RX 570 doesn't work well
theralph224
3 (0.00/day)
Well, I got a 8 months old RX 570 and I am not that much of a PC nerd (no offense). I think my PC doesn't connect with the driver or however that works. I downloaded the GPU-Z and it shows my GPU isn't running at all, how does this work? Well it doesn't work now, but does someone know how I can get this to work?
4,628 (0.74/day)
where everyone wants to be
System Name Everchanging
Processor AMD Ryzen 9 5900X
Motherboard ASUS ROG Crosshair Dark Hero
Cooling Arctic Cooling Liquid Freezer 2 420mm
Memory 2x16GB Corsair DDR4 3600 CL16
Video Card(s) eVGA RTX 3090 Ti FTW3
Storage Samsung 980 Pro 256GB, Samsung 980 Pro 2TB
Display(s) 2xSamsung 28" 4k HDR 144Hz
Case Fractal Meshify 2 XL
Audio Device(s) fiio K9 to Hifiman Sundara's via 4.4mm balanced cable
Power Supply Seasonic Prime TX 850w
Keyboard Corsair K70 RGB PRO
Software Windows 11 x64
Can you post a screen shot of the Graphics Card tab, please?
4,628 (0.74/day)
Looks like it could be something with the driver is off, have you tried updating to the latest 21.2.3? If you haven't, I would try that. Display Driver Uninstaller is a good utility to use to make sure the uninstall is 100% clean. Guides and download can be found on Guru3D.
theralph224
3 (0.00/day)
I will take a look at it, but I don't think so
Well downloading 21.2.3 made it worse. Now I'm getting blackscreens all the time.
