rtx 4070 when to worry about gpu hotspot and mem temps?
184 (0.09/day)
El Salvador
hi there i wanted to know at what point i need to concern myself with the gpu hot spot and memory temps for the gpu, i usually play cyberpunk 2077, but after the new update and driver update ive noticed that cpu and gpu gets a bit hotter now.
usually the gpu is around 62+65c° on gpu temp while on hotspot can reach depending on the situation around 82ish one time it reached to 84 as you can see there but it was for a moment.
cpu gets around 65+ to 70c° or so (ryzen 7800x3d)
ignore the current because im playing something lighter in comparison to cyberpunk 2077.
thanks for your time.
417 (1.77/day)
System Name XPS, Lenovo and HP Laptops, HP Xeon Mobile Workstation, HP Servers, Dell Desktops
Processor Everything from Turion to 13900kf
Motherboard MSI - they own the OEM market
Cooling Air on laptops, lots of air on servers, AIO on desktops
Memory I think one of the laptops is 2GB, to 64GB on gamer, to 128GB on ZFS Filer
Video Card(s) A pile up to my knee, with a RTX 4090 teetering on top
Storage Rust in the closet, solid state everywhere else
Display(s) Laptop crap, LG UltraGear of various vintages
Case OEM and a 42U rack
Audio Device(s) Headphones
Power Supply Whole home UPS w/Generac Standby Generator
Software ZFS, UniFi Network Application, Entra, AWS IoT Core, Splunk
Benchmark Scores 1.21 GigaBungholioMarks
You’re fine.
Unless you’ve broken your video card you don’t need to worry about temperature, your card will manage itself.
184 (0.09/day)
El Salvador
You’re fine.
thats good to know, but at which point i need to take a concern temps wise for hotspot or gpu memory ? just to get a better grasp of it thats all.
3,572 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
At 84, I'm starting to get gray hair.
Most people start doing it in much younger age.
OP, your temps are completely fine. Concerning temperatures: 83C and hotter on the GPU die; 95C and hotter on VRAM; 85C and hotter on CPU; 95C and hotter on VRM (any VRM). Hotspot delta IDEALLY never goes past 20C but sub 30 is acceptable (e.g. 70C avg, 99C hotspot isn't great but it's not dangerous). It usually means your cooling is mounted incorrectly, the contact is loose so some parts of the die aren't cooled as actively as they should be. Hotspot above 110C should also set the alarms.
You also definitely don't want your RAM and SSDs running hotter than 65C. HDDs, 55C.
184 (0.09/day)
El Salvador
yeah i understand the feeling as well lol.
i wouldnt care much about this topic if the gpu situation wasnt annoying as it is right now with scalpers and paper launches, plus tbh the 50 series is not worth it i rather wait for 60 series gpu.
therefor my reason to ask about this particular information.
43,517 (6.76/day)
Just replace your thermalpads and paste with better stuff
3,572 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Storage Yes.
43,517 (6.76/day)
Fyi all card makers use budget thermal pads a 1 size solution, they all dry up. The user is concerned and should just put better 1s on to ease their mind.
freeagent
9,682 (4.14/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I would say you are probably doing ok considering the ambient temperature difference between you're location and mine :)
I am 47 and the transformation is almost complete. I bypassed grey and went straight to white. Dammit.
3,572 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Storage Yes.
@eidairaman1, it will cost some effort. There's no "one size fits all" situation, OP needs to learn what thickness is ideal for their exact GPU and possibly learn how to disassemble this GPU correctly (no idea if they have respective experience). It also costs money and time.
I'm not disagreeing with you, it's just taxing and not even SNAFU at this moment.
184 (0.09/day)
El Salvador
the one thing ive changed in other gpus before has been the thermalpaste, and thats it never touched thermal pads.
if it matters i have a rtx 4070 asus dual
freeagent
9,682 (4.14/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I replaced the paste on my 4070Ti with a Thermalright Heilos pad. I think it works pretty well..
1,128 (0.75/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
The operating temperature of the GDDR6X D8BZC Micron memory is from 0C to +95C. Enough to outlast the shortage of 60 series without changing the pads.
3,572 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Storage Yes.
Kept at 80ish degrees, they can work basically forever. GPUs generally become too weak or too old (lacking features) long before they physically die.
43,517 (6.76/day)
Yeah those run HOT
7,378 (1.04/day)
Video Card(s) Sapphire Radeon RX 590 Nitro+ SE (RX 7900 XT/XTX or RX 9070 XT?) | Intel® Iris® Xe Graphics
Yeah those run HOT
My Asus Dual didn't get that hot but again I use a Asus AP201 mesh case no fancy tempered glass this also helps a lot with temps ;)
7,378 (1.04/day)
I have a lian LI air mini 011, should be pretty good for air flow I would assume.
Yeah depending on your fan configuration, I used FanControl by Rem0o with a custom fan curve for my dual cpu fans, gpu fans and the one at the back set to anything over 65C the fans should go higher in speed to keep cool but I never really heard any noise even playing Indiana Jones and The Great Circle on my setup in December noise wasn't really bad.
Right now I am using my older Sapphire Radeon RX 590 Nitro+ Special Edition gaming Wolfenstein 2 The New Colossus and Sapphire did a really great job on this card I can't even hear the fans at max 1440p settings.
29,065 (6.86/day)
Your temps are fine. Perfectly within specs and expectations.
That could be helpful. Not critical in this user's case but any improvement is a good thing.
7,506 (4.98/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
It's great stuff. To summarize:
1. Those temps are fine.
2. Hotspot can go into the 110s degrees C. Yours is nowhere near that. This is a worst case scenario and it is the hottest temperature measured in the entire GPU core.
3. Memory junction temperatures are well within acceptable. Bearing in mind, that this is also a worst case scenario, the hottest temperature detected throughout the full array, so hottest area of the hottest chip. In reality, this is significantly lower overall and when averaged. Unless this measurement exceeds 105 degrees C, it is well within specification.
4. Card is new, thermal pads on the memory and VRM are gonna be in great shape for a few years still. Do not replace them needlessly.
5. It is rare, but TIM pumpout can occur on a new card. However, it doesn't look like yours have seen that issue since temps are fine.
Conclusion: Your GPU does not need to be serviced. There is nothing to worry about.
1,883 (0.40/day)
Romania
I also get about the same temps with my 4070 Dual. You can undervolt it, mine dose 2700Mhz at 950mV and the card will be cooler and quieter.
80 (0.47/day)
Processor 12400f
Motherboard Msi b760 p
Cooling Oem
Memory Viper 2x8 3600 cl17
Video Card(s) Msi rx 6700 xt mech
Storage Pny 256 m2, Kioxia Sata ssd 480
Display(s) Iiyama 2470hsu b6
Case Fury Shobo
Audio Device(s) On board, Microlab Fc 330
Power Supply Msi a650bn
Mouse Logitech g203
Keyboard Logitech
From my experience everything below 85c in very demanding titles is fine. Temperatures also depends on speed of the fans. If they are at 100% with over 85c - there is a problem. You should always undervolt gpu. Not too much though...50-70mV would do and save you +25 watts.
