ROCm OS?
13 (0.00/day)
System Name Ti-99/4a
I picked up 8 GPU's to run a ROCm accelerated LLM but have no clue what OS dependencies are required, The cpu on the 8 slot board is an old skylake celery (soldered) so I want to keep it as lightweight as possible so can I get away with something like PCLinuxOS or will I need a tiny kernel?
I'm obviously avoiding Bloated SystemD distros.
I haven't found any good sources for info I straight up ROCm setups.
Also does anyone have a clue what the impact of running lower pci-e lanes will have, I may have to move to a board with more lanes but will see if the 1 GB/s restriction is manageable or not, I remember on things like FAH back in the day it didn't matter.
Solaris17
Super Dainty Moderator
27,431 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
1,767 (1.42/day)
System Name Raspberry Pi 7 Quantum @ Overclocked.
I honestly think you'd get more help posting on Reddit's "Local Llama." Also, Vulkan is now faster than ROCm, dangerously close to CUDA, at least for LLMs;
13 (0.00/day)
662 (1.00/day)
Brazil
Processor 5950x
Motherboard B550 ProArt
Cooling Fuma 2
Memory 4x32GB 3200MHz Corsair LPX
Video Card(s) 2x RTX 3090
Display(s) LG 42" C2 4k OLED
Power Supply XPG Core Reactor 850W
Software I use Arch btw
Your OS of choice shouldn't make much of a difference, specially CPU-wise.
Avoiding systemd might give you more headaches with almost no benefit. No reason to go with a tiny kernel either.
As said above, localllama on reddit is a good place to start.
131 (0.28/day)
Headless Arch Linux, use archinstall and choose your init system there. Afterwards check the GPGPU page on the wiki and install the ROCm packages.
Running fewer or slower lanes doesn't impact inference speed, but loading and unloading the model will be slow.
It's awful. Maybe there's a --lowvram option that kobold doesn't expose in their GUI, but my processing speeds take a nosedive with Vulkan even with the extra VRAM and you can't isolate the model itself onto the GPUs. ROCm is much better.
13 (0.00/day)
Thanks for the detailed first hand info!
131 (0.28/day)
By the way, NV_coopmat2 is NVIDIA exclusive. Mesa supports KHR_coopmat.
You're very welcome! If you have any extra questions or problems, feel free to ask! :toast:
No sane man should be forced to talk to plebbitors.
