RTX 3000 Series artifacts, black squares that flicker in desktop and 2D mode
76 (0.02/day)
System Name BUILD
Processor INTEL® CORE™ i7-13700K
Motherboard MSI MPG Z790 CARBON WIFI
Cooling NOCTUA NH-D15 chromax.black
Memory 32GB G.SKILL 5600 MHz
Video Card(s) MSI RTX 4070 Ti GAMING X TRIO
Storage 2TB SAMSUNG 990 PRO
Display(s) GIGABYTE M27Q 1440p 170Hz IPS
Case PHANTEKS ECLIPSE P500A DRGB
Power Supply ORSAIR RM1000x SHIFT
Mouse COOLER MASTER MM711
Keyboard CORSAIR K70 RGB TKL OPX
Want to make this post as maybe it will help other users that they think they got a faulty RTX 3000 cards, so if you have this similar issue you can breath relax because your graphic card its ok, the faulty are the nvidia drivers, like any version looks like only afect RTX 3000 series.
There is a issue with artifacts, black/white squares or dots flickering in desktop and 2D mode like more than 1 year old already with RTX 3000 series cards.
At first I tought my RTX 3070 was faulty, so I RMA and I receveid a new RTX 3070 but have same issue. I had the RTX 3070 with the issue from feb 2021 and now from july 2022 I have a new RTX 3080 and after 2 weeks of use, I got the issue again, also in the RTX 3080, so with this card, I tested 3 different cards that all of them has the issue. For me its triggered like 1 per month lets say, and you have to restart PC in order to fix it. I changed DP cable like 3 times aswell just in case.
There is another guy here that posted time ago this issue, he said he RMA his card aswell and the issue triggered for him aswell with the new graphic card.
The issue is very random, there is no chance to reproduce it, the funny fact is that it will have everytime same patron I mean everytime there are some squares that are flickering in desktop, if you move mouse they dissapear, apear again, flickering and most likely the nvidia driver will crash with display has stopped working and recovered. They thend to flicker at same spot every time. Here are some examples of the issue that I found from other users but all of them with RTX 3000 series cards.
1)
2)
3)
4)
5)
I tested bunch of different driver versions, like from beggining of 2021 that I got first time the issue, untill now so there are alot of drivers and all are triggering the issue in certain moment. I did fresh windows install like 10 times , tested windows 10, tested windows 11, nothing works.
1,805 (0.40/day)
Romania
Did you try on another monitor/TV and/or with another display cable ?
76 (0.02/day)
System Name BUILD
Already said I tested like 3 different DP cable, read it with atention, also dosent matter monitor/TV see all the videos, this is from different users with different monitors.
76 (0.02/day)
System Name BUILD
So is there any solution ? If this was a major with all of the users, why didn't Nvidia lunched any fix till now ?
I will like to know, it may not be as major issue as you think, it may affect minority users...and anyway that is another major issue with black flickering bar on RTX 3000 series from 472.12 and still not fixed...
  • Like
Reactions: aQi
1,210 (0.68/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
Try going into your BIOS and force PCIe Gen to Gen 3 (It's probably on Auto by default) and also test with an HDMI cable to see if it's just the display port
5,713 (4.30/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
I've seen this problem before with my 3090, but it only occurs with unstable memory settings. Very easy to reproduce for me, I just set memory to +1000 on Afterburner and try to play a game, after 20 minutes or so this happens without fail. How are your memory junction temperatures?
76 (0.02/day)
System Name BUILD
The thing is I dont have how to reproduce it, for example from the first time that I got the issue, passed like 4 months untill I got the issue again, than after few weeks got it again, other after months again...so it not like its very common ..so It has to wait to long to see if will fix it or not.
is has nothign to do with this, I seen this issue on 3060, 3060 ti, me I got it on 3070 that memory juntion temperature cannot be read and is way lower than GDDR6X, and my self I dont have any kind of GPU overclock. And the most important think its just desktop or chrome/firefox or other internet explorer...but never games
5,713 (4.30/day)
São Paulo, Brazil
Can you try lowering your memory speed a little bit? Even if it's at 0, try like -200, see if it happens again. It's very weird, I know, games run fine, benchmarks score OK. But if my 3090's memory is beyond +800 (1319 MHz in GPU-Z) this artifacting on the desktop/2D always occurs. Of course, if it is happening stock, you have a problem somewhere. Maybe memory running hot, maybe your card needs an RMA.
