RTX 3080 NO display if boots with display and hdmi are plugged in
5 (0.01/day)
System Name Gaming pc
Processor I9-10900
Motherboard MPG Z490 Gaming Edge WIFI
Cooling Noctua NH-U12
Memory corsair vengeance rgb pro 32gb 3200mhz
Video Card(s) KFA2 RTX 3080 10GB (Gaming/rendering GPU)/ASUS DUAL EVO 2070 SUPER 8GB (Streaming GPU)
Storage 250GB 970 EVO PLUS (OS) 1TB 970 EVO PLUS (Game drive) 2x 500GB 7200RPM Recordings
Display(s) MSI 144HZ 1080P 1MS (MAIN DISPLAY) B2440 60HZ 1080P 5MS X2 (OBS DISCORD ETC)
Case NZXT H510 WHITE
Power Supply Corsair RM1200x SHIFT
Mouse logitech g pro wireless
Keyboard Hyper X Origins
VR HMD RIFT S
Software WINDOWS 10 PRO
Hi all I got a weird problem that just occured with my RTX 3080.
If i boot my pc with any outputs such as hdmi or DP the gpu wont display an output however if i boot it without any cables then plug in my cables it will display and run like normal.
No clue why i even did a ddu wipe and used geforce experience to update a possibly corrputed driver i use three mointors and having to unplug them and replug them back in everytime i wanna use my pc is not fun.
Before this happend i was playing in VR playing blade and sorcery and watched a movie afterwards and shut down the pc as normal. i've also done all the bios stuff recommend by youtube and this has not changed the weird behavour.
any help whould be great as this is weird behavour and thinking is my gpu dying in some way?
Thanks
2,815 (4.68/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
No idea. Watching this thread out of pure curiosity.
2,000 (1.00/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Audio Device(s) Yamaha YSP-800 DSP soundbar/Bowers and Wilkins P7 Headphones
Software Windows 10 Pro X64
Benchmark Scores Who cares
Thanks
Does it do the same if you boot into the bios?
5 (0.01/day)
Processor I9-10900
VR HMD RIFT S
It's hit or miss sometimes bios will show with no need to remove my cables but then sometimes i need to remove it.
To sanity check i have even bought new cables and plug them in incase one of them has gone faulty and causing this issue and these cables have not fix the issue.
i have also changed pci e power cables with ones left my in my gpu box so there brand new and this also have not fixed it
i also have a RTX 2070 super in the system as a recording/streaming GPU and this gpu does boot right away no issue.
i have also tested my 3080 in a sparce pc and its the same hit or miss with boots with hdmi and dp.
i honstly think my gpu is dying in some way and am out of warrenty am sure.
I also ran Port Royal stress Test when booted in my main system and it ran the full 20 loops and FPS Stability 98.4 % not sure this will help but it does not crash under ray tracing load
thanks
8,840 (3.28/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Sounds like a handshake issue. It could be the cable but that does not really make sense. What it could be is a connection but does it effect every single port?
1,225 (0.18/day)
Malaysia
Motherboard ASUS A520M-K
Display(s) AOpen 27HC5R 27" 1080p 165Hz
Case AIGO Darkflash C285
Do you mean just boot your PC without any cable plugged in, then you plug after it load Windows? My 3080 'died' after it loads windows driver and I need to remove the card physically before it being detected again, but even so it still 'died' after some time. I have no idea what caused this too. the DP cable works on my 1070 no problem so idk what's the problem is
5 (0.01/day)
Processor I9-10900
VR HMD RIFT S
Yes if no cables are plugged in it boots with no issue and works like normal.
It only has the issue if i leave them pluged in but windows does load as my vr and keyboard are active and i can even use the vr but it like my mointors are blind to the card
If i leave any cable in the gpu during boot no display the only way am getting output is to put my cables in after boot
2,000 (1.00/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Sounds like your 3080 is on the road to hell unfortunatly. If it does the same in another machine it kinda confirms it.
3,775 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
Does it do this with all the DP ports? Did you try switching ports during a no video boot session?
5 (0.01/day)
Processor I9-10900
VR HMD RIFT S
From what i gathed it like all ports are somehow disabled during boot and when windows boots there activated but having any ports in keeps the ports disabled
That's what i feared i might consider selling the gpu on ebay as faulty and use some of the funds off ebay to go towards a 40xx card or get a 3090ti it a shame all of a suddon my card gone like this
3,775 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
I've seen this from time to time. I had it on a Titan XP which would refuse to show any screen till its booted. It was a huge pain in the ass during bios updates as you can imagine. It was simpler to swap to an old 1080p panel just for bios work. Coincidentally the Titan died and was replaced by a 7900XTX and now, like da hell, system boots fine with the same panel. I suspected it was the cable, or this or that, but then it boots fine with a newer card.
101 (0.07/day)
@Hazyballoon do you have fast boot enabled in bios? If so, disable it. Youre suppose to turn your monitor on before you boot your tower anyway, so make sure you do that after you reboot the bios. I would def try a rollback of the OS before i said its the gpu at least.
5 (0.01/day)
Processor I9-10900
VR HMD RIFT S
Hi all so i think i fixed my issue not 100% though.
I unistalled my vr software thinking that could be somehow overrideing something as i read on reddit that can happen if oculus is set as high priorty which it was for performace . And after unstalling the software i have had four successful boots with all cables connected so hopefully it working now but still wanna use my vr some hopefully a reinstall of oculus will not break again.
Thanks guys for taking time out your day to assist me it's much appreciated
101 (0.07/day)
Thats good to hear! A big thank you to you too for actually returning and giving a THANK YOU to the people who helped and a update of your progress. Most people get their answer, it works and they disappear. So congrats on being one of the few respectful people. :peace:
230 (0.18/day)
Scotland
System Name Scan 3XS System
Processor Intel Core i7 11700K
Motherboard ASUS TUF GAMING Z590-PLUS WIFI
Cooling Corsair Hydro H150i ELITE CAPELLIX RGB
Memory 16GB Corsair Vengeance RGB PRO
Video Card(s) 10GB EVGA GeForce RTX 3080 XC3 ULTRA GAMING
Storage 1TB Samsung SSD 970 EVO Plus, 2TB Seagate HDD, 240GB Kingston SSD
Display(s) Samsung C32JG5x Curved, 1080p, 1920 x 1080
Case Corsair iCUE 4000X RGB
Audio Device(s) USB Speakers 2.1
Power Supply Corsair RM750x 80PLUS GOLD
Mouse Razer Mouse
Keyboard ROCCAT Horde
Software Microsoft Windows 11 Pro 64-Bit 23H2
Had that happen last year, replaced my cable and its been working so far without any prob's..
MrShark_59
2 (0.01/day)
did u try plugging the dp/hdmi port into the gpu? bc when i got my pc i did not know where to plug it in.
