RTX 50x0 Founders edition PCIE gen. 5 signal quality issues?
1,047 (1.67/day)
I noticed that Roman had problems with his FE card, he needed to drop the PCIE speed to gen 4 to get the card to work properly:
These cards have one more connector and a ribbon cable in the signal path compared to standard cards, which may impact the signal quality.
I am not an expert in this field, have no deep electronics knowledge nor measuring equipment and will not own these cards, so I can offer no input about this on my own, but other consumers will start getting these cards today, and for sure they will be able to provide their experience.
144 (0.13/day)
Processor Intel i5 9400f
Motherboard MSI Z390 Gaming Plus
Cooling SilentiumPC Fera 3
Memory 2x 8GB Corsair Vengeance LPX 3200 16-18-18-36
Video Card(s) MSI GTX 1660 Super Ventus XS OC
Storage 500 GB Kingston A2000; 1 TB Kingston A2000; 1 TB HGST Travelstar
Display(s) AOC 24G2U
Case SilentiumPC Signum SG1
Audio Device(s) Creative Pebble Plus; Logitech G533
Power Supply beQuiet Systempower 9 500W
Mouse Logitech G403 Hero
Keyboard HyperX Alloy Origins (Red)
Not like it really matters in any way:
Ruru
S.T.A.R.S.
13,311 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
If even PCIe 4.0 needs better riser cables, that modular solution of those cards having the PCIe connector via a ribbon cable sounds more than a suspect to me.
1,047 (1.67/day)
Performance loss is one issue - it may not matter much, but the crashes and not booting is another problem, which may cause some users not only stress, but some may not be able to troubleshoot and solve it and will simply return or RMA the card.
Ruru
S.T.A.R.S.
13,311 (3.00/day)
Jyväskylä, Finland
1% performance loss is practically something in margin of error. You wouldn't even notice that without having an OSD on in games.
139 (0.05/day)
There is no ribbon cable involved with PCIe connector. It connect directly from PCB board via another connector.
Ruru
S.T.A.R.S.
13,311 (3.00/day)
Jyväskylä, Finland
3,477 (1.11/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
There is no ribbon cable involved with PCIe connector. It connect directly from PCB board via another connector.View attachment 382547
It doesn't really matter, the concern remains the same. An additional connector the signal has to transfer over just adds another potential point of failure and signal loss.
PCIe 5.0 signals are extremely finicky.
I commend the design that went into this card but I doubt it's longevity.
soupinator
9 (0.04/day)
The weird thing here is that this problem has only been reported on the 5080 FE, not the 5090 FE - why? The two PCBs are quite different but the PCI-E boards appear to be identical. The only thing that seems odd to me is that the connector for the display outputs on the 5080 is up in the middle of the board, so I wonder if that's causing some electrical interference due to passing over the PCI-E traces on the main PCB.
I have a 5080 FE on the way and a PCI-E 5.0 motherboard so I'll report back if I have any issues with it.
3,477 (1.11/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
Could be the length of the traces or number of PCB layers are different. Could also just be we don't have a large enough sample size yet. The issue might happen on both at equal rates. Hard to tell right now.
