Here is the silent side of the bios
8 GB GDDR6, 1400 MHz GPU, 1750 MHz Memory
www.techpowerup.com
As i thought there is a difference between the 2, its the TDP your quiet bios is 160W and your oc bios is 180W.
Use gpu-z and save your bios files using the arrow to your desktop, make sure to label your quiet bios and your oc bios.
For recovery purposes.
I will look at files now.
@PRGamerDad
Follow these directions,
Remove all GPU Drivers using Display Driver Uninstaller before flashing. (Follow directions)
Use this tool
Download this tool for flashing
AMD AMDVBFlash is used to flash the graphics card BIOS. The version released by ATI was called ATIFlash or just WinFlash. It supports all AMD Radeo
www.techpowerup.com
Flash 1 side at a time and verify the card is powering monitor properly after restart.
Follow these directions closely
Use this bios for the performance Side only
www.techpowerup.com
Use this bios for the Quiet Side only
www.techpowerup.com
Since the Subsystem ID will be changing slightly you will need to do a force flash in an administrator privileged command prompt. (Find cmd in start menu right click and open as administrator)
If that is not performed you may receive the stupid 0FL error.
Then follow this command
Enter this command first
Amdvbflash.exe -unlockrom 0
Then enter this command
amdvbflash -f -p 0 XXXX .rom
Note: XXXX is the name of the VBIOS file you downloaded. You can also change the downloaded file name to a simple name.
This is alternate way:
Create a new text file in your ATIFlash directory, name it FLASH.bat, and place this code into it:
@Echo off
cls
echo Flashing card 0 with BIOS.rom...
echo.
amdvbflash -p 0 -f BIOS.rom
echo.
pause
Assuming the new BIOS you want to flash onto your card is named BIOS.rom, this is the BIOS it will use for flashing.
Save your changes, then run the batch file by double-clicking on it.
Once you've received a success message, reboot your computer for the new BIOS to come into effect. If you can boot into Windows successfully, then that's good! (Note: your screen may flicker for a bit, because you basically have a new card, and Windows is trying to recognize it. If you want to be thorough, go ahead and do a clean re-install of your graphics drivers.)
Last resort methods to flash back, possibly flash forward.
If you need to flashback to a 5700
Use this method (might work for flashing to XT as well)
Not true! For example, on Powercolor, protection is on both BIOS. None of the BIOS can be flashed again! This is not true. I have a powercolor red devil 5700 and I have been able to flash multiple bios to the silent side. OC seems to be the flash once. What particular powercolor model are you...
www.techpowerup.com
www.techpowerup.com
There is a tool powercolor uses but I am blind to how it works, you just extract the tool from the 5600xt file. And use with a 5700/xt bios to flash or flash back i believe. (Delete the 5600xt bios immediately)
