RTX 3090 issue. Input welcome. SOLVED
2,938 (0.50/day)
Riverside, California
Motherboard AsRock X670E Phantom Gaming Lightning
Cooling Be Quiet! Dark Rock 4
Memory G.SKILL Trident Z5 Neo DDR5-6000 32GB (2 x 16GB)
Video Card(s) Sapphire Radeon RX 7900 XTX
Storage Samsung 980 PRO Series 1TB, Samsung 980 PRO Series 1TB, Crucial P3 NVMe M.2 2TB
Display(s) LG OLED55G2PUA
Case Lian Li O11 Dynamic XL ROG Certified
Audio Device(s) Digital out to high end dac and amps.
Power Supply EVGA GQ 1000W
Mouse Logitech G600
Keyboard Logitech G413 Carbon
VR HMD Oculus Rift CV1, Oculus Rift S, Quest 2, Quest 3
I picked up a 3090 today. It is working fine but I wanted to install fresh drivers but no matter what I do, during the driver install my PC crashes. Currently, have 460.79 installed from my GTX 1080 ti. used DDU to do a cleaning, rebooted, and tried to install the latest drivers, get a blue screen. Updated BIOS and mobo drivers, windows 10 fully updated and the latest version, disconnected web, but nothing works. Crashes every time during driver install. Also the entire time the card did not detect that my monitor supports 4k and showed the highest resolution as 1080p.
After a dozen tries, I gave up, popped my 1080 ti back in, reinstalled the latest drivers, and then did some more research into this issue. I read that some people had success by going into the BIOS and setting the PCI-E slots from auto to Gen 3 (that's the latest my board supports) and after doing that and reinstalling the 3090, once I reached the desktop it loaded up at 4k. I thought I was good to go but then tried to do a clean install of the nvidia drivers again and yet again got a blue screen crash for my troubles.
So right now my pc and 3090 are working fine but I cannot update drivers. Does anyone know what is going on? I thought maybe it was a mobo compatibility issue or a windows issue but I'm at a loss.
Honestly about ready to build a new PC tomorrow with the latest and greatest but I really wasn't planning on building a new PC. My specs are up to date so if someone has any input, I am all ears. I rarely have to seek advice on PC problems but this one has me baffled.
By the way, holy cow Cyberpunk runs awesome on this 3090!!! Looks awesome, runs awesome! What an improvement over the 1080 ti.
Rei
656 (0.40/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
Have you tried using DDU in Windows Safe Mode?
Also are you using the driver provided by Zotac's website (which I assume is your GPU's brand) or from Nvidia's website? You should try Zotac's provided driver first as Nvidia recommends before using Nvidia's own "generic" driver.
2,938 (0.50/day)
Mouse Logitech G600
I used DDU in safe mode yes and tried both the latest Nvidia driver and the one on Zotac's website. This is such a strange issue.
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
What is your psu?
2,938 (0.50/day)
Mouse Logitech G600
Corsair HX1000i
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
Did you use the standard Windows driver type or DCH Windows driver type? It seems like the one from Zotac's website is a DCH type & an older version at that as well as directly linking to Nvidia's website but should be the most compatible version. My assumption is that Nvidia's own newer version (460.79) of the driver is not yet compatible with your GPU so you should use the version (457.51) recommended by Zotac. If all else fails then I'm outta ideas. Sorry...
Corsair HX1000i
Well, clearly your PSU should be more than capable of handling you rig so no problem there.
2,938 (0.50/day)
Mouse Logitech G600
The driver installed is DCH Windows driver. I am not sure if the Zotac driver is or not but I tried installing it multiple times but my PC keeps crashing during install.
129 (0.06/day)
Processor i9 10900K
Motherboard ASUS Z590 E-Gaming
Cooling CPU AIO - EVGA Liquid cooled GPU - Air cooled
Memory 32GB
Video Card(s) Zotac RTX 3090 Ti Holoblack (NTK female pins in the cable that came with the GPU)
Storage Too many to list here !!!
Display(s) 32" Samsung 4K (Smart Monitor)
Case Obsidian 500D
Audio Device(s) Monitor - see above
Power Supply EVGA 1000 watt
Mouse EVGA X17
Keyboard EVGA Z15
Software Win 10
You need to install the Standard Drivers and not the DCH drivers.
Removing the DCH drivers can be a pain in the butt...... they need to be purged from the system with DDU, you might need to remove the card from the system as well.
Make sure the PC is not connected to the internet when you install the drivers.
Get the Standard Driver from this link. (Do not install the Studio Drivers.)
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
It isn't the one provided by Zotac. The one from Zotac is version 457.51 but the one you have as shown on your screenshot is version 460.79 which should be the latest. Does that mean that its already installed then? Try the standard driver type if it's not working.
129 (0.06/day)
Processor i9 10900K
Memory 32GB
Case Obsidian 500D
Mouse EVGA X17
Keyboard EVGA Z15
Software Win 10
The 460.79 drivers do work with the card, but they must be the Standard Drivers.
