RTX 3070 fan at max speed al the time
5 (0.00/day)
Processor Intel Core i5 10400
Motherboard HP 8704 (U3E1)
Memory 16gb16 GB DDR4 Hyperx 2 666mHZ
Video Card(s) HP Geforce RTX 3070 Ga104-300
Storage 500 gb m.2 ssd
Display(s) AOC 24 curved
Case HP omen 25L
Power Supply 500 W strømforsyning
have an rtx 3070 with 2 gpu fans, sudently after a reboot, on of the fans goes to max with 0 gpu load. I cant adjust the fan speed in msi afterburn. The second fan start spinning when gpu is loaded.
Have tried benchmark it and the gpu is working fine.
there are the thing i have tried:
- Clean DDU driver install
- Reinstalled msi afterburn
- reinstall windows
- disconnected the card and removed dust and checking the wire(works fine)
if i roll back drivers or remove drivers, the fans goes to normal. if i reboot the pc, the fans stopped and goes to max when i boot into windows.
Possible something wrong in bios?
anyone got the same issue?
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Either
  • the cable to the fan has come loose in the GPU
  • software is controlling it (Afterburner, EVGA precision, etc)
  • you have a GPU miner, hiding its usage
Does HWinfo64 give you readings for RPM from both fans?
5 (0.00/day)
Case HP omen 25L
have deleted al software like afterburn ect.. do not get any reading of rpm on the fan who is running max..
Mussels
58,413 (7.87/day)
Oystralia
Yes but do you get one or two readings?
Even at 0RPM, knowing if theres one or two RPM sensors will help
Get HWinfo, have a look.
Then take out the GPU and inspect the physical wire that goes between the fans, it's somewhat common for one side of a fan plug to come loose leading to weird fan behaviour
5 (0.00/day)
Case HP omen 25L
Does this tell you anything?
Mussels
58,413 (7.87/day)
Oystralia
It shows one GPU fan, at 33% - while the GPU is at low load, and cold (so, not a bitcoin miner)
If the fan was at 100% while that was happening, that means the connectors physically loose
You didn't specify what model 3070, so its hard to give precise information here
Regeneration
NGOHQ.COM
3,135 (0.45/day)
Check thoroughly the fan's wire and headers for any damages.
Check the vendor website for VGA BIOS updates and try to contact their support.
If its not too complicated for you, you may try to locate the latest BIOS from the TPU database.
6,165 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
5 (0.00/day)
Case HP omen 25L
it only shows gpu fan 1, and i have 2. the fan show 30% but i am sure the fan goes to 100% , its so loud! the other fan is just spinning for 1 sec then stops..
wiring is okei
no damage
installed vga bios
updated bios
no changes.. Thanks for quick respond, and sorry for poor info
spec:
GPU: HP Geforce RTX 3070 Ga104-300
CPU: Intel Core i5 10400
RAM: 16 GB DDR4 Hyperx 2 666mHZ
Motherboard: HP 8704 (U3E1)
powersuply: 500W
Windows 11
Mussels
58,413 (7.87/day)
Oystralia
OEM cards are lots of fun
I'm going to assume yours looks like this?
You need to follow the wiring for both fans and see what they connect to, often theres a Y splitter between them and it's a common place to come loose, even the slightest amount can cause your problem
8,224 (2.14/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I recall a feature for some card, I forget, that one fan was supposed to shut off when the card not under load.
Are you sure its the graphics card fans and not a case fan thats loud?
5 (0.00/day)
Case HP omen 25L
100%!! broke the fan under cleaning today :( so now no fans runs.
But still shows 33%. Fucking shit. It wil not update vbios. All wiring was good. Starting to get pissed of this shit.Should have deleted absolutly everything on the pc inkluding bios, vbios, drivers, u name it.
Do i loose my waranty because i broke the fan?
and last, couldnt find the same fan as i broke , NR of the fan: T129215bu. The fans i fond with the same nr was only supporting gtx 1060 ect.. can i use a diffrent fan with different nr?
Feel free to send me link of what fans that fit my rtx
Thanks for the respond!
43,301 (6.74/day)
Damaging a component can void a warranty, get a replacement fan. DO NOT FLASH THE BIOS!
Mussels
58,413 (7.87/day)
Oystralia
Shite, that sucks
That Y joiner is usually the problem... you can try warranty (dont say you opened it, say the fan seized and fell out) - or you can replace the fan
The fans are common and have been used for many, many GPU models (especially with gigabyte) so they're cheap, $12 for a 3 pack here
These guys have HP 3090 fan replacements, but they dont match how yours seem to attach
HP Graphics Card Fan Replacements – GPU Fan Replacement
Inrobert has fans from other 3070 models, but i dont see one with your strange mount
8 results found for "3070" – inRobert
I guess what you need to look out for, is how they attach to the GPU: get a replacement with matching screw holes
Edit: and i'm no expert with those fans... but can it simply be reassembled?
The GPU itself will run with no fans attached directly to it, as long as its cooled.
Technically any fan that fits and is powered (even powered externally) will work to keep the card fine. Look at some of the youtubers who modded their GPU's to use noctua fans, as an example (Yes, that would void the warranty - but would fix the card and let you keep using it)
Reddit link and IMGR library of someone who did exactly this:
Aurora 3080 GPU Fan Replacement : Alienware
Imgur: The magic of the Internet
