RTX 4060 8GB OC massive fps drop
108 (0.21/day)
Processor AMD Ryzen 5 5600G
Case NX
Mouse Razer Viper 8khz,
Keyboard Rapoo
Hello!
My problem would be that, for example, in csgo everything is low and in 1024x768 there is a maximum of 400 fps and sometimes ledropol sometimes goes to 280, why is this?
Processor: AMD Ryzen 5 5600g 6 Core 12 Threads
RAMS: 2x8gb(KIT) Kingston FURY Beast 16GB DDR4 3200MHz KF432C16BBK2/16
Videocard: GIGABYTE GeForce RTX 4060 8gb OC
SSD:(IN WINDOWS AND 2 GAME): Samsung SSD 850 EVO 250GB
SSD2: Kingston 2000GB M.2 NVMe 2280 PCIe 4.0
HDD1: TOSHIBA DT01ACA100
HDD2: TOSHIBA DT01ACA050
Monitor: BenQ ZOWIE XL2566K 360 hz
1,829 (0.60/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Card/CPU goes into 2D/Idle mode due to too low usage ?
Check GPU/VRAM clock with afterburner.
1,852 (2.67/day)
Brazil
System Name G-Station 1.17 FINAL
Processor AMD Ryzen 7 5700X3D
Cooling DeepCool AK620 Digital
Case Thermaltake Level 20 MT
Mouse Razer Viper Ultimate
As good as a 5600G is, is Cezanne capable of mantaining extreme framerates for long?
269 (0.71/day)
Processor AMD Ryzen 5800X3D (undervolted)
Memory 2x16 GB G.Skill DDR4 3600 CL16
Video Card(s) Gainward RTX 4090 Phantom
Display(s) 27" 1440p 144Hz VA main (w/ strobing / HDR600), 55" LG OLED Evo secondary for controller based games
Audio Device(s) SB X AE5 + Logi Z906 THX + HIFIMAN Sundara / Denon AV Amp X3800H + Atmos Speaker Sys in a 5.1.4 cfg
Mouse Logitech G502 x Lightspeed
Keyboard Razer Huntsman V3 Pro TKL
Software Win 10
Suboptimal game design, could be water for example which drops your fps.. in other words, it's the game.
108 (0.21/day)
Case NX
Keyboard Rapoo
WTF XDDD random?? and random memory up MEM: 8500MHz and drop 405
random up MEM AND GPU
i dont understand :DD sorry
Water? no!
In game.
3,085 (1.04/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Hello!
You are likely CPU bottlenecked. CSGO is heavily CPU reliant. If you want less dips get a Ryzen 5800X3D. You have a g model 6 core, which has worse performance than the X and non-x models due to the reduced cache.
WTF XDDD random?? and random memory up MEM: 8500MHz and drop 405View attachment 308423
You have to enable monitoring to see clocks over time. Simply looking at the program while alt-tabbed out of the game will put your card back into 2D clocks.
108 (0.21/day)
Case NX
Keyboard Rapoo
It does this even if there is no game running
3,085 (1.04/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
You are referring to the clocks correct? That would be normal behavior if so.