76 (0.02/day)
System Name BUILD
I told ya I tested 3 different graphic cards, all of them brand new....there is no way I got 3 faulty cards.....and If you read with atention I said that another guy that posted this issue on geforce forum he RMA his card just like me, but got the issue on both....so another guy with 2 different cards faulty ?
freeagent
8,041 (3.72/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
After spending a year with my 3070Ti I can say I haven't seen this.
I think your OC is unstable..
If your card isn't overclocked, I would try as suggested.. lower your memory clock.
76 (0.02/day)
System Name BUILD
Because the issues are not afecting everyone dude, it may be a minority users that we run into this problem so you lucky just that
Why you guys think evertime when see some artifacts that its a GPU memory fault ? Dont be so inocent most of them are dirrectly related to drivers
Just see how many artifacs issues are presented in the latest driver versions...there are bunch more I can keep searching and showing if not enough
So why this issue that im reporting it has to be memory related even I said I got it on differents brand new cards, why cannot be just like any of the below ?
GRD 516.94 (fixed/open issues)
[Chivalry 2] Toggling DLSS preset may cause gameplay to shimmer or show black rectangle. [3692024]
[Prepar3D] Light sources display flashing black boxes. [3684206]
[Forza Horizon 5] Rainbow like artifacts in game after driver update. [3685123]
Monitor may briefly flicker on waking from display sleep if DSR/DLDSR is enabled. [3592260]
GRD 516.59 (fixed/open issues)
[Red Dead Redemption][Vulkan]: Some objects may flicker when player is indoors. [3684575]
[OpenGL] Minecraft Java Edition may display artifacts when using Optifine shaders. [3682262]
[OpenGL] Artifacts may appear in Second Life when connecting using third party viewers. [3682537]
[Neverwinter Nights] Light sources not rendering correctly. [3682841]
[Vulkan] Path of Exile displays flashing black textures. [3682952]
GRD 516.40 (fixed/open issues)
[Assassin's Creed Origins] Game displays flicker when character is under water near a boat. [3642655]
[Jurassic World Evolution 2] Artifacts may appear in game [3682201]
[Vulkan] Path of Exile displays flashing black textures [3682952]
freeagent
8,041 (3.72/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I’ve been using nvidia GPUs for a long time.. never saw that before unless GPU was pushed too hard.
I did see that rainbow road a couple of times in Forza Horizon 5 though lol..
5,713 (4.30/day)
São Paulo, Brazil
Well, I've owned my RTX 3090 since the day they came out, so I more or less have an experience with what it can or cannot do, and what its problems and shortcomings are :)
You're using a Corsair RM750x right? That is a good power supply, I suppose it's enough... so yea, idk what to say man. If after lowering PCIe generation to 3 and testing lower mem clocks doesn't help, I'm out of ideas. Of course, if you are willing to test that and let us know if the problem is mitigated somehow, that is already something to work with. Good luck
76 (0.02/day)
System Name BUILD
No, right now I have RM850x 2021 version I updated it since I upgrate from 3070 to 3080.
But as I said im not really looking for a support here, Im not asking for help, just posted that if someone run into the issue see whats goin on
fybyfyby
5 (0.01/day)
Hi, I bought ASUS TUF 3090 and have very similar issue. I also thought, it is VRAM related....BUT...it does this only on desktop with minimum load. I never saw it in games, benchmarks or furmark or when doing deepML training. I also run vram test without problem. I have stock gpu settings and never OCed it. This doesnt make sense - to have artifacts only when in idle. Temperatures are something like 44-55 degree C. Memory Clock is like 50 MHz in gpu-z.
I have latest studio drivers installed (DDU, clean install). It was also present on game ready drivers. OH and I have latest Windows 10 installed, MOBO is PCIex3 and have Corsair RM750x PSU.
