Artifact00
- Jul 20, 2020
- 24 (0.02/day)
hi i just got a new comp that i build it myself
the spec are
b450 tomahawk max
3300x
rtx 2060 zotac amp
team delta 2x8 3000mhz
case phanteks p300 2 fan front intake 1 top out 1 back out
so after building i want to monitor the heat on cpu and gpu
and i found when i play code vein the gpu heat 80 degree is it normal? or gpu are made to run at that heat?
for the game itself i set it as high as possible cause i want play at the best setting on 70fps, thats what i aim with my build
the spec are
b450 tomahawk max
3300x
rtx 2060 zotac amp
