System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Hi I've received a RX 570 Armour OC 8GB card with the error 43 I've tried flashing numerous of bios and roms but its keeps coming up as two GPUS
I can provide more info if needed
System Name | Simona |
Processor | I7 12700K 5.1P/4.0E @ 1.288v |
Motherboard | ASUS STRIX Z690 A |
Cooling | Kraken Z73 360mm |
Memory | Corsair vengence Pro 4000mhz CAS 19 |
Video Card(s) | GTX 1080 2154mhz |
Case | Lian Li 011 Dynamic |
VR HMD | Oculus Rift S |
Already know this myself, its a general fault.Code 43 means the drivers have failed to initialise due to a hardware related fault or a driver related issue - In most cases its caused by a faulty component.
I am assuming you have freshly installed drivers using DDU
Doesnt come up as a mark 2 from the label so its a OG unitHi
I hope these are good enough
I made it come as one gpu but i still get the error
They were bottom bin msi cards (armor)Hi thanks for your help I just threw the card away as its possible it's too far gone because its pretty much dead as I get pixies all over the screen now so rip to the card
