RivaTuner v2.09 Released
malware
5,422 (0.75/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
On this page you can download the latest version of RivaTuner. In RivaTuner v2.09 you'll find some minor bugfixes, better driver support as well as added support for NVIDIA G96 and G100 (aka GT200).
Minor bugfixes:
  • The server no longer erroneously swaps RGB components and no longer causes On-Screen Display to be rendered in unexpected color under Direct3D10 when non-default OSD color is being used.
What's new:
  • Added ForceWare 175.xx drivers family support.
  • Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 174.40, 174.51, 174.53, 174.60, 174.70, 174.74, 174.82, 174.85, 174.88, 174.93 and 175.12.
  • Added Catalyst 8.4 drivers detection. Please take a note that ATI continues "old good" tradition of using the same build version of different driver versions, so both Catalyst 8.3 and 8.4 will be detected as Catalyst 8.3 or newer.
  • Updated Catalyst 8.4 certified SoftR9x00 patch script (for Windows 2000/XP drivers only).
  • Updated PCI DeviceID database for AMD graphics processors. Added PCI DeviceIDs for RADEON X1650 AGP and RADEON 3850 X2.
  • Update driver files database for 64-bit NVIDIA ForceWare drivers.
  • Unlocked previously available experimental AMD RV620 graphics processors family support.
  • Added experimental NVIDIA G96 graphics processors family support.
  • Added experimental NVIDIA G100 (aka GT200) graphics processors family support.
  • Added experimental driver-level multi-GPU fan control support for Quad-SLI systems. Thanks to Jacob Freeman @ EVGA for testing driver-level fan control with2x NVIDIA 9800GX2 system.
  • Now RivaTuner is able to detect driver version and display driver files info for drivers using multiple driver files and active non-primary driver file.
  • Added experimental clock frequency stress-testing for NVAPI overclocking interfaces. Please take a note that NVAPI's own stress testing is not ideal yet and it is not available for some GPU families (e.g. G80) or may work improperly for others. Due to this reason NVAPI clock frequency stress-testing feature is disabled by default, however power users may enable it using NVAPIClockTest registry entry.
  • Added set of technologies aimed to improve RivaTuner startup and usage safety in conjunction with other hardware monitoring and diagnostics related tools:
    - Added low-level PCI controller access synchronization protocol. The protocol serves for preventing possible PCI controller access collisions when multiple tools are being started and scanning PCI buses simultaneously (e.g. detecting supported hardware during OS startup). Please take a note that to take full effect the protocol must be supported by other tools used simultaneously with RivaTuner, so please ensure that you're using this version of RivaTuner with the latest versions of other monitoring or diagnostics related software products (e.g. Everest).
    - Previously used low-level I2C synchronization protocol is now also applied to driver-level thermal monitoring function calls to prevent possible conflicts between low-level I2C transactions and internal driver-level I2C transactions.Please take a note that to take full effect the protocol must be supported by other tools used simultaneously with RivaTuner, so please ensure that you're using this version of RivaTuner with the latest versions of other monitoring or diagnostics related software products (e.g. Everest).
    - Added hardware scanning synchronization protocol, aimed to optimize startup process and reduce startup time when multiple tools are intensively scanning hardware.
    - Now startup daemon routine displays warning message in case of driver load failure (e.g. when the driver is blocked by antivirus tool).
    - Startup daemon self-deinstallation technology is disabled by default now. The daemon no longer uninstalls itself from Windows startup when it fails to apply any startup settings (e.g. due to driver load blocked by antivirus tool). If needed, the technology can be re-enabled by setting DontUninstallStartupDaemon registry entry to 0.
  • Updated bundled RivaTunerStatisticsServer v2.6.0 utility:
    - Now OSD rendering routines are compatible with WPF based applications.
    - Now the server's manifest file specifies full administrative privileges requirement. If you're using Windows Vista with UAC enabled, it is recommended to create scheduled task launching the server simultaneously with RivaTuner to minimize amount of displayed UAC evaluation dialogs.
    - Changed sever's own OSD rendering behavior, now the server doesn't display 3D API usage information in the OSD when framerate display is not requested by a client application.
    - Updated pseudo-3D applications list.
  • Updated bundled D3DOverrider v1.6.0 utility:
    - Now the D3DOverrider's manifest file specifies full administrative privileges requirement. If you're using Windows Vista with UAC enabled, it is recommended to create scheduled task launching the utility simultaneously with RivaTuner to minimize amount of displayed UAC evaluation dialogs.
  • Improved launcher module:
    - Added 'Show item in tray menu' option to regular launch item editor. By disabling this option you may prevent some regular launch items from being displayed in RivaTuner's tray menu. This option is helpful if you're intensively use scheduled tasks and define many helper launch items, required only for scheduled tasks.
    - Now you may select 'All files' as file type when browsing for application associated with a launch item and this way start and non-executable file type (e.g. WAV or MIDI) registered in the OS. Please take a note that 'Restore settings after terminating application' option will not affect non-executable file types.
    - Now RivaTuner stores application specific event markers in the event history panel of hardware monitoring window, allowing you to analyze all item launch events and reasons (e.g. item launch due to pressed hotkey, due to scheduled task etc). This feature simplifies debugging complex dynamic hardware control algorithms programmed via scheduler module etc.
  • Improved scheduler module:
    - Now you may specify custom scheduled tasks names in the task editor window to improve scheduled tasks list readability.
    - Added 'Wait for application termination' option for 'Launch application' tasks, allowing you to program sequentional tasks execution if needed.
