ShadowChild
- Sep 26, 2020
- 5 (0.00/day)
Hi evevryone, first sorry for my bad english I'm french
. I have a really big problem of frametime spikes (that leads to stuttering). I have this problem with my brand new RTX 3080 and my old GTX 1060.
Here is my setup:
Aorus b550 pro ac
Ryzen 7 3700x
RTX 3080/GTX 1060
Corsair rm 750x PSU
Gskill trident z neo 3600mhz CL18
Sabrent 4.0 nvme
What I have done :
-Reinstalled Windows Multiple Times (Even on New SSD) Reinstalled GPU drivers (Used DDU for clean install without Geforce Experience)
-Updated Bios/ MOBO Drivers (Audio/LAN/Chipset)
-XMP On/Off - No difference
-Disabled All In-Game Overlays
-SWAPPED EVERY SINGLE COMPONENT IN MY PC (GPU, CPU, MOBO)
-Closed all unessessary background processes
-Turned on High Performance Power Plan in Windows
-Messed with every combination of Enabling/Disabling Gsync and Vsync - stutter still occurs in any configuration
-Tried capping fps at lower values (144, 120, 60) - stutter still occurs
-Plugged PC into different wall outlet in case this is somehow a power issue. Had no effect.
-Disabled HPET
-Disabled C States
-Tested on Other - no difference
-Used different Display port - no diff
-Play games in Offline mode - no effect
-Ran Memtest86 - no errors found
-Turned game settings all low - no effect
Notes :
-My Temps are under 70
-Cpu usage is not the bottleneck
-Disabling fullscreen optimization for each game lower the frametime spikes but the problem is always there
Here you can see the frametime :
Example 1 : Exameple 2 :
Here is my setup:
Aorus b550 pro ac
Ryzen 7 3700x
RTX 3080/GTX 1060
Corsair rm 750x PSU
Sabrent 4.0 nvme
What I have done :
-Disabled HPET
-Disabled C States
Notes :
