RTX 2070 Super build
Clueless1977
11 (11.00/day)
Was wondering if I was getting everything I can out of my RTX 2070 Super with my current build. Specifically I want to do everything possible to enhance GAMING performance at my monitors native 1440p. It is a MSI G273Q (2560x1440@165Hz). I know, from this website, that the 2070 Super isn't great for 1440p at higher settings - but I want to get the best I can out of it. This is an Acer prebuild, so I am unsure of what can even be swapped out.
My system is:
CPU: Intel Core i7-10700 CPU @ 2.90GHz
RAM: 16.0GB Dual-Channel DDR4 (21-21-21-47)
GPU: 4095MB NVIDIA GeForce RTX 2070 SUPER (Sapphire/PCPartner)
Motherboard: Acer Predator PO3-620 (U3E1)
Storage: 1863GB Seagate ST2000DM008-2FR102 (SATA (SSD)) and 476GB Western Digital WDC PC SN530 SDBPNPZ-512G-1014 (RAID (SSD))
Any advice is appreciated.
1,694 (1.08/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Your current CPU will not bottleneck the 2070S, however the RAM is definitely on the slow side.
According to the manual, the motherboard supports 2666 MT/s memory only (up to 64 GB). But you should be able to run faster modules with much lower timings at reduced speed. A 2x 16 GB 3600 MT/s or 3200 MT/s CL16 kit would be a sensible upgrade.
If you're happy with the performance you're getting, there isn't much more you can do. Update your BIOS to the latest version and make sure the temps are OK.
FreedomEclipse
~Technological Technocrat~
24,277 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
4095MB is a little small for a 2070S.
Toothless
Tech, Games, and TPU!
9,679 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Clueless1977
11 (11.00/day)
They might be using Speccy which doesn't know how to read vram on anything past Kepler it seems.
Yes, I used Speccy. Is there another alternative?
Thanks. After doing some reading on these forms I suspected that RAM was going to be the only thing that would probably be effective. I have two free slots (according to Speccy), so that is probably what I will do.
I also examined the possibility of getting a new GPU, but any ones that I consider affordable (under $500 Canadian) don't even match the 2070 Supers performance. GPU pricing is completely out of control!
711 (1.16/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
My system is:
You will be better off with a GPU upgrade, you have already said you know the 2070S isn't great for 1440p gaming, then buy a GPU, don't buy RAM or CPU expecting a big performance increase in FPS cause at 1440p the limiting factor in gaming is your GPU, do you have a budget? does your pre-built have a PSU as you haven't listed one, what is it's power rating and make/model would be ideal, where are you in the world, this will also affect prices and what you can afford, 10700 (4.8Ghz boost) and 16GB DDR4 aren't that bad and at 1440p will drive more than a 2070s
1,017 (0.59/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
question what games are you currently playing?
Clueless1977
11 (11.00/day)
I live in Canada. Any GPU I consider affordable doesn't give me any performance upgrade worth spending money on. We have 13% tax here and I don't want to spend more than $500 before taxes on an older card. The GPU prices are really crazy. I hope the 5000 series and whatever AMD is doing will drive down prices of the 4000 series...but I have my doubts.
711 (1.16/day)
Buy used, use eBay/PayPal/credit cards so you are protected, am sure a 3080 should be within your budget, spending $500 on a new CPU and platform will net you very little considering your CPU is 8c/16t and not 10 years old, otherwise HODL, keep your money, wait another 6/12 months and see where you are at with GPU's I recently bought my son a 3070 (cost me £260) and he was coming from a 2070s, 25% average performance uplift, sadly the same vRAM but hey that's Nvidia for you, what can you do
Toothless
9,679 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
GPUz, hwinfo64, hell even task manager will say it correctly. Anything from Piriform is dead after they just dropped proper updates for anything.
43,005 (6.72/day)
Good luck with that not happening, prices are being inflated,
2,066 (0.64/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
I'll put this gently. BIOS is your largest hurdle. Prebuilt lock every safety switch and conservative setting into the on position with no way to change their behavior.
Less gently. OEM parts are in almost every instance lower performing than ones selected for retail. Every model differs in how or if "upgrades" will... They really build these things out from the factory order all the way into locking down the firmware on each specific part and it's part in the whole. Call it a negative impact or wheels spinning in the background trying to correct for something no longer in the chain. Just expect less than perfect results.
IF you want to maximize the GPU and gaming. Be completely agnostic and watch for a budget friendly sale on LGA 1700 or AM4 cpu and DDR4 mobo. Carry over everything that can be stripped and plan on finding some higher speed RAM used.
I agree that a different GPU would be an exercise in frustration. We never ever ever come close to suggesting someone spend beyond their means. Shop smart and devote your most valuable resource, time, towards tuning and maximizing stable performance. Play at reasonable settings until the right GPU reveals itself.
28,480 (6.77/day)
My system is:
GPU: 8GB NVIDIA GeForce RTX 2070 SUPER
Looks like a good build. You made a typo though, fix it for you. Can't see anything else that needs help. Buy and enjoy!
43,005 (6.72/day)
My system is:
Get a gpu-z screenshot please
Clueless1977
11 (11.00/day)
Prebuild from Acer bought back in 2021! Just seeing if I could max it out and/or do a mid-life upgrade. Looks like bringing the RAM up to 32GB is going to be the only thing I will be doing unless I find a 3080 or 4070 used at a reasonable price. Need to make sure my power supply would be up to it though.
Clueless1977
11 (11.00/day)
28,480 (6.77/day)
Oh hell yes. If you have 2 empty DIMM slots, drop in a 32GB kit and you'll have 48GB. You have room to upgrade that CPU too. A 10800 or 10900 would give you more CPU headroom. And if that system has a 2070, a 3070 or 4070 would slot right in. Either one would be a solid upgrade. You'd have to shop carefully to find a model that has the same power connector, but we can help there if you would like.
BTW, Welcome to TPU!
Clueless1977
11 (11.00/day)
Oh hell yes. If you have 2 empty DIMM slots, drop in a 32GB kit and you'll have 48GB. You have room to upgrade that CPU too. A 10800 or 10900 would give you more CPU headroom. And if that system has a 2070, a 3070 or 4070 would slot right in. You'd have to shop carefully to fun a model that has the same power connector, but we can help there if you would like.
Thank you so much. What is the power connector exactly? And the new RAM should be of the same model as my current stuff too?
28,480 (6.77/day)
Open your case side panel, take a photo and post it here. I'll highlight it for you. It will be either 1 x 8pin PCIe connector or a combo of 1 x 8pin + 1 x 6pin, maybe an 2 x 8pin.
BTW, here is a list of the CPU's that should be compatible with your system;
Clueless1977
11 (11.00/day)
Thanks man. I will get to it ASAP
99 (0.24/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 speakers, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
Get some more RAM as the others posted before and a Radeon 7800XT (or 6800XT-6900XT used) for the graphics. Make sure that you have 2x8 pin PCIE power connectors available (you most likely have, but better to check before shopping).
