Rx 570 4GB error 43 problem bios version
Luffy
8 (0.01/day)
Hello, specialists I have a problem with my graphics cards RX570 Gigabytes 4GB purchased occassions.
My problem is this.
Despite installing the driver (AMD Adrenalin 22.11.1)
The cards all have the same problems. 43 errors displayed in Device Manager
I think the cards were flashed for mining.
I noticed a problem with the bios version (see photo attached) on the set of 6 cards, I was able to rework two.
By flashing with atiflash amdvbflash 3.31
The other 4 it does not work even forcing via (command prompt) I always have the same error message (Errors OFL01) see photo attached.
I reached my limits to find a solution... I know that we can flash the bios with a CH341A adapter, I await your answers and I thank you in advance for taking the time.
PS: in the attached photos there are two screenshots of the TechPowerUp GPU-Z software for you to see the differences in bios.
41,699 (6.60/day)
Yeah someone put a Sapphire bios on that card for mining
Did you install the driver for AMDVBflash 3.31?
Luffy
8 (0.01/day)
Yes, it is thanks to this manipulation that I was able to flash two out of the 6
For the other 4, impossible because of the version of the bios that does not correspond to any of the versions rx 570
When I type the version of the sapphire bios on the VGA bios collection site. The result displayed are rx 470. It's very weird
41,699 (6.60/day)
Ok dont try flashing multiple cards at once
41,699 (6.60/day)
I didn't do that, I tried one by one without success
Start getting sticker pics from the card backs and get pics of a ram chip from each card corresponding to the sticker pics from each card.
Luffy
8 (0.01/day)
Here is
I think my problem is that no rx 570 bios version is compatible with the version installed on my boards.... That's why I can't flash them. What do you think of my reflection. I do not know how the person managed to flash the cards with this bios version which corresponds to rx 470 4gb or rx 470 8gb and yet my card is still recognized as an rx 570
41,699 (6.60/day)
Here isView attachment 271688View attachment 271689
I think my problem is that no rx 570 bios version is compatible with the version installed on my boards.... That's why I can't flash them. What do you think of my reflection. I do not know how the person managed to flash the cards with this bios version which corresponds to rx 470 4gb or rx 470 8gb and yet my card is still recognized as an rx 570 View attachment 271694
Give me time to find it
41,699 (6.60/day)
Bios from 2019 03 01
2019 03 15
The rest are older, if you pick 1 from this list you must ensure Samsung FE Ram is contained in the details.
Luffy
8 (0.01/day)
I have this version of bios it didn't work
Besides, I tried all the Gigabyte versions too
41,699 (6.60/day)
I wasn't finished.
If I were you, I'd have the card in a pcie slot and not on a riser cable, firmly installed in slot, squared.
Get Amdvbflash/atiflash 2.93, Go here https://www.techpowerup.com/download/ati-atiflash/
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Download atiflash/amdvbflash 2.93
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to biosname.rom
(Biosname.rom is just an example, change it to match your card model in 5 characters with .rom on end)
4. Move biosname.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
7a. Type in amdvbflash.exe -i to know which gpu to flash (0, 1, 2 etc)
8. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0 (or 1, 2)
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked"
9. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 (or 1, 2) biosname.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0)press enter.
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen
Luffy
8 (0.01/day)
Thank you for your quick answer, I will test your method tomorrow morning and I will give you a feedback
41,699 (6.60/day)
Yes please do so
Bear in mind if you have 2 GPUs and the working 1 is in your top slot and the 1 you are trying to flash is in a lower slot, the top GPU will be labeled 0 and the lower will be labeled 1. If you are in a AMD APU or intel core i cpu and have monitor hooked up to the I/O ports area, then the gpu is probably in top slot (0)
41,699 (6.60/day)
Hi, thanks a lot, All of them worked with your method . Thank You eidairaman1
Get some gpu z screens and lets see