1,194 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
Strange thing about driver issues it is often connected with users with Windows 10 Home - wonder if theres is something there
2,938 (0.50/day)
Mouse Logitech G600
I didn't know that. I just downloaded the standard windows driver and will attempt the install. brb
@STSMiner
You the man! I wasn't aware that nvidia had a new style of the driver in cahoots with Microsoft. I located the standard windows version, downloaded it, and tried installing, CRASHED again! Then I went into safe mode and used DDU, got back into windows after rebooting and before I could try to install the nvidia drivers again, Microsoft installed the latest DCH driver without my permission! Again rebooted into safe mode, used DDU, disabled web, rebooted, tried installing just the drivers (windows standard) and it worked!! All is well!
I can't thank you enough, I would not have thought nvidia had two types of drivers and that their standard DCH driver was not compatible. I owe you a beer! :toast:
I want to thank the rest of you as well. I appreciate the help!
129 (0.06/day)
Processor i9 10900K
Memory 32GB
Case Obsidian 500D
Mouse EVGA X17
Keyboard EVGA Z15
Software Win 10
@STSMiner
@WhiteNoise
Your welcome !
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
@STSMiner Cheers to you mate.... :clap::peace:
@WhiteNoise I suppose the next time you update your driver, be sure to get the standard driver type from Nvidia's website. Most likely you won't need to use DDU or even uninstall your previous driver or even need to disconnect from the internet. Or you could use GeForce Experience to update your driver.
6,775 (0.94/day)
Republic of Asia (a.k.a Irvine), CA
System Name ---
Processor FX 8350 @ 4.00 Ghz with 1.28v
Motherboard Gigabyte 990FX-UD3 v4.0, Hacked Bios F4.x
Cooling Silenx 4 pipe Tower cooler + 2 x Cougar 120mm fan, 3 x 120mm, 1 x 200 mm Red LED fan
Memory Kingston HyperX DDR3 1866 16GB + Patriot Memory DDR3 1866 16GB
Video Card(s) Asus R9 290 OC @ GPU - 1050, MEM - 1300
Storage Inland 256GB PCIe NVMe SSD for OS, WDC Black - 2TB + 1TB Storage, Inland 480GB SSD - Games
Display(s) 3 x 1080P LCDs - Acer 25" + Acer 23" + HP 23"
Case AeroCool XPredator X3
Audio Device(s) Built-in Realtek
Power Supply Corsair HX1000 Modular
How to download the standard windows version? On NVidia's driver download page I only see 2 options in the drop down - 'Game Ready' and 'Studio'.
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
On that page, click the "Beta and Older Drivers" instead. That page shows a more consistent & complete listing of drivers.
Here is the link to go to that page:
6,775 (0.94/day)
System Name ---
Thanks.
Which one to choose?
  • Like
Reactions: Rei
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
Thanks.
Obviously the top most one are the one to pick as they are the latest which you should use for a bug-free operation & optimized for the latest games. Also are you primarily doing gaming task or studio-esque production workload on your PC? Use the "Game Ready Driver" for the former & "Studio Driver" for the latter. While those two types of driver work fine interchangeably, each is better optimized for specific set of workload.
LittleKingCurio
2 (0.00/day)
I registered just to respond to this thread. I am desperate! "WhiteNoise" has the exact same problem with the DCH drivers I am having and reverting back to the standard drivers has resolved my issue as detailed in this very helpful post. However, Nvidia will not be releasing any more standard drivers and will only publish DCH from now on. My efforts are now trying to understand why all of the further Nvidia DCH driver releases of crash my system. The last stable driver Nvidia 472.12 and any later release causes the same issue.
I have done an enormous amount of troubleshooting and am still at a complete loss. I have two 3090s at this point, one EVGA and one Asus. I even sent the Asus off to RMA before I could establish it as a driver issue. Both exhibit the same behavior. I have updated the graphics cards firmware and the motherboard firmware. I have tried on a fresh install of Win10 and a fresh install of Win11 (as well as on old image backups). If I plugin to my motherboard HDMI, the system will boot and it will let me install any driver version I want, but the moment I switch the cord to my graphics card it will lock up and freeze upon boot. If I am plugged in to the graphics card and attempt to install the newer drivers it will lock up the same way during the driver installation.
At this point, I use DDU in safemode to remove the newer drivers and re-install back to 472.12 and it works. Asus, EVGA, and Nvidia have so far been unable to assist or provide me with any information. This obviously isn't happening to every 3090 user on the latest DCH drivers, so I am trying to understand what about my system is unable to install ANY version of Nvidia DCH drivers without complete card failure.
3,827 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
That is weird. I've been on DCH drivers since the beginning w/o issues. I'm using a FE card.
LittleKingCurio
2 (0.00/day)
I just found the solution, moments after my previous posts.
For me, the holy grail answer was - You cannot install the DCH drivers over the top of the Standard drivers (although Nvidia documentation stated this was OK). You must use DDU to completely remove the Standard drivers in safemode, then after restart, the newest DCH drivers installed without issue.
I hope this helps anyone struggling with the same issue.
2,938 (0.50/day)
Mouse Logitech G600
Yeah, I use DCH now and have been for a long time. I have never had an issue again since the original issue I had in this thread. I'm currently using the latest drivers and I am on Windows 11 too.
1,960 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Short version :
1) Download driver You want (Standard up to 472.12 or latest DCH),
2) Disconnect internet,
3) Install new card,
4) Install driver You want/downloaded
5) Profit ?
