Roccat Announces Kone Pure Owl-Eye White and Khan AIMO White
47,449 (7.50/day)
Black products are a tradition with the German gaming peripherals manufacturer, with the Kone Pure Gaming Mouse being the first white ROCCAT product that was introduced back in 2013. Today ROCCAT offers various products in white giving different options for gamers' set-ups.
Often requested from ROCCAT's customers, the Kone Pure Owl Eye and the Khan AIMO are perfect additions to the white collection the manufacturer already counts in its portfolio. Both products are perfect peripherals to display RGB lighting and boast the same technology of the other colour variants.
The Khan AIMO white 7.1 High Resolution RGB Gaming Headset is now available for 119.99€.
The Kone Pure Owl-Eye white optical RGB Gaming Mouse is available at 69.99€.
Kone Pure Owl-Eye White Tech Specs:
  • ROCCAT Owl-Eye optical sensor with 12000dpi
  • 1000Hz polling rate
  • 1ms response time
  • ROCCAT exclusive 50 Mio. lifecycle switches
  • 50G acceleration
  • 250ips maximum speed
  • Mouse acceleration: no
  • Angle snapping: no
  • Adjustable lift-off distance
  • ARM Cortex-M0 50MHz
  • 512kB onboard memory
  • 1.8m braided USB cable
Khan AIMO White Tech Specs:
DRIVER UNITS
  • Measured Frequency response: 10 - 40000Hz
  • Impedance: 32Ω
  • Max. SPL at 1kHz: 99dB
  • Driver Unit material: Neodymium magnet
  • Driver diameter 50mm
MICROPHONE
  • Measured Frequency response: 100-1000Hz
  • THD% at 1kHz: 2%
  • Sensitivity at 1kHz: -40dB
  • Signal-to-noise-ratio: 60dB
  • Impedance: 2.2Ω
SOUND CARD
  • Resolution: 24-bit at 96kHz (max)