    - Now you may select 'All files' as file type when browsing for application associated with 'Launch application' task and this way start and non-executable file type (e.g. WAV or MIDI) registered in the OS. Please take a note that 'Wait for application termination' option will not affect non-executable file types.
    - Now RivaTuner stores application specific event markers in the event history panel of hardware monitoring window, allowing you to analyze all shceduled tasks events and reasons (e.g. scheduled task launch due to core temperature change from 50°C to 51°C). This feature simplifies debugging complex dynamic hardware control algorithms programmed via scheduler module etc.
  • Improved hardware monitoring module:
    - Now you may use 'Override group name' option in each data source's properties to define custom on-screen display group for it and override default OSD grouping rule if needed,
    - Now RivaTuner is able to detect PLL shutdown and swicth to bus clock on G8x and newer GPU families to provide dynamic memory clock frequency monitoring on upcoming G96 graphics processors family.
    - Now RivaTuner uses BIOS PLL information tables on G9x and newer GPU families to detect reference clock frequencies for core and memory PLLs if unknown GPU is detected. If needed, reference clocks can be redefined via [CrystalClock] section of RivaTuner.cfg file.
    - Improved SMART.dll hardware monitoring plugin. Now the plugin supports SMART temperature reading for up to 8 hard drives instead of 4 hard drives in the previous version.
  • Improved low-level diagnostic report module:
    - Now RivaTuner displays PLL table contents containing per-PLL reference clock frequencies for G8x and newer display adapter families in 'NVIDIA VGA BIOS information' diagnostic report category.
  • Unlocked undocumented SSAA and combined MSAA / SSAA antialiasing modes for G8x and newer display adapters.
  • Now you may change external I2C fan controller detection retry counter using ExternalFanControllerDetectRetry registry entry or completely disable external I2C fan controller detection by setting this registry to 0.
  • Minor UI changes and improvements.
Wile E
Power User
24,318 (3.71/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
Dammit. I just downloaded 2.08 a few hours ago. lol.
jbunch07
5,260 (0.87/day)
Chattanooga,TN
Processor i5-2500k
Motherboard ASRock z68 pro3-m
Cooling Corsair A70
Memory Kingston HyperX 8GB 2 x 4GB 1600mhz
Storage OCZ Agility3 60GB(boot) 2x320GB Raid0(storage)
Display(s) Samsung 24" 1920x1200
Case Custom
Power Supply PC Power and Cooling 750w
Software Win 7 x64
Sweet! downloading now
echo75
456 (0.08/day)
Denmark
System Name Main
Processor Q6700 @ 3.5Ghz (with 1.50 Vcore)
Motherboard P5K
Cooling Xigmatek HDT S1283 (amazing performance)
Memory Corsair 800mhz 4GB @ 864mhz
Video Card(s) Asus 8800GT@ 720/1800/2100,blue Pcb with 92cm Glaciator cooler(4870 still under testing)
Storage Seagate 250GB SATA , 500GB eSATA
Display(s) LG Flatron 19"
Case Antec Designer (modded)
Power Supply Corsair VX 550W
Software Win XP Pro SP2
Benchmark Scores 3Dmark06 = 15,253 for 8800GT, 3Dmark06 = 15,807 for HD 4870
wolf
Better Than Native
8,104 (1.28/day)
System Name MightyX
Processor Ryzen 5800X3D
Motherboard Gigabyte X570 I Aorus Pro WiFi
Cooling Scythe Fuma 2
Memory 32GB DDR4 3600 CL16
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
43,596 (6.57/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Thank you once again Mr. Unwinder!:toast:
newtekie1
Semi-Retired Folder
28,473 (4.14/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Awesome, downloaded at home and waiting to installed when I get off work!
3,527 (0.57/day)
UK
System Name Dream Weaver
Processor Ryzen 5600
Motherboard B450 MSI Gaming Pro Carbon AC
Cooling NH-D14
Memory 16GB Flare X @ 3200MHz CL14
Video Card(s) Sapphire Vega 64 Nitro+
Storage 500GB evo 970 m.2 + 4TB HDDs
Display(s) ASUS 27" 1440p 144hz FreeSync
Case Fractal Design Define R3
Power Supply Corsair 850W
Nice! now I can OC my card with the newest 175.12 beta drivers! :toast:
1,177 (0.19/day)
System Name KOV
Processor AMD 5900x
Cooling H100i Cappellix White
Memory Corsair 3600kHz 32GB
Video Card(s) RX 7900XT
Storage Samsung 970 evo 500gb, Corsair 500gb ssd, 500GB 840 pro & 1TB samsung 980pro. M2.SSD 960 evo 250GB
Case Corsair 680x
Power Supply AX1200i Corsair
Software windows 11
PVTCaboose1337
Graphical Hacker
9,501 (1.40/day)
Texas
System Name Whim
Processor Intel Core i5 2500k @ 4.4ghz
Motherboard Asus P8Z77-V LX
Memory 2 x 4GB G.Skill Ripjaws @ 1600mhz
Video Card(s) Gigabyte GTX 670 2gb
Storage Samsung 840 Pro 256gb, WD 2TB Black
Display(s) Shimian QH270 (1440p), Asus VE228 (1080p)
Case Cooler Master 430 Elite
Audio Device(s) Onboard > PA2V2 Amp > Senn 595's
Power Supply Corsair 750w
Software Windows 8.1 (Tweaked)
My temperature went down by 5c... very strange. The monitor must be messed up.
Cold Storm
Battosai
15,010 (2.42/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
I love my VDO tool! Wile E, if you think its worth it... I'll go to it! Woot Woot for everyone that loves it
