RTX 3060 on P8Z68 Deluxe boot problem.
Shadowbuddy
2 (0.00/day)
Hello there!
My RTX 3060 stopped working on P8Z68 Deluxe.
Since I changed my GTX1060 to my new RTX 3060 the board already presented some incompatibilities, everytime I restarted my PC it didn't boot, I had to remove the battery, clear the CMOS for it to work again.
Then I formated my PC today and the MOBO simply does not boot due to the RTX 3060 being connected on it, I tried a backup board I have for emergencies (GT 630) and it worked fine, even allowing for resets without a problem.
I had this MOBO for many years and never had big problems with it, and considering it will cost A LOT to upgrade since I'll have to change the MOBO, memory sticks and my CPU, I would like to see if there are any options left.
Any help is appreciated!
463 (0.31/day)
Earth, Solar System, Milky Way Galaxy, Local Group
Processor AMD Ryzen 7 5700X
Motherboard Asus TUF Gaming B550M-Plus (Wi-Fi)
Cooling Thermalright PA120 SE; Arctic P12, F12
Memory Crucial BL8G32C16U4W.M8FE1 ×2
Video Card(s) Sapphire Nitro+ RX 6600 XT
Storage Kingston SKC3000D/2048G; Samsung MZVLB1T0HBLR-000L2; Seagate ST1000DM010-2EP102
Display(s) AOC 24G2W1G4
Case Sama MiCube
Audio Device(s) Somic G923
Power Supply EVGA 650 GD
Mouse Logitech G102
Keyboard Logitech K845 TTC Brown
Software Windows 10 Pro 1903, Dism++, CCleaner
Benchmark Scores CPU-Z 17.01.64: 3700X @ 4.6 GHz 1.3375 V scoring 557/6206; 760K @ 5 GHz 1.5 V scoring 292/964
Maybe due to UEFI settings?
Is there any setting called CSM something?
You know 2nd gen Core has come a long way, surely there could be some weird problems.
42,716 (6.69/day)
Hello there!
Try this.
Shadowbuddy
2 (0.00/day)
463 (0.31/day)
Case Sama MiCube
Mouse Logitech G102
I don't know what UEFI means or is, could you explain, maybe knowing what it is I can work with it?
Well, you can consider UEFI a new generation of BIOS and it replaces legacy BIOS.
Older mainboards and hardware are more legacy-BIOS-compatible while newer ones mostly use UEFI.
I think this is probably where it goes wrong.
Try looking for CSM settings. It can help with the compatibility with older hardware. Or the VBIOS of your card simply doesn't work with your board...
I can't remember the exact things in this mainboard, you know it's been a very long time since the time I used this board.