In a week or two I will upgrade to new AMD platform with PCIex4 and RM1000x PSU, so I will wait, if this will be still a problem and potentitaly RMA GPU. On the other hand, I still dont have this issue, when gpu is heavy used, so...I really dont know, if it is really an issue. Its only annoying for a while.
5,713 (4.30/day)
São Paulo, Brazil
I've had this exact problem with my TUF OC 3090 too, best of my knowledge this is caused by unstable memory setting. Usually this manifests after closing a 3D application when the memory clock is too high. I get this 100% after benchmarking with +1000, I find my card likes to run at +800 mem clock.
If your 3090 doesn't have a memory overclock applied, this could be bad. Since you already cleared drivers I'd be fresh out of ideas, did you try the other BIOS by flipping the switch and seeing if the behavior is the same?
fybyfyby
5 (0.01/day)
I didnt do anything with card. I even dont know on which side the switch is :). But its strange, theres no problem in 3d games (like CP 2077), machine learning, furmark, occt vram test or other vram tests. And this can be seen only on desktop and even when the card is idle (all fequencies down). I will experiment a bit when my new HW arrives.
Only thing that isnt fresh is my Win10 install. When new HW comes, I will instal fresh Win10 or 11.
76 (0.02/day)
System Name BUILD
You will RMA the card and you will face the same issue with the new card they will give you
5,713 (4.30/day)
São Paulo, Brazil
It's this switch that says performance and quiet mode. By the way I assure you that I'm not mining, rig is just a wreck under a complete rebuild and repair process
5,889 (2.95/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
1,077 (0.36/day)
System Name Main System
Processor i9-10940x
Motherboard MSI X299 Xpower Gaming AC
Cooling Noctua NH-D15S + Second Fan
Memory G.Skill 64GB @3200MHz XMP
Video Card(s) ASUS Strix RTX 3090 24GB
Storage 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600; 2TB Samsung PM981a
Display(s) Dell U4320Q; LG 43MU79-B
Case Corsair A540
Audio Device(s) Creative Lab SoundBlaster ZX-R
Power Supply EVGA G2 1300
Mouse Logitech MK550
Keyboard Corsair K95 Platinum XT Brown Switches
Benchmark Scores Cinebench R20 - 6910; FireStrike Ultra - 13241; TimeSpy Extreme - 10067; Port Royal - 13855
I have had ASUS 3090 strix since launched, switched to evga 3080 ftw3 ultra for 6 months, and now evga 3090 ftw3 ultra for 1 month, no issue so far. It is your setup if you have this flickering problem.
76 (0.02/day)
System Name BUILD
Then it's not the card.
Ofc its not, I already stated I change 2x 3070 and one 3080 and all have the issue in my case, but people always say VRAM , VRAM VRAM when they saw some graphic glitches...withot knowing whats the issues about
268 (0.29/day)
Georgia, United States
System Name LMDESKTOPv2
Processor Intel i9 10850K
Motherboard ASRock Z590 PG Velocita
Cooling Arctic Liquid Freezer II 240 w/ Maintenance Kit
Memory Corsair Vengeance DDR4 3600 CL18 2x16
Video Card(s) RTX 3080 Ti FE
Storage Intel Optane 900p 280GB, 1TB WD Blue SSD, 2TB Team Vulkan SSD, 2TB Seagate HDD, 4TB Team MP34 SSD
Display(s) HP Omen 27q, HP 25er
Case Fractal Design Meshify C Steel Panel
Audio Device(s) Sennheiser GSX 1000, Schiit Magni Heresy, Sennheiser HD560S
Power Supply Corsair HX850 V2
Mouse Logitech MX518 Legendary Edition
Keyboard Logitech G413 Carbon
VR HMD Oculus Quest 2 (w/ BOBO VR battery strap)
Software Win 10 Professional
My 3080 TUF had the black rectangles twice. Once after I had recently got it (last summer) and week or 2 ago. That being said I've seen similar rectangles when overclocking my old 980 and having an unstable memory clock,
ir_cow
4,098 (0.70/day)
USA
I had this issue before from overclocking memory, also from the video card not being seated in the PCIE slot fully.
