RTX 4060 High Power Consumption
Trindade31102022
5 (0.01/day)
have the RTX 4060 MSI Gaming X, and it has a high consumption problem when not in use. staying at 50w. I didn't find any solution for this.
Does anyone have a solution?
Config:
MSI B450M-Mortar MAX
Ryzen 5700x
16gb ram
Win10 PRO
7,310 (3.15/day)
California
System Name His & Hers
Storage lots of SSD.
Hopefully someone more knowledgeable on PWR_SRC but from my understanding it's the gpu power plane and somthing to do with input power. Considering the tdp is reading 0.0% my guess is it's not reporting properly. What's the power supply being used and do you have a spare to rule out the same behavior.
Trindade31102022
5 (0.01/day)
Power Supply: Gamemax GP650 650W, 80 Plus Bronze, PFC Ativo
is not the source.
Before I was using a 1660 super, and it consumed 10w
I saw some videos on YouTube, and the 3060 consumes 20w
7,310 (3.15/day)
California
Only 40 series card I have that I can compare is a 4090 which you can see the same PWR_SRC is much lower and you'd think given it is a much larger gpu it would be higher. My chrome was even up during this.
Have you tried contacting MSI support?
Panameras918
2 (0.00/day)
In nvidea profile inspector set "power management mode" to Adaptive. After set max performance for any game in nvidia control panel :)
CarpeDiem4396
1 (0.00/day)
Config:
Ryzen 5700x
16gb ram
Win10 PRO
My 2060 is the same. There is no need to worry too much about this. 40w is not very high.
