1GB) of Buffalo Firestix DDR2-1066
Video Card(s) MSI Radeon HD 4870 1GB OC (820/950) & tweaking
Storage 2x 74GB Velociraptors in RAID 0; 320 GB Barracuda 7200.10
Display(s) 22" Mitsubishi Diamond Pro 2070SB
Case Silverstone TJ09-BW
Audio Device(s) Creative X-Fi Titanium Fatal1ty Profesional
Power Supply Ultra X3 800W
Software Windows XP Pro w/ SP3
Back in the fall I saw a post by Wiz and in it he said that he is working on a new stable release and the problem was actually with ATI cards, NV cards were working fine. He said something about it coming out either late last year or some time this year, basically when the issue with ATI cards is sorted. So according to that, he is working on it. I cant find that post now but if someone is interested in searching for it, its here somewhere, prolly in the ATI Tool section.
h3llb3nd4
3,323 (0.59/day)
Durban, South Africa
System Name My mobo is Laughing at me
Processor E7400
Motherboard P5KPL-E Bios flashed to 0601 (Piece of poo!!)
Cooling Thermalright Ultra 120a
Memory GENERIC 2 GB DDR2 800
Video Card(s) NONE!! Beat that!!
Storage 500GB SAMSUNG SATAII, 250GB SAMSUNG SATAII and o'l crappy 4gb maxtor
Display(s) ACER X223W Q
Case AEROCOOL ZERODEGREE (planning to mod)
Audio Device(s) REALTEK ONBOARD
Power Supply GIGABYTE 460W
Software Win 7 x86 build 7022
Benchmark Scores Super Pi 1m 17.000 :(
RivaTuner IS the BEST!!!!
1,197 (0.21/day)
Asia, PH
Processor Q6600 @ 3.6GHz | P4 @ 2.1GHz
Motherboard Asus Commando ROG (Vdroop mod) | Asus P4V8X-MX
Cooling MegaShadow w/ 2x Scythe Slipstream MX-2 Paste + Kama Bay + 4x120mm case fan | stock Intel
Memory Kingston 4x1GB DDR2 @ 800MHz w/ OCZ XTC cooler | 1GB DDR @ 400MHz
Video Card(s) Palit GTX 260 1792mb 448bit @ 713/1458/1116x2 | GeForce 4 MX 440 AGP8X 64mb 64bit
Storage 640GB WD AACS 250GB Excelstor 160GB Seagate | 40GB WD
Display(s) Samsung T220, Samsung 32" 1080P | LG L1752S
Case Gigabyte 3D Aurora 570 | Trendsonic mid tower
Audio Device(s) Asus Supreme FX (Creative Inspire 5.1 speaker), Samsung HT-Z220 | Onboard audio (2.1 Speaker)
Power Supply Gigabyte Odin Pro 800W | 550W generic
Software Vista Ultimate 64 SP2 | XP Pro 32 SP3
Benchmark Scores 3Dmark06 - 17,348 Vantage - P13,510 Super PI 1M - 12.765s @ 4.1GHz GenericCPUbench - 6,864 ms 38,
Any1 notice the memory clock is stuck @ 100MHz?
so now the memory clock for G9x GPU is attached to PCIE Frequency?
- Fixed idle memory clock frequency detection for G9x GPU based systems supporting memory clock frequency generator switching to PCIE bus clock (e.g. GeForce 9800GTX+ series display adapters)
